What FARs cover R/C drones?
Old June 25th 06, 02:02 PM posted to rec.aviation.piloting
Default What FARs cover R/C drones?
"Bob Gardner" wrote in message
According to this morning's paper, the FAA has shot down the LA Sherrif's
proposal. Never mind.
http://www.mercurynews.com/mld/mercu...a/14875403.htm
If the sheriff has any balls, he will tell the FAA to pound salt. As long
as the RC plane is flown in view of the pilot, and can see the plane, or any
possible conflict to full scale planes, there is nothing wrong with him
flying his "toy airplane."
Put the burden of proof back on the FAA, to prove the problem. By the time
the FAA investigates, the airplane will be considered obsolete.
Jim in NC
Old June 25th 06, 03:40 PM posted to rec.aviation.piloting
On Sun, 25 Jun 2006 09:02:33 -0400, "Morgans"
wrote in ::
Perhaps this quote from the article has sheriff Baca exercising
prudence and restraint:
The FAA won't authorize the county to use drones until it
investigates the incident to determine whether the sheriff's
Department should face disciplinary action, Brown said.
It begs the question, what sort of disciplinary action is the FAA
authorized to apply in this case? I seriously doubt the FAA can
suspend the airmans certificate of the officer who controlled the
drone.
As long as the RC plane is flown in view of the pilot, and can see the plane, or any
First, I seriously doubt the sheriff assigned an airman to operate the
drone, so it is unlikely there was any real pilot involved its
operation.
Secondly, if I'm not mistaken, the FAA would require a second person
whose sole duty it would be to observe the drone's operation to assure
there would be no conflict with full-size manned aircraft, as is
mentioned in this 25 year old Advisory Circular:
http://www.eoss.org/faa/ac91-57.pdf
ADVISORY CIRCULAR AC 91-57
MODEL AIRCRAFT OPERATING STANDARDS
The sheriff's department intends to operate their drones over
congested urban areas, not at a designated RC field as is usual for RC
model aircraft. If an engine out incident, loss of control, or
structural failure should occur in a densely populated area, citizens
could be injured by the drone.
That said, I wonder if the FAA will share culpability if they should
actually issue a certificate of authorization to the sheriff's
department.
It would also be interesting to know how big a role the firms below
are playing in this drama:
http://www.ga.com/
www.aerovironment.com
www.aurora.aero
www.auvsi.org
www.boeing.com/phantom
www.dfrc.nasa.gov/Research/Erast/erast.html
www.erast.com
www.grc.nasa.gov/WWW/ERAST
www.jpdo.aero
www.lmaeronautics.com
www.is.northropgrumman.com
www.psl.nmsu.edu/uav
www.uav.com/home
www.uav-info.com
www.uavforum.com/
www.uavworld.com
www.ucare-network.org
www.unitealliance.com/
www.uvonline.com www.uvs-international.org
Old June 25th 06, 05:58 PM posted to rec.aviation.piloting
On Thu, 22 Jun 2006 09:42:44 -0700, Randy Aldous wrote:
[snip]
- The Sheriff's Cmdr. apparently doesn't understand the difference
between the RC Models and a UAV.
Agreed. Plus, he's talking about flying these things in ANY area where
other aircraft are certain to be...such as during high visibility crimes
(bank robberies, hostages, etc...). For certain news will want to be in
the area...now suddenly, with no coordination with the FAA, he expects
helicopter crews to see and avoid tiny, 5-lbs craft. That Sheriff seems
pretty nutty to me.
Greg
Old June 26th 06, 02:51 AM posted to rec.aviation.piloting
There is a difference between "UAV" and "Remotely Piloted Vehicle".
The difference was drawn to avoid problems with the SALT II Treaty which
prohibits dropping bombs or launching missiles from UAVs.
Jim Logajan wrote:
difference between the RC Models and a UAV.
