Steven P. McNicoll wrote:
"Mike" wrote in message . .. Using trigonometry, I get ~ 785ft 2.5 miles out from the touch down zone, so your method is pretty accurate. Here's my calculation: Assuming: Distance = 15,000 ft Slope: 3 degrees Height = Distance * sin(Slope) = 785.04 ft. A 3 degree glidepath descends 318 feet per nautical mile. 318 x 2.5 = 795. Sorry, the original calculation was based on bad data. 15,000 feet is not 2.5nm as stated in the original post. 1nm = 6,076ft 2.5nm = 15,190ft Elevation = 15,190 * sin(3-degrees) = 795 ft -- Mike |
Mike wrote:
Steven P. McNicoll wrote: "Mike" wrote in message . .. Using trigonometry, I get ~ 785ft 2.5 miles out from the touch down zone, so your method is pretty accurate. Here's my calculation: Assuming: Distance = 15,000 ft Slope: 3 degrees Height = Distance * sin(Slope) = 785.04 ft. A 3 degree glidepath descends 318 feet per nautical mile. 318 x 2.5 = 795. Sorry, the original calculation was based on bad data. 15,000 feet is not 2.5nm as stated in the original post. 1nm = 6,076ft 2.5nm = 15,190ft Elevation = 15,190 * sin(3-degrees) = 795 ft Sorry for the double post. Last send just "hung" so I resent thinking it didn't send the first time. -- Mike |
Mike wrote:
Steven P. McNicoll wrote: "Mike" wrote in message . .. Using trigonometry, I get ~ 785ft 2.5 miles out from the touch down zone, so your method is pretty accurate. Here's my calculation: Assuming: Distance = 15,000 ft Slope: 3 degrees Height = Distance * sin(Slope) = 785.04 ft. A 3 degree glidepath descends 318 feet per nautical mile. 318 x 2.5 = 795. Sorry, the original calculation was based on bad data. 15,000 feet is not 2.5nm as stated in the original post. 1nm = 6,076ft 2.5nm = 15,190ft Elevation = 15,190 * sin(3-degrees) = 795 ft The TCH is 46 feet, so the G/S is 842 feet about TDZ at 2.5 miles from the threshold. |
M wrote:
I don't understand your calculation. At 2.5 miles from the touch-down zone (assuming that's what it is), the GS should be about 750 feet above the touch-down zone elevation. The pilot was way below the glideslope. 3 degree G/s = 318.44 feet per mile. 2.5 (318.44) + 46' TCH = 842 feet. |
"Sam Spade" wrote in message news:A%Slg.179411$bm6.90388@fed1read04... 3 degree G/s = 318.44 feet per mile. 2.5 (318.44) + 46' TCH = 842 feet. All these calculations assume the full ILS was used. The narrative refers to a 376' minimum altitude, which was the localizer MDA at the time of the accident. |
"Sam Spade" wrote in message news:A%Slg.179411$bm6.90388@fed1read04... 3 degree G/s = 318.44 feet per mile. 2.5 (318.44) + 46' TCH = 842 feet. All these calculations assume the full ILS was used. The narrative refers to a 376' minimum altitude, which was the localizer MDA at the time of the accident. I doubt anyone knows whether he was using LOC or ILS minimuma. The NTSB doesn't even understand the concepts: "The ILS 36 has a minimum approach altitude of 376 feet above ground level (AGL). The cloud ceiling was at 500 feet AGL. After the accident, the ILS 36 was taken out of service to be tested. It was flight checked on December 24, 1997, with no anomalies found." What does "minimum approach alitude" refer to? What does "376 feet above ground level" refer to? If the field office investigator can't sort oout MDA, DA, and HAT, I don't expect to figure out much about his or her's view of how the approach was being flown. |
"Sam Spade" wrote in message ... I doubt anyone knows whether he was using LOC or ILS minimuma. The NTSB doesn't even understand the concepts: "The ILS 36 has a minimum approach altitude of 376 feet above ground level (AGL). The cloud ceiling was at 500 feet AGL. After the accident, the ILS 36 was taken out of service to be tested. It was flight checked on December 24, 1997, with no anomalies found." What does "minimum approach alitude" refer to? It could only be an MDA. What does "376 feet above ground level" refer to? At the time of this accident 440 MSL was the MDA for the S-LOC 36, that's 376 feet above the TDZE of 64 feet. |
"Sam Spade" wrote in message ... I doubt anyone knows whether he was using LOC or ILS minimuma. The NTSB doesn't even understand the concepts: "The ILS 36 has a minimum approach altitude of 376 feet above ground level (AGL). The cloud ceiling was at 500 feet AGL. After the accident, the ILS 36 was taken out of service to be tested. It was flight checked on December 24, 1997, with no anomalies found." What does "minimum approach alitude" refer to? It could only be an MDA. How do you conclude that? A decision altitude is a minimum approach altitude, too, in a broad use of a term that lacks any official definition. Besides, no one has any way of determining whether the pilot was flying the LOC or ILS profile. What does "376 feet above ground level" refer to? At the time of this accident 440 MSL was the MDA for the S-LOC 36, that's 376 feet above the TDZE of 64 feet. Yes, but "above ground level" is a term of ignorance. Above ground level at the crash site, at the runway, or at the DA point, or along the entire length of the final approach segment where the LOC DMA could resonably apply? |
Sam Spade wrote:
Yes, but "above ground level" is a term of ignorance. Above ground level at the crash site, at the runway, or at the DA point, or along the entire length of the final approach segment where the LOC DMA could resonably apply? MDA |
"Sam Spade" wrote in message news:A5Vlg.179419$bm6.137774@fed1read04... How do you conclude that? A decision altitude is a minimum approach altitude, too, in a broad use of a term that lacks any official definition. The term would be "decision height" in the US, not "decision altitude". It's an MDA because nothing else fits. The DH (Decision Height, the height at which a decision must be made during an instrument approach where an electronic glideslope is provided to either continue the approach or to execute a missed approach) for the full ILS RWY 36 was 264 MSL, 200' above the TDZE (Touchdown Zone Elevation, the highest elevation in the first 3000' of runway) of 64'. The MDA (Minimum Descent Altitude, the lowest altitude to which descent is authorized on final approach in execution of a standard instrument approach procedure where no electronic glideslope is provided) for the ILS RWY 36 to straight-in localizer minimums was 440 MSL, 376' above the TDZE. Think of an MDA as an altitude to be maintained while a DH is an altitude to be flown through. Besides, no one has any way of determining whether the pilot was flying the LOC or ILS profile. Yes, I already pointed that out. Yes, but "above ground level" is a term of ignorance. Not at all, the term is used quite often in aviation. |
