K21 brake parts
Old June 20th 06, 01:51 PM posted to rec.aviation.soaring
Default K21 brake parts
Does anyone know of an automotive source for the complete brake caliper
Stuart
Old June 20th 06, 11:21 PM posted to rec.aviation.soaring
"Stuart Kinnear" wrote in message
Stuart
Tost Catalog says K21 uses Cleveland wheel . It is reasonable to assume
its also a cleveland brake.
Aircraft Spruce among others sell Cleveland stuff
Ken Reynolds
Old June 21st 06, 09:00 AM posted to rec.aviation.soaring
Stuart
Slightliy of topic, but important.
NEVER use automotive brake fluid for the brakes in gliders!
Automotive brake fluid will destroy the seals.
Peter Nyffeler (Y7 HB-1689)
Old June 21st 06, 10:09 AM posted to rec.aviation.soaring
Stuart
this is in no way off-topic:
BTW, it is not wise to have hydraulic brakes in a glider
to fly upside down: I have experienced twice full loss of
braking action after touch down. :-(
(+49)0711-685-872-44(Fax79)
--Nobelstr.19 Raum 0.030, D-70569 Stuttgart IHR Hoechstleistungsrechnen
--http://www.ihr.uni-stuttgart.de/
Old June 21st 06, 05:19 PM posted to rec.aviation.soaring
Except, of course, in those rare but not non-existant cases where the
brakes were designed around automotive pistons and seals. A good
example is the early (pre-MATCO) Rosenhan drum units used on some 1960s
American gliders.
Old June 21st 06, 05:26 PM posted to rec.aviation.soaring
Another example is the Stemme S10 series, which uses DOT fluid. Stemme uses
a Cleveland 300 caliper with the seals changed from Buna-N to EPDM rubber.
bumper
"Bob Kuykendall" wrote in message
American gliders.
Old June 21st 06, 06:09 PM posted to rec.aviation.soaring
DG also uses brake fluid with a EPDM (ethylene propylene)
O-ring at least on the 800/808. I would check the manual
for each specific model to determine which is used.
Even if you were to change the caliper O-ring to EPDM
you would still need to verify what is used for a seal
in the master cylinder and lines.
bumper
'Bob Kuykendall' wrote in message
roups.com...
gliders!
cases where the
seals. A good
used on some 1960s
American gliders.
Old June 22nd 06, 01:06 PM posted to rec.aviation.soaring
And Duo Discus. In fact most tost calipers and all Tost master
cylinders.
On 21 Jun 2006 17:09:09 GMT, Gary Evans
bumper
groups.com...
gliders!
cases where the
seals. A good
used on some 1960s
American gliders.
Old June 22nd 06, 02:37 PM posted to rec.aviation.soaring
Tost calipers are in fact Cleveland parts with differant
O-rings and I assume the same may be true for their
master cylinders. All of this branding can get confusing.
Being U.S. manufacture replacement parts (except the
EPDM O-rings) can be obtained through retailers like
Aircraft Spruce and the special O-rings through an
industrial supplier such as MSC.
Tost master
cylinders.
bumper
egroups.com...
gliders!
cases where the
seals. A good
used on some 1960s
American gliders.
Old June 22nd 06, 05:06 PM posted to rec.aviation.soaring
Gary is, of course, correct. Couple of additional things to be aware of:
Some of the earlier (pre about 1998) Cleveland caliper aluminum pistons were
not anodized, thus were subject to corrosion. This could be a problem, as
the automotive brake fluid is hygroscopic. Corrosion in the O-ring groove
and piston bore results in brake fluid contamination of the rotor and
resulting loss of brake effectiveness.
For experimental types, Sierra Brass (think that's the name) will bore out
and brass line the caliper bore, a procedure done on old Corvettes and other
cars. Cost in about $80 IIRC. Solves the leakage problem nicely.
all the best,
bumper
"Gary Evans" wrote in message
Tost master
cylinders.
bumper
legroups.com...
gliders!
cases where the
seals. A good
used on some 1960s
American gliders.
Need Peitz Brake Parts - US [email protected] Soaring 0 June 18th 05 04:24 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Cleveland Parking Brake Parts Jeff Home Built 2 October 11th 04 10:38 PM
Cobra Brake Parts or Axle WDM Soaring 1 October 11th 04 05:09 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
