You have positive indication of ground track based on needle
position, direction of movement, and rate of movement. Maybe, if the PT fix is based on navaid. but the information you receive is imprecise and will vary with the distance from the navaid. If the fix is an intersection, you don't have even that. A centered needle is much easier to read. Plus, you still run this risk with the procedure you've described, when you go out and do the 45-180 PT. You're only going outbound for a minute, in the fattest part of the protected area. And the issue of a late turn over the holding fix is missing. I'll bet you five bucks the difference is minimal. Well, no ****. The safety-conscious choices we make every day don't matter most of the time. We put up with a bit of inconvenience to give us an extra margin of safety for the extreme situations. |
(C Kingsbury) wrote
Needle position and movement trend will indicate what you're dealing with. At best I will grant you there is a theoretical reduction of precision of measuring the x-wind component, but I suspect in most cases the difference in the two approaches will be nugatory. In most cases, you can just fly IMC without talking to anyone and it's fine. Yes, and we allow people to drive 55MPH, despite the fact that some people get killed doing just that. Which means that sometimes it's NOT safe to drive 55, even when that's the speed limit. I agree that final approach segments often demand higher precision than what "the rules" require. My favorite is the ILS 5 to Lawrence, MA, which ought to be called the cannonball run: http://204.108.4.16/d-tpp/0409/00654I5.PDF Clearly I am missing something here. Plese explain. Michael |
#24
"C Kingsbury" wrote in message
om... I agree that final approach segments often demand higher precision than what "the rules" require. My favorite is the ILS 5 to Lawrence, MA, which ought to be called the cannonball run: http://204.108.4.16/d-tpp/0409/00654I5.PDF Hm, that's one of my favorite approaches to practice in LIFR. Flying it to PTS standards looks safe to me. Is there a hazard I'm failing to appreciate? --Gary |
#25
"Gary Drescher" wrote in message news:9wn1d.296945$8_6.234657@attbi_s04...
"C Kingsbury" wrote in message om... I agree that final approach segments often demand higher precision than what "the rules" require. My favorite is the ILS 5 to Lawrence, MA, which ought to be called the cannonball run: http://204.108.4.16/d-tpp/0409/00654I5.PDF Hm, that's one of my favorite approaches to practice in LIFR. Flying it to PTS standards looks safe to me. Is there a hazard I'm failing to appreciate? No, not if flown properly. But, with the obstacles where they are, the margin for error (particularly right around GRAPS where the smokestacks are) is definitely reduced. I probably would not wait for a full-scale right deflection before missing this approach if the crosswinds were messing with my head. It might be interesting sometime on a VFR day to fly this with the localizer on its last dot (just barely not pegged) and also on the last dot of the glideslope, just to see how much room that really leaves you. Maybe I'll try it in Flight Simulator tonight just for kicks. Best, -cwk. |
#26
(Michael) wrote in message . com...
(C Kingsbury) wrote Needle position and movement trend will indicate what you're dealing with. At best I will grant you there is a theoretical reduction of precision of measuring the x-wind component, but I suspect in most cases the difference in the two approaches will be nugatory. In most cases, you can just fly IMC without talking to anyone and it's fine. Well, not around Boston you can't. But that's neither here nor there, and my point remains. If you were to draw a bounding rectangle of the airspace used by the two different procedure turn flightpaths, they may not be identical, but I find it difficult to imagine a case where the differences are actually significant from a perspective of utility or safety. And again, it is clear beyond any argument that the full procedure increases the pilot's workload, which in my view is among the surest ways to reduce real safety. At best, the full procedure might provide navigational precision of 5-10% on the inbound leg to the FAF, though I suspect this advnatage washes out during the final approach segment, unless it is very short, or nonexistent, as with a beacon on the field, in which case the minimums are so high it makes little difference anyway. My unqualified suspicion is that a lot more pilots, especially lightplane single-pilot IFR ones, get into trouble with basic spatial disorientation, than with modest navigational errors. Truly systematic risk management looks at the effects each optimization has not just on a particular variable, but on all variables. Yes, and we allow people to drive 55MPH, despite the fact that some people get killed doing just that. Which means that sometimes it's NOT safe to drive 55, even when that's the speed limit. Yes, and it doesn't mean that we ought to lower it to 45 everywhere, either. Your point that "I need to get into my head" that just because the rules allow X doesn't mean X is safe smelled more than a bit hyperbolic in this regard. To dismiss the rules completely because there are one or two exceptions is no more intelligent than applying them thoughtlessly in place of common sense. Best, -cwk. |
#27
m... "Gary Drescher" wrote in message news:9wn1d.296945$8_6.234657@attbi_s04... "C Kingsbury" wrote in message om... I agree that final approach segments often demand higher precision than what "the rules" require. My favorite is the ILS 5 to Lawrence, MA, which ought to be called the cannonball run: http://204.108.4.16/d-tpp/0409/00654I5.PDF Hm, that's one of my favorite approaches to practice in LIFR. Flying it to PTS standards looks safe to me. Is there a hazard I'm failing to appreciate? No, not if flown properly. But, with the obstacles where they are, the margin for error (particularly right around GRAPS where the smokestacks are) is definitely reduced. True, but the obstacles are still well beyond both the horizontal and vertical boundaries of the glideslope. I probably would not wait for a full-scale right deflection before missing this approach if the crosswinds were messing with my head. Yup, PTS standards call for no more than 3/4 deflection. I'd always go missed in IMC if I were off by that much. It might be interesting sometime on a VFR day to fly this with the localizer on its last dot (just barely not pegged) and also on the last dot of the glideslope, just to see how much room that really leaves you. Maybe I'll try it in Flight Simulator tonight just for kicks. Cool, I'll give that a try too. --Gary |
#28
Yup, PTS standards call for no more than 3/4 deflection. I'd always go missed in IMC if I were off by that much. If you ever shoot the VOR-B at LVJ, half scale deflection (5-6 degrees) and a VOR that's off by 2 degrees (well within the acceptance criteria) can be enough to kill you. Michael |
#29
"Michael" wrote in message
om... "Gary Drescher" wrote Yup, PTS standards call for no more than 3/4 deflection. I'd always go missed in IMC if I were off by that much. If you ever shoot the VOR-B at LVJ, half scale deflection (5-6 degrees) and a VOR that's off by 2 degrees (well within the acceptance criteria) can be enough to kill you. Hm, the VOR could even be off by 6 degrees (for an in-air check) and still be legal. In that case, even one dot of deflection could be lethal on that approach. --Gary |
#30
Vectored past the localizer | Doug | Instrument Flight Rules | 28 | December 30th 03 07:05 PM |
IFR Routing Toronto to Windsor (CYTZ - CYQG) | Rob Pesan | Instrument Flight Rules | 5 | October 7th 03 01:50 PM |
Established on the approach - Checkride question | endre | Instrument Flight Rules | 59 | October 6th 03 04:36 PM |
