Corrosion at Aluminum/Steel Junction
Old June 19th 06, 07:34 PM posted to sci.military.naval,rec.aviation.homebuilt
Default Corrosion at Aluminum/Steel Junction
I need to build a dozen outdoor canopies for an office building.
I want to use structural aluminum channel, bolted with steel bolts.
Where might expect corrosion to arise over the years, and would
it be mainly in the aluminum or in the steel bolts?
Thanks for any help.
Please post here or email me at grayscale[AT]verizon.net
Ralph
Old June 19th 06, 08:54 PM posted to sci.military.naval,rec.aviation.homebuilt
Ralph
I would think stainless steel bolts or some form of fiber or plastic
(lucite) washer would provide the rigidity and separation. Not that
that view is universal:
http://www.eng-tips.com/viewthread.c...=154321&page=1
mattmlm (Structural)
9 May 06 10:21
I've got a project where Aluminum columns (and base plates) are being
anchored to a concrete pier/footing. The contractor used your everyday
common steel threaded anchor rods. In less than two weeks they are
completely rusted over. The contract documents called for hot-dipped
galvanized anchor bolts. (before judging, we did not provide the design
or specifications, simply consulting on a separate portion of the
larger project)
I'm thinking of having the contractor cut off and drill-in epoxy grout
anchors.
Will the galvanized anchor bolts react to the aluminum? Should I use
aluminum anchor bolts? If alum, what affect would the anchors have in
steel reinforced concrete?
Thank you,
MLM
Start your own Eng-Tips Group! Click Here!
Goahead (Aerospace)
9 May 06 11:10
Galvanized steel anchor bolts should be OK with aluminum.
As an extra precaution the contact areas could be painted with
insulating paint.
http://www.welding-advisers.com/
TVP (Materials)
9 May 06 11:30
Al bolts are unlikely to be strong enough if they were not specifically
incorporated into the design. Zinc is the most compatible coating for
steel bolts that is also relatively cost effective.
Heckler (Mechanical)
9 May 06 12:09
Aluminum and Zinc are really close together on my Galvanic Corrosion
Potential Chart.
9 May 06 12:24
Is that good thing or a bad thing?
MLM
theonlynamenottaken (Structural)
9 May 06 13:17
Its a good thing... the farther apart two metals are on the galvanic
series the greater potential between them, hence more aggressive
attack.
Aluminum embedded in and in direct contact with concrete is not
acceptable. A chemical reaction occurs and the concrete literally self
destructs from the expansion (product of the reaction, just like rust
on carbon steel that is allowed to corrode in concrete). I don't know
about epoxy grouted aluminum in concrete but I've seen slabs with
aluminum cast into it break themselves apart.
UcfSE (Structural)
9 May 06 13:23
I have a question to go along with this. I have noticed in the past
with aluminum panels that the manufacturer of the panels has
recommended stainless steel screws with some kind of special washer
between the steel and the aluminum. Does that line of thinking work
also in this case, say with using stainless steel anchor bolts or epoxy
bolts with an aluminum base plate?
9 May 06 13:40
How good is stainless in direct contact with Aluminum? When this issue
first came up, the only thing that I thought of was stainless. Then
came the comments about the specs calling for hot-dipped galvanized.
I've always assumed that stainless was preferred, if not required. Is
that assumption correct?
MLM
Also, thanks for the input.
9 May 06 14:35
ASTM A-153 or ISO 1461 covers hot-dip galvanizing. I think it's more
of a cost factor when considering Stainless verses galvanized steel.
Goahead (Aerospace)
10 May 06 12:04
Stainless should not be in contact with aluminum. Stainless fasteners
should be Cadmium or Zinc plated before
being inserted in aluminum bodies. Usual anodizing or conversion
coating are not protective enough at the contact place.
