OAT for RADAR on fighters?
Old June 19th 06, 03:50 PM posted to rec.aviation.military.naval,rec.aviation.military
Default OAT for RADAR on fighters?
While reading through Hans-Heiri Stapfer's "Walk Around MiG-21 Fishbed
Part 1" (Squadron-Signal), he makes mention of a temperature probe
mounted low on the nose on an MiG-21F-13. Why would a radar rangefinder
need to know the OAT?
Old June 19th 06, 04:38 PM posted to rec.aviation.military.naval,rec.aviation.military
Dunno about MiGs, but every high performance tactical aircraft I ever
dealt with had an OAT input to the Central Air Data Computer (or
whatever it was called on a particular system.) Air temp is a
component of density and that is a factor that impacts range of a
weapon.
Since dum**** fighter drivers don't like numbers the presentation on
the radar screen would be little lines indicating min and max ranges.
When the radar gets a range, the computer whiz-bang calculates how far
the gizmo can get at the current density altitude.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Old June 19th 06, 08:00 PM posted to rec.aviation.military.naval,rec.aviation.military
Thanks, Ed, I knew you'd come through. Ah, dum**** RADAR operators in
the back of big airplanes don't really like numbers, either, but once
you get engineers involved who know better than the people that have to
use the systems...
Don
weapon.
Ed Rasimus
Old June 19th 06, 09:38 PM posted to rec.aviation.military.naval,rec.aviation.military
In message , Ed Rasimus
writes
I love Ed's knack for concise, elegant and accurate descriptions. If
only we were allowed to use such enjoyably accessible styles in official
handbooks...
(I do what I can with a war on the passive voice, but it's a slow and
uphill fight)
Paul J. Adam
Old June 19th 06, 11:28 PM posted to rec.aviation.military.naval,rec.aviation.military
On Mon, 19 Jun 2006 21:38:42 +0100, "Paul J. Adam"
writes
handbooks...
uphill fight)
Bless you and know that the fight against the passive voice is a noble
crusade. We are dealing with it in the US Congress even as we speak.
Those damn passivists are simply cowards...and their voices are so
whiney.
I think I manage to stay away from passivity pretty well, but got
taken to task the other day by someone who read my blog regarding my
dangling particles or some-such. That's an indignity up with which I
need not put.
Ed Rasimus
Old June 20th 06, 03:27 PM posted to rec.aviation.military.naval,rec.aviation.military
weapon.
AFAIK temperature determins the speed of sound all on its own. Air
density seems to have nothing to do with it unless you get to near
space. Air density of course would determin dymanic pressure.
Technically the speed of sound is the square root of the ratio of air
pressure over air density all multiplied by a constant known as adiatic
exponent of air. However as the ratio of pressure to density is a
constant at a specific temperature temperature is all that is needed.
Best look at it here
http://www.sengpielaudio.com/SpeedOfSoundPressure.pdf
The WW2 British blind bombing system Oboe made compensations for air
density variations so possibly modern radars use it as well, probably
not so much for ranging but for doppler or anti-jamming measures.
Ed Rasimus
Old June 20th 06, 04:01 PM posted to rec.aviation.military.naval,rec.aviation.military
On 20 Jun 2006 07:27:56 -0700, "Eunometic"
weapon.
You are correct, but irrelevant to the discussion of the relationship
between OAT and radar ranging. Mach is temperature dependent and since
the atmosphere gets colder as you rise, the speed of sound will
change.
But, while high performance aircraft do have mach indicators, they
operate on the basis of airspeed--which leads to an entirely more
complex discussion as we start to grapple with indicated, calibrated,
equivalent and true airspeeds as well as ground speed along with the
trigonometric impact of dive/climb angle relating to bombing.
Highly recommend you don't fly landing approach on mach.
Ed Rasimus
Old June 21st 06, 03:08 AM posted to rec.aviation.military.naval,rec.aviation.military
Hey, Ed, M 0.1 is a maximum cruising speed for most old fuds on the
Green Stamp.
BTW I don't think that OAT probe has much to do with the radar. I'd
suspect it's for the air data computer to feed the Machmeter (for some
reason the 21 has a big one, probably so the pilot will fly the exact
Mach commanded by his controller) and the engine and anti-ice systems.
BTW when the 21 was first placed in commission Sov philosophy didn't
allow the interceptor pilot much freedom at all; he was essentially
just the interface between the GCI controller and the two Atolls. I
used to watch their training intercepts on GCI radar at one base i was
at.
Cheers - Walt BJ
Old June 27th 06, 02:41 PM posted to rec.aviation.military.naval,rec.aviation.military
Ed Rasimus nicked:
That's an indignity up with which I need not put.
Churchill.
Gotcha.
(hah -- it's a pretty good line.)
Billy
http://www.two--four.net/weblog.php
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Restoration 0 October 30th 04 06:21 PM
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Piloting 0 October 30th 04 06:21 PM
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Naval Aviation 0 October 30th 04 06:20 PM
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Instrument Flight Rules 0 October 30th 04 06:20 PM
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Home Built 0 October 30th 04 06:19 PM