Hmmm. If you read some of the useful links your provide (airspace2.doc
seems to have a nice summary) I think you'll find that "UAV" has various
meanings, some of which include RC models, and some of which don't. Is
there a definition of UAV that the FAA uses that is regulatory? My
fundamental question is what FAR(s) would the FAA cite and convince a judge
that the Sheriff was in violation of?
http://www.house.gov/transportation/...29-06memo.html
http://www.acq.osd.mil/uas/docs/airspace2.doc
http://www.politechbot.com/2006/03/2...llance-in-the/
http://www.rcgroups.com/forums/archi.../t-358461.html
Great links; thanks. They seems to confirm my suspicion that the FAA is
sending confusing signals.
Old June 26th 06, 02:33 PM posted to rec.aviation.piloting
"Larry Dighera" wrote in message ...
The FAA does not 'require' any observers or assistants.
There is also no requirement to fly at 'a designated rc field.'
Old June 26th 06, 03:14 PM posted to rec.aviation.piloting
"Greg Copeland" wrote in message news
[snip]
pretty nutty to me.
Greg
New 'copters are required to remain a certain altitude above any 'event', and these 'tiny' aircraft will most likely not
be over a couple hundred feet AGL. The cops would be talking to the cops 'copter if present for coordination purposes...
Old June 26th 06, 03:17 PM posted to rec.aviation.piloting
On Mon, 26 Jun 2006 13:33:59 GMT, ".Blueskies."
wrote in
While you are correct, there is no mandatory observer *requirement*
contained within AC 91-57, neither does it mention the county's
necessity to obtain FAA authorization to operate drones. Here's what
it does say about observers:
1. PURPOSE. This advisory circular outlines, and encourages
voluntary compliance with, safety standards for model aircraft
operators.
3 0 OPERATING STANDARDS.
d. Give right of way to, and avoid flying in the proximity of,
full-scale aircraft. Use observers to help if possible.
So, it would appear that the FAA is operating under different
authority in this case.
True.
However, have you ever operated a gasoline powered RC model over a
large crowed of people, or even over a congested area of urban
population? Of course not; you seek a safe location that poses less
hazard to the public.
  #28
Old June 26th 06, 04:53 PM posted to rec.aviation.piloting
wrote in
operators.
True.
Only reasonable people think this way, and if the AMA (Academy of Model Aeronautics) member wants to be insured, then
they will operate the aircraft per the AMA safety code. If insurance is available or liability is somehow limited, then
the operator would not need to be as concerned - congested area really doesn't mean anything. I was wondering why the
sheriff was requesting some sort of blessing from the FAA.
Does anyone remember when the wacko flew the RC plane into the (I think Goodyear) blimp?
  #29
Old June 26th 06, 10:06 PM posted to rec.aviation.piloting
On Mon, 26 Jun 2006 15:53:05 GMT, ".Blueskies."
wrote in
Are you implying that the AMA insures it's members' RC operations
provided they are in compliance with the AMA Safety Code?
Such a liability-limited RC aircraft operator wouldn't need to be
concerned about operating over a crowed of people, unless s/he felt a
moral obligation to refrain from maiming his fellow citizens in the
event of loss of control.
Doesn't operating an RC aircraft over people mean that the probability
of hitting someone with it is substantially increased over the
probability when operating over unpopulated land?
I was wondering why the sheriff was requesting some sort of blessing from the FAA.
I wasn't aware sheriff Baca was requesting anything from the FAA.
Where did you find that information?
Why?
  #30
Old June 26th 06, 10:27 PM posted to rec.aviation.piloting
wrote in
Uh, yes, this is the primary reason many folks join the AMA...
Yes, and that is the point, if the person is not concerned about the crowd, they can fly over it with no legal issues,
until something goes wrong or someone complains about 'noise'.
They said the situation would be "cleared up' soon...
"Sheriff's officials described the controversy as a misunderstanding that soon will be cleared up."
Why?
No regulations followed the incident - it was handled using currently existing laws and the 'wacko' was jailed.
Cessna Glare Shield Cover Al Gilson Owning 4 March 21st 06 03:04 AM
Musings on SOARING cover photos Ray Lovinggood Soaring 19 March 8th 05 02:30 AM
Minor changes to USA FAR's 2005 Burt Compton Soaring 0 December 20th 04 10:24 PM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 04:20 AM
Full airplane cover? Robert M. Gary Piloting 4 May 5th 04 04:33 PM
