non-vectored NDB IAF
Old September 16th 04, 02:03 PM
Gary Drescher
"C Kingsbury" wrote in message
m...
It might be interesting sometime on a VFR day to fly this with the
localizer on its last dot (just barely not pegged) and also on the
last dot of the glideslope, just to see how much room that really
leaves you. Maybe I'll try it in Flight Simulator tonight just for
kicks.
I tried it on FS2004. At full deflection, you certainly come close to a
smokestack, but you don't hit it. (Of course, the FS2004 scenery shouldn't
be trusted for real-world purposes, though it looks correct here.)
--Gary
  #33
Old September 16th 04, 02:52 PM
Gary Drescher
"Michael" wrote in message
m...
I wonder how many of those CFIT accidents where the aircraft was
inexplicably off the FAC are actually a result of this.
I also don't think it's such a big deal anymore, because nobody I know
flies IFR without GPS, be it IFR certified or not.
I do. There's no GPS in most of the IFR planes I rent (but they do have VFR
LORAN).
--Gary
  #34
Old September 17th 04, 04:18 PM
Michael
"Gary Drescher" wrote
Hm, the VOR could even be off by 6 degrees (for an in-air check) and still
be legal. In that case, even one dot of deflection could be lethal on that
approach.
Quite true. The scary part is I almost killed myself and a student
that way. We had a lesson one morning, I called for a briefing, and
there were two airports reporting IFR conditions. LVJ was the closer
one, so we went there (I'm a big believer in training in actual
whenever possible, even if it adds time to the lesson - owners tend to
be OK with that since they're just paying for gas) and the only
approaches were VOR and GPS. The plane had no GPS, but the VOR was
fine.
We got about 30 minutes of actual on the way out, but then the weather
started breaking up. Still, by the time we broke out we were being
vectored to the FAC so I had the student put the hood on and continue.
He was doing a fairly credible job of it (the air was bumpy) meaning
he was well within PTS standards at all times. And so I sat there and
watched as he performed an approach that should have been fine - and I
saw us head for a tower. Had we been in IMC, there is an excellent
chance I would not be here.
After this, we performed a VOR check in the air on this VOR. The VOR
showed 5 degrees off. In other words, it was legal. We later checked
it in the air on another VOR. On that one, it showed 2 degrees off.
Michael
Vectored past the localizer Doug Instrument Flight Rules 28 December 30th 03 07:05 PM
IFR Routing Toronto to Windsor (CYTZ - CYQG) Rob Pesan Instrument Flight Rules 5 October 7th 03 01:50 PM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