IFRs (Petroleum)
26 May 06 16:21
In my experience (27 years in the petrochemical industry), aluminum and
stainless fasteners are acceptable in most environments. Althought
they are far apart on the galvanic scale, the typically much larger
area of the aluminum part compared to the fastener reduces to nearly
nil the tendency of the aluminum to corrode. However, in this case,
I'd definitly use galvanized anchors - they were specified, are
compatible, are probably more available not to mention less costly.
Note that the environment is a critical issue - If this is on the
seashore, or exposed to wet atmosphere, or under water, or vibrating
from machinery, etc then corrosion needs to be re-evaluated.
Old June 19th 06, 10:25 PM posted to sci.military.naval,rec.aviation.homebuilt
"Front Office" wrote in message
Ralph
Ralph,
I'm 'going through' my 11 year old aluminum boat trailer right now which was
bolted together with galvanized bolts. I don't see the aluminum pitting I
would have expected around the bolt holes. I do have a few rusty bolts which
are easily replaced. I recommend you use this method. If you go with S/S
bolts you WILL have pitting around the aluminum holes (as the least noble
metal gets the damage) and it will not be easily repaired in the future.
Larry
My turbine powered boat project;
http://www.turbinefun.com
Old June 19th 06, 11:38 PM posted to sci.military.naval,rec.aviation.homebuilt
I suggest you take this question to rec.crafts.metalworking.
Vaughn
Old June 20th 06, 12:04 PM posted to sci.military.naval,rec.aviation.homebuilt
Ralph
In a marine environment, the aluminum will go more quickly.
The ADAMS-class DDG and the FFs made during the 1960s had aluminum---or
should I say, al-loo-min-ee-um?-- bolted to a steel plate with a special
sort of bolt called a Huck bolt. They all experienced corrosion of the
aluminum. (black electrical tape separated the two metals.)
The TICONDROGA and SPRUANCE class ships had aluminum superstructures
which were welded to a "fusion bar" which consisted of a piece of very
clean and smoothly-machined piece of aluminum FLAT BAR joined to a very
clean piece and smoothly machined piece of steel flat bar via explosive
charges.
M.S.
Old June 20th 06, 03:05 PM posted to sci.military.naval,rec.aviation.homebuilt
On Mon, 19 Jun 2006 18:34:46 +0000, Front Office
Ralph
a product called Duralac is designed to prevent the electrolytic
corrosion between dissimilar metals.
it is an aviation product made in england. comes in a white and yellow
tube.
it is a toothpaste consistency yellow fluid containing zinc chromate.
it dries slowly to a rubber consistency.
the stuff is used for pop rivets with great benefit in corrosion
control. you just dip them in it prior to setting the pop in a wing
skin.
it is good stuff. two tubes in my aviation tool box.
Stealth Pilot
Old June 21st 06, 12:41 AM posted to sci.military.naval,rec.aviation.homebuilt
On Tue, 20 Jun 2006 22:05:55 +0800, Stealth Pilot
tube.
Minor point, it only contains Barium Chromate and White Spirit.
You can also buy bigger tins of it, It's used in a lot of marine
applications as well as aviation.
Old June 21st 06, 02:32 PM posted to sci.military.naval,rec.aviation.homebuilt
On Wed, 21 Jun 2006 00:41:07 +0100, Martin Evans
tube.
had to drag out my tube.
that's true.
Stealth Pilot
Old June 22nd 06, 03:21 PM posted to sci.military.naval,rec.aviation.homebuilt
tube.
that's true.
Stealth Pilot
Hard to get zinc chromate in the average consumer product
anymore. It's been linked to cancer. Zinc *oxide* is often seen in
those green aerosol primers now. I can still get Endura epoxy zinc
chromate, clearly labelled "for industrial use only."
Dan
Pilatus B4 and corrosion Mika Koski Soaring 1 April 26th 06 09:50 PM
Corrosion Evaluation Help Dick Home Built 3 July 15th 05 02:51 AM
Surface Corrosion? Joaquin Murrieta Home Built 2 May 3rd 05 01:19 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
