SAC ILS "ADF Required" Info
Old June 8th 06, 11:59 PM posted to rec.aviation.ifr
Default SAC ILS "ADF Required" Info
I just got some information back from the FAA on why an ADF is now
required after several decades of being able to fly the approach w/o
the ADF....
"Mr. Gary: The FAA Flight Procedures Office has issued a NOTAM
amendment 22C. This amendment states that the ILS Runway 02 approach at
SAC Airport requires ADF due to the inbound course 015 degrees is off
by 1 degree starting at the Coups IAF to the VOR. This procedure can
still be flown with GPS if an ADF is not available. The FAA has stated
that this approach will be amended in the future to realign the
approach course, probably using the Vortac. This does not effect the
future decommissioning of the NDB at SAC. Flight Service might have
more information if you need it. "
-Robert
Old June 14th 06, 08:49 PM posted to rec.aviation.ifr
the ADF....
It's too bad he didn't say what the ADF or GPS is required for.
Old June 15th 06, 03:03 AM posted to rec.aviation.ifr
the ADF....
What part of "requires ADF due to the inbound course 015 degrees is off
by 1 degree starting at the Coups IAF to the VOR" don't you understand?
Old June 15th 06, 03:07 AM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:Wd3kg.179045$bm6.51565@fed1read04...
What part of "requires ADF due to the inbound course 015 degrees is off by
I don't understand what the FAA Flight Procedures Office believes ADF or GPS
is required for on the SAC ILS RUNWAY 2 SIAP.
Old June 15th 06, 03:30 PM posted to rec.aviation.ifr
They have their reasons, and sometimes their reasons are not very sound.
Old June 15th 06, 03:43 PM posted to rec.aviation.ifr
news:O9ekg.179076$bm6.79817@fed1read04...
As in this case. Bottom line is ADF does not provide any information needed
to fly this approach.
Old June 16th 06, 01:04 AM posted to rec.aviation.ifr
Some times, as in this case, it's hard (or impossible) to understand the
reason behind a "Chart planview note: ADF required". Usually that would
be there if the LOM is needed for procedure entry, and in this case it
would only be required for procedure entry if NORCAL can't vector
aircraft to final for some reason. Is NORCAL able to vector aircraft to
this final approach course at a suitable altitude? If not, that would
explain the ADF required note. Perhaps "ADF or RADAR required" would
have been more appropriate.
It wouldn't be charted that way just for the sake of the LOC portion,
because if that was the case, they would have changed the title of the
procedure to indicate the extra equipment required for the non-precision
final. Assuming the outer marker works, then ADF would not be required
for the LOC FAF, because the OM would take care of that.
The ILS doesn't need the LOM for final since it relies on glideslope
intercept, and not the non-precision FAF.
In this case the LOM is not required for missed approach, as the MA
instructions give the option to go to the VORTAC.
It would be nice if the procedure could include the reason the ADF is
required, i.e., "ADF required for missed approach" or "ADF required for
procedure entry when radar OTS".
It appears this procedure can be completed via radar vectors to final,
then glideslope intercept (ILS) or OM (LOC), followed by MA back to SAC
VORTAC. Don't see a need for the ADF as long as NORCAL can vector to final.
Guess this is just one of lifes mysteries.
JPH
Old June 16th 06, 04:19 PM posted to rec.aviation.ifr
"JPH" wrote in message
news:qAmkg.7416$f76.6314@dukeread06...
would only be required for procedure entry if NORCAL can't vector aircraft
to final for some reason. Is NORCAL able to vector aircraft to this final
approach course at a suitable altitude? If not, that would explain the ADF
required note. Perhaps "ADF or RADAR required" would have been more
appropriate.
final. Assuming the outer marker works, then ADF would not be required for
final.
Where do you see a need for ADF without vectors to final?
Old June 16th 06, 05:07 PM posted to rec.aviation.ifr
appropriate.
final.
When told to head direct EXECC (IAF) and fly the approach pilot-nav.
Technically, EXECC is the IAF, not the VOR. However, because they are
so close, I think most pilots just use the VOR.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old June 16th 06, 05:23 PM posted to rec.aviation.ifr
"Mark Hansen" wrote in message
There's a feeder route from the VOR to EXECC. There's no need for ADF on
this approach, the note "ADF REQUIRED" is an error.
Help! - Wooden prop - any info? G0MRL Aviation Marketplace 1 February 13th 06 03:14 PM
Seeking Northrop Gamma info Dillon Restoration 3 December 12th 05 04:45 AM
Helicopter Physics info online anywhere?? [email protected] Rotorcraft 4 April 24th 04 04:18 PM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
