An odd clearance...can anyone explain?
Old September 16th 04, 01:09 AM
Ron Rosenfeld
On Wed, 15 Sep 2004 21:00:21 GMT, zatatime
What is the definition of nearby? Can I file to any VOR or
intersection, say, within 20 miles of my departure point? Do I have
to actually file starting with a fix, or can I just file from any
point on an airway? Given the busy nature of the NY area, what are my
odds of getting a clearance using a fix further away? (That last one
may just come from experience). A better understanding of this sure
will help me pick better routes in the future since I'd always file to
the closest, even if I had a crappy route to my destination.
I know of no restrictions such as question.
If I am flying from, let us say, KEPM to KASH, I will either file (and be
cleared), as my initial fix, BRNNS (140 NM) or ENE (178 NM). And I could
just as easily file direct to KASH. I don't because of overwater
considerations.
And those clearances were issued when I was filing /A.
In a non-radar environment, though, different considerations apply.
So far as the NY area, close to NYC (and I would guess in most busy
airspaces), random routes are not commonly approved. I would not expect to
depart KFRG cleared direct ETX, for example. There are also altitude
restrictions on certain routings.
However, you might be able to get something like KBDR direct ACK. And if
over water distance were not a consideration, that's how I would file.
--ron
Old September 16th 04, 01:51 AM
Stan Gosnell
zatatime wrote in
You can file to any fix you can navigate to. I regularly file to and from
lat/lon coordinates, far from any airway. It's easier for ATC if you file to
a fix they have in the database, but it's not absolutely essential. You do
need to be able to navigate to the fix in the event of radar failure.
You may not be cleared to the fix you filed to, and perhaps won't get the
route you filed. But you can *file* what you like.
Regards,
Stan
Old September 16th 04, 03:32 PM
john smith
Reading Don Brown's AvWeb column, filing to lat/lon's is causes problems.
Old September 16th 04, 04:35 PM
Steven P. McNicoll
"john smith" wrote in message
He's mistaken.
Old September 16th 04, 06:56 PM
Robert M. Gary
"Steven P. McNicoll" wrote in message ink.net...
"Andrew Gideon" wrote in message
online.com...
What had you filed and what was the actual clearance?
How do you differentiate a VOR from an airport when filing? What is
the difference between SAC and SAC, what is the difference between SMO
and SMO, etc.
-Robert
Old September 16th 04, 08:44 PM
Steven P. McNicoll
om...
and SMO, etc.
On-field VORs usually have the same identifier as the airport, but not
always. In this case Lancaster Airport is LNS and Lancaster VORTAC is LRP.
It may simply be that the proposal strip had LNS..LRP..ETX... as the route
and the controller just read it as written.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
