SAC ILS "ADF Required" Info
Old June 22nd 06, 06:09 PM posted to rec.aviation.ifr
Default SAC ILS "ADF Required" Info
Steven P. McNicoll wrote:
Sam Spade wrote:
Oh very well. But, this is not a charting error.
"ADF REQUIRED" on charts for IAPs that do not require ADF is not a
charting error?
If it is an error at
all, it is a source document error. That is not in NACO's purview no
matter how much you may wish it to be.
It appears the FAA wants notice of charting errors reported to NACO.
Do you understand that?
Yes, far better than you do.
  #62
Old June 22nd 06, 06:12 PM posted to rec.aviation.ifr
Jose wrote:
Perhaps that note is an error.
Perhaps. I wonder where notification of that possible error should be
addressed?
http://avn.faa.gov/index.asp?xml=nfpo/qoab
  #63
Old June 22nd 06, 06:23 PM posted to rec.aviation.ifr
Impossible, and you're welcome.
  #64
Old June 22nd 06, 06:50 PM posted to rec.aviation.ifr
It's becoming increasingly apparent that you are delusional.
  #65
Old June 28th 06, 11:57 AM posted to rec.aviation.ifr
"Jose" wrote in message
. com...
That remains to be seen. Let's hear what Mr. Harmer has to say.
I received a response from Mr. Harmer. ADF is required to identify the FAF.
Apparently marker beacons cannot be used to determine position along track.
His response and my reply follow.
Paul
I will try to clarify this issue because it is more than a bit confusing.
When a procedure isn't absolutely clear on what equipment is required to
fly the approach then we have to add notes as necessary so the pilot knows
exactly what equipment is needed. For this particular approach the VOR
and
NDB are used for the procedure and are depicted in the plan view. Their
close physical proximity as depicted on the planview could lead a pilot to
believe that he could do the hold in lieu pattern using the VOR, but that
is not correct. The VOR is only used on the procedure as a feeder and a
missed approach holding fix.
Now to try and explain. This approach has 2 parts, the full ILS and then
the LOC only which must be addressed separately for clarification. There
are 2 IAFs identified on this approach, first the hold in lieu at EXECC
LOM
and secondly the NoPT segment from COUPS INT to EXECC LOM; and 1 feeder
route, SAC VORTAC to EXECC LOM. When an aircraft is shooting the full ILS
approach from COUPS INT it does not require the use of ADF to fly the
final
(the precision FAF is based on an altitude not the LOM) or missed approach
because 2 missed options are provided. But should the glideslope fail and
he has to transition to the LOC only approach, or when flying the LOC only
approach, then ADF is required to identify the FAF. The missed approach
provides the pilot with 2 possible holding options either going to the SAC
VORTAC or the EXECC LOM to hold so ADF required doesn't apply. Mr
McNicoll
is correct is stating that he is allowed to substitute GPS for ADF in
certain circumstances. However we have to consider the least possibly
equipped aircraft shooting this approach and that requires that we place
an
"ADF REQUIRED " note on this approach.
I hope this will answer the question for Mr McNicoll. Feel free to
contact
us anytime
Don Harmer
Air Traffic Organization-W
Western Flight Procedures Team
Lead, Western Pacific Area (AJW-324)
405-954-9930
Dear Mr. Harmer,
I received your response through Paul Spadero explaining why ADF is required
on the SAC ILS or LOC RWY 2 approach. You indicated that ADF is required to
identify the FAF when flying the LOC only approach. The FAF is EXECC LOM,
why must the pilot use ADF to identify station passage of the Compass
Locator? Why can't the Outer Marker be used to identify EXECC?
Steven P. McNicoll
De Pere, WI
  #66
Old June 29th 06, 09:28 PM posted to rec.aviation.ifr
Mr
McNicoll
an
Why not "ADF OR GPS required"?
Jose
  #67
Old June 29th 06, 11:17 PM posted to rec.aviation.ifr
Jose wrote:
Mr
McNicoll
an
Jose
Good question. I'm sure that will be an option in the not too distant
future, but right now you can't mix and match ground-based systems with
GPS on published procedures due to TERPS requirements. That's another
set of guidelines that allows substitution with GPS in some
circumstances, and already you may have seen NOTAMS stating "Procedure
NA except for IFR certified GPS equipped aircraft" where the NOTAM
specifically allows substitution for DME or ADF ancillary equipment.
John
  #68
Old June 29th 06, 11:28 PM posted to rec.aviation.ifr
On 06/29/06 15:17, JPH wrote:
Jose wrote:
Mr
McNicoll
an
Jose
Huh? The AIM has a complete section called "Use of GPS in lieu of
ADF and DME"
That's another
John
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #69
Old June 30th 06, 02:19 AM posted to rec.aviation.ifr
om...
No need for that, GPS can substitute for ADF in this case anyway. But why
not "ADF REQUIRED FOR LOC RWY 2"?
  #70
Old June 30th 06, 02:23 AM posted to rec.aviation.ifr
"JPH" wrote in message
news:TjYog.11140$f76.5031@dukeread06...
GPS on published procedures due to TERPS requirements. That's another set
of guidelines that allows substitution with GPS in some circumstances, and
already you may have seen NOTAMS stating "Procedure NA except for IFR
certified GPS equipped aircraft" where the NOTAM specifically allows
It's an option now. See AIM para 1-1-19.f.:
http://www.faa.gov/atpubs/AIM/Chap1/aim0101.html#1-1-19
Help! - Wooden prop - any info? G0MRL Aviation Marketplace 1 February 13th 06 03:14 PM
Seeking Northrop Gamma info Dillon Restoration 3 December 12th 05 04:45 AM
Helicopter Physics info online anywhere?? [email protected] Rotorcraft 4 April 24th 04 04:18 PM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
