I've noticed that the windscreen and canopy on my RV-6 has developed a haze
on its exterior. The history of the canopy is that the canopy was manufactured about 7 years ago, with the airplane first flying about 5 years ago. The airplane has always been hangared (other than the occasional overnight stay somewhere), and has been treated properly during its life. My cleaner of choice is Plexus, which Aircraft Spruce and several other outlets sell for aircraft canopies. The only things I can imagine that could have caused the haze on the canopy is either the plexus, exposure to corvis oil (the smoky stuff) at airshows, or some sort of airborne contaminant in my hangar (e.g. a neighbor spray painting). For what it is worth, the canopy doesn't have any scratches, so I probably don't need an aggressive abraisive cleaner. The bottom line is that I'm interested in removing this haze layer. Any recommendations? Thanks, KB |
Actually you do need an 'aggressive abrasive cleaner'...
Whatever is attacking the acrylic is bonded to the surface.. You need to grind that away and then polish the new surface... cheers ... denny |
In article .com,
"Denny" wrote: Actually you do need an 'aggressive abrasive cleaner'... Whatever is attacking the acrylic is bonded to the surface.. You need to grind that away and then polish the new surface... Micro Mesh? |
![]() john smith wrote: Micro Mesh? And elbow grease... |
Kyle Boatright wrote:
The bottom line is that I'm interested in removing this haze layer. Any recommendations? Know any local classic car / hot rod die-hards? Those folks are often very familiar with all kinds of cool products to restore mechanical things. Chances are they will know of products and techniques to get your canopy crystal clear and sparkling. In some cases, they work with parts that are very difficult, or even impossible, to replace. |
It would be interesting to know if there are any sources of chemical vapors
nearby that could have caused the hazing. If they are strong enough to damage your canopy, perhaps they are also a hazard to metals and your body. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel Suppose you were an idiot... And suppose you were the president... But I repeat myself. -- with apologies to Mark Twain. 'The first rule of intelligent tinkering is save all the pieces.' - Aldo Leopold 'Hockey is a sport for white men. Basketball is a sport for black men. Golf is a sport for white men dressed like black pimps.' - Tiger Woods "Denny" wrote in message oups.com... Actually you do need an 'aggressive abrasive cleaner'... Whatever is attacking the acrylic is bonded to the surface.. You need to grind that away and then polish the new surface... cheers ... denny |
You can also use a product called Mirror Glaze. It comes in two flavors,
one in a white squeeze bottle has a mild abrasive for scratch removal. Another flavor comes in a blue/grey bottle and is for regular cleaning. You spread it on, let it dry and buff it off. Lots of work, but works well. http://www.meguiars.com/?home-clear-...lastic-Cleaner Good Luck... Guy "tony roberts" wrote in message news:nospam-D71DE8.21522029062006@shawnews... Hi Kyle I don't recall the name of the product but it is easy to find - most Harley dealers carry it and it is for removing the haze and small scratches from motorbike windshields. It comes in a white plastic squeeze bottle with red writing. They make one for haze and two for different levels of scratches. Awesome stuff - takes a fair amount of work but the results on my old windows was excellent. HTH Tony C-GICE -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE In article , "Kyle Boatright" wrote: I've noticed that the windscreen and canopy on my RV-6 has developed a haze on its exterior. The history of the canopy is that the canopy was manufactured about 7 years ago, with the airplane first flying about 5 years ago. The airplane has always been hangared (other than the occasional overnight stay somewhere), and has been treated properly during its life. My cleaner of choice is Plexus, which Aircraft Spruce and several other outlets sell for aircraft canopies. The only things I can imagine that could have caused the haze on the canopy is either the plexus, exposure to corvis oil (the smoky stuff) at airshows, or some sort of airborne contaminant in my hangar (e.g. a neighbor spray painting). For what it is worth, the canopy doesn't have any scratches, so I probably don't need an aggressive abraisive cleaner. The bottom line is that I'm interested in removing this haze layer. Any recommendations? Thanks, KB |
Ok Kyle,
The first thing to do is to not panic and jump into a mechanical repair involving material removal, sanding, polishing. The first thing I would do is to get a bit of METHANLOL and see if the film is removable. Methanol doesn't hurt acrylic in the least. If that doesn't work, ues V&PM Naptha, Use soft cotton to clean it, I use flannel from Walmart. My experience is that the stuff is usually on the INSIDE of the bubble and are products fron the sublimation of the plastics in the interior of the airplane. DEFINATELY solvent wipe stuff before you get out the polishing compounds. Another thing that few bother with is to use a canopy cover to keep dust off the canopy. Most dust is pretty acidic, remember acid rain and car paint jobs. Get a big soft piece of flannel at Walmart and keep it on the plane when you arent flying it. Plexiglass generates static electric charges and pulls dust out of the air when it sits. Oh Yeah, I make canopies and acrylic stuff for a day job, so you can take this for what it is worth -- Have a great day Scott "Kyle Boatright" wrote in message news ![]() I've noticed that the windscreen and canopy on my RV-6 has developed a haze on its exterior. The history of the canopy is that the canopy was manufactured about 7 years ago, with the airplane first flying about 5 years ago. The airplane has always been hangared (other than the occasional overnight stay somewhere), and has been treated properly during its life. My cleaner of choice is Plexus, which Aircraft Spruce and several other outlets sell for aircraft canopies. The only things I can imagine that could have caused the haze on the canopy is either the plexus, exposure to corvis oil (the smoky stuff) at airshows, or some sort of airborne contaminant in my hangar (e.g. a neighbor spray painting). For what it is worth, the canopy doesn't have any scratches, so I probably don't need an aggressive abraisive cleaner. The bottom line is that I'm interested in removing this haze layer. Any recommendations? Thanks, KB |
![]() "tony roberts" wrote in message news:nospam-D71DE8.21522029062006@shawnews... Hi Kyle I don't recall the name of the product but it is easy to find - most Harley dealers carry it and it is for removing the haze and small scratches from motorbike windshields. It comes in a white plastic squeeze bottle with red writing. They make one for haze and two for different levels of scratches. Awesome stuff - takes a fair amount of work but the results on my old windows was excellent. HTH Tony C-GICE This was the ticket! We have a brand new Harley Dealership nearby and they carried their cleaner/polish and their plain 'ol cleaner. The cleaner/polish really did the job. It took a minute or two to clean each 6"x6" area of the canopy. Afterwards, I followed up with the cleaner, which is inexpensive ($3.95/bottle) and does just as good a job as the Plexus I normally use at a fraction of the price. I'd say the pump spray bottle from the Harley shop has 2x the cleaner in it as an aersol can of Plexus, which costs ~$8.00 or so. The cleaner/polish was $5.95/bottle. Highly recommended for slightly hazy plexi... KB |
Haze domes | Roger Kelly | Soaring | 8 | June 26th 05 04:29 PM |
OOPS! Got contact cement on the windshield | Mike Rapoport | Owning | 12 | November 13th 04 11:13 PM |
Windshield Antenna Kits | Scrabo | Piloting | 2 | July 12th 04 04:58 PM |
windshield wipers | tony roberts | Owning | 8 | June 1st 04 02:45 AM |
Arrgh! I may have scratched my windshield! | Peter R. | Owning | 7 | April 28th 04 07:58 AM |
