Puget Sound -- Eugene, OR Routing Q
Old June 29th 06, 04:36 AM posted to rec.aviation.ifr
Default Puget Sound -- Eugene, OR Routing Q
Last weekend I flew IFR Paine to Eugene. I filed V23, but was cleared
to the west along OLM V165 UBG V495 CVO EUG. Similar routing for the
return flight. I asked each controller (except Seattle Approach) for
vectors EUG direct when able, but each controller said they needed to
keep me on the airway through either Portland or Cascade Approach's
airspace.
Question: is this a typical routing?
TIA,
Ethan
Old June 29th 06, 05:00 AM posted to rec.aviation.ifr
Yes. You will get V-27 southbound and V-23 northbound, whether you like it
or not. I used to run packages between Boeing and Oakland every night and I
learned this lesson early.
Bob Gardner
airspace.
TIA,
Ethan
Old July 5th 06, 05:53 PM posted to rec.aviation.ifr
M[_1_]
From Seattle area going south bound (or northbound into Seattle area
from Oregon/CA) you almost always have to funnel over Olympia. South
of OLM Seattle center will let you cut corners as long as you're above
5-6000 or so.
airspace.
TIA,
Ethan
Jeppesen flitepro=no sound Angelo Campanella Simulators 0 March 27th 06 09:54 PM
The price of gas C J Campbell Piloting 167 June 4th 04 06:06 PM
How Aircraft Stay In The Air Sarah Hotdesking Military Aviation 145 March 25th 04 05:13 PM
Puget Sound TFRs reduced in size - charted here David H Owning 3 January 10th 04 06:01 AM
Puget Sound TFRs reduced in size, turned into National Security Areas C J Campbell Piloting 4 January 10th 04 06:01 AM
