Wing Root Fairing
Old June 17th 06, 02:37 AM posted to rec.aviation.owning
Default Wing Root Fairing
First impressions of adding Knot2U wing root fairings on my Cherokee 140:
Nothing clearly different in the handling/performance of the plane.
Of course, I hadn't flown the airplane since Nov 05 (surgery) so
insert jokes about not remembering much here..
Bob Noel
Looking for a sig the
lawyers will hate
Old June 17th 06, 03:00 AM posted to rec.aviation.owning
Wallet noticeably lighter....
Old June 17th 06, 04:10 AM posted to rec.aviation.owning
In article . net,
.4 AMU is hardly noticeable in the aviation world :-)
Bob Noel
lawyers will hate
Old June 17th 06, 02:46 PM posted to rec.aviation.owning
What are you hoping for?
Dan
C172RG at BFM
Old June 17th 06, 05:04 PM posted to rec.aviation.owning
"You will notice:
******** = 1-2 mph increased cruise.
******** = Reduced stall speeds
******** = Improved low speed handling
******** = Improved Stabilator Authority in the flare"
To be fair, I wasn't "hoping" for much. The wing root fairings are
just a start at some airframe cleanup. I probably won't do the rest
of the available mods until after painting the airplane. The wing root
fairings are easily removed for painting, unlike the other mods.
Bob Noel
lawyers will hate
Old June 17th 06, 06:38 PM posted to rec.aviation.owning
I had the following installed:
hoerner wingtips (and the installer obviously didn't know what he
was doing, but at the time, neither did I),
flap gap seals (good install job)
aileron gap seals (another good install job)
the difference? on the checkride, even the DE couldn't get the
cherokee to stall (power-on stall). After 3 tries by me, he took
over. I think we were at 30 deg. nose up when he decided it wasn't
worth anymore time or effort.
Old June 18th 06, 02:18 AM posted to rec.aviation.owning
Bob: From a shop stand point, you want to accomplish all the mod work
prior to doing the pain work. We had a client that always, and I mean
always! had us do the paint work before everything else on his
aircraft. It took three times as much labor to do anything as you had
to carefully mask off and pad any area that you had to lean over or sit
on to get at the work area. Save yourself the time, aggrivation and
nerves and get all the work done first and then paint.
It will also save you some bucks in the end...
Craig C.
Old June 22nd 06, 01:24 AM posted to rec.aviation.owning
Bob Noel wrote:
I'm a bit confused. Other than the wing root fairing, the speed mods
(flap hinge fairings, aileron and flaps and stab gap seals) seem to be
easily worked without leaning over or sitting on parts of the airplane.
Am I missing something?
Also, I thought it would be easier to strip and paint before the mods
and one more thing, I had thought about having the paint shop install
the mods... don't know if any do that though.
If your paint shop is going to do the mods that's one thing....What I
was trying to get across is that you want to accomplish all the tasks
that require disassembing and reassembling of the aircraft prior to the
paint job. When the paint guys take it apart for stripping and
painting, you want it to go back together and never have to come apart
again....expect for maintenance.
Our client was the type that it had to be repainted first, then we tore
it down to hang new canopy glass, run new electrics, replace the
complete interior, change all the instruments and their wiring and
plumbing and on and on, all which required climbing all over the
aircraft right after the new paint job.
In my book, the last thing I want to do prior to delivering a
restoration is the paint so that there is less chance to damage the
most visable part of the restoration.
Craig C.
Good news for private pilots' spouses Skylune Piloting 30 July 7th 06 11:19 PM
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
