SAC ILS "ADF Required" Info
Old June 19th 06, 02:38 PM posted to rec.aviation.ifr
Default SAC ILS "ADF Required" Info
Steven P. McNicoll wrote:
"Jose" wrote in message
y.net...
To comply with the notation on the chart "ADF required".
Notes like this are not regulatory, they're just reminders.
That is incorrect.
  #32
Old June 19th 06, 02:39 PM posted to rec.aviation.ifr
.net...
I suppose this would be true, as the actual regulations are in part
something-or-other, and it is not required that one even have the chart,
just the textual description of the approach. Nonetheless, I would expect
pilots not to second-guess government publications in that manner; after
all part something-or-other might also have a misprint.
If it is an error, it should be NOTAM'd until it is reprinted. Absent a
NOTAM, I would expect pilots to rely on the government publication that
contained the putative error.
In what manner would you expect pilots to rely on the note "ADF REQUIRED" on
the SAC ILS or LOC RWY 2? When ADF is actually required on non-NDB
approaches the note "ADF REQUIRED" adds nothing to the approach, it simply
states a fact. When the note appears on an approach that can be flown
without ADF it only creates confusion.
FAA Order 8260.19C Flight Procedures and Airspace
CHAPTER 8. INSTRUMENT APPROACH PROCEDURES DATA TRANSMITTAL SYSTEM
SECTION 3. COMPLETION OF FAA FORMS 8260-3/5
814. NOTES.
h. Equipment Requirement Notes. Determine the need for equipment notes
after evaluating all SIAP segments, including missed approach. To avoid
proliferation of equipment requirement notes, all IFR aircraft are assumed
to have at least one VOR receiver. Therefore, the note "VOR required" is
not appropriate. VOR, ILS, or other non-ADF approaches may require ADF for
procedure entry or missed approach. Use standard Note: "ADF required." If
radar vectoring is available, use standard Note: "ADF or radar required."
You have just proven yourself wrong. The note that results from
application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5
which is an amendment to FAR 97.
  #33
Old June 19th 06, 02:41 PM posted to rec.aviation.ifr
There's a feeder route from the VOR to EXECC. There's no need for ADF on
this approach, the note "ADF REQUIRED" is an error.
Steven, if you have any push with the FAA, any help getting this
notation removed would be very, very appreciated. This is causing
headaches for many pilots who don't have IFR GPSs (and of course most
of us put the ADF in the dumpster long ago). I was talking to a local
DE who used to be a big wig at the FSDO. He didn't even believe me
until I pulled out the charge. He said he was going to make some calls
to the FAA and thought perhaps he could help get this fixed as well.
-Robert
It has already been mentioned to the proceddures folks. They will "get
around to it when they can." AOPA has a lot more juice than Steve but
they are overwhelmed fighting user fees.
  #34
Old June 19th 06, 02:55 PM posted to rec.aviation.ifr
I have no push with the FAA. The TPP has an email address for notification
of charting errors on the inside front cover. I sent the following message:
I found an error on the SAC ILS or LOC RWY 2 SIAP chart. The note "ADF
REQUIRED" appears on the approach plate, but ADF is not required for
procedure entry or missed approach. Since this approach can be flown
without ADF or GPS in lieu of ADF the note is in error and must be removed.
  #35
Old June 19th 06, 02:56 PM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:0Nxlg.179313$bm6.96676@fed1read04...
That is incorrect.
As they can be nothing else, that is entirely correct.
  #36
Old June 19th 06, 02:58 PM posted to rec.aviation.ifr
news:sOxlg.179314$bm6.172001@fed1read04...
You've just demonstrated your inability to use simple logic.
  #37
Old June 19th 06, 03:06 PM posted to rec.aviation.ifr
.... in the same manner that pilots would deal with being given a
clearance to fly an ILS when they did not have an ILS receiver aboard.
I expect pilots to rely on the publication as accurately reflecting
facts, and the presence of "ADF Required" (which as stated upthread was
actually initiated by NOTAM) would be relied upon as reflecting the fact
that ADF is required.
I would not expect pilots to second-guess NOTAMS or approach procedures.
If it says ADF required, then an ADF is required.
So, if cleared for the approach, and no ADF is aboard, the word "unable"
or some equivalent would be legally required.
As you note, when the note is "in error", confusion results.
Jose
  #38
Old June 19th 06, 03:07 PM posted to rec.aviation.ifr
It would be interesting to hear the response.
Jose
  #39
Old June 19th 06, 03:46 PM posted to rec.aviation.ifr
When you are out of ideas then, in your typical fine fashion, you resort
to personal attacks.
Shoot the messenger as you so love to do, Steve.
That does not change the FACT that the note is an FAR.
  #40
Old June 19th 06, 03:47 PM posted to rec.aviation.ifr
That is incorrect.
Why can they be "nothing else?"
Help! - Wooden prop - any info? G0MRL Aviation Marketplace 1 February 13th 06 03:14 PM
Seeking Northrop Gamma info Dillon Restoration 3 December 12th 05 04:45 AM
Helicopter Physics info online anywhere?? [email protected] Rotorcraft 4 April 24th 04 04:18 PM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
