Airport Power
Old July 1st 06, 12:19 PM posted to rec.aviation.owning
Default Airport Power
David Lesher wrote:
"Kyle Boatright" writes:
I need a trickle of electrical power about a dozen times a year in my
hangar. I need it for my 125 watt preheater if I'm taking an early-
morning flight in the winter, and will use it for a .25A trickle charger
if I've let the aircraft sit for more than a week or two.
Well, you can handle the trickle with a solar array of some kind.
I agree. If you can mount the solar panel so that it has about the same
angle from horizontal as your latitude, and so that you can get to it
occasionally to wipe the dirt off of it, it will work a little better.
125W @ 8H = 1KWH
At 13.8 VDC; 72 Ah-H w/100% efficiency.
Say 150 Ah-H at real world inverter levels.
In a later post, David said he only needed to run the heater for about
4 hours. I haven't measured any of them, but I can believe that a
really cheap inverter might only be 50% efficient. Tripp Lite claims
that their 150 W inverter is about 89% efficient at full load [1], and
another site [2] gives about the same numbers.
So, to get 125 W of AC to the heater, the inverter will need about 140 W
of DC input, or about 12.2 A at 11.5 V. (This is an average; the battery
will start out at around 12.5 V and shouldn't be run much lower than
10.5 V.) This is 48.8 Ah at the four hour rate. Powersonic [3] claims
that their 60.0 Ah/20hr gel-cell battery will do 48.0 Ah at the 4 hour
rate. Flooded batteries often have a "reserve capacity" rating, which
is the number of minutes they will run a 25 A load. Since your load is
about half of this, you would look for one with a 120 minute or better
reserve capacity rating. Interstate [4] says their SRM-24 will support
a 15 amp load for 4.6 hours, so that would work.
But wait! All of those ratings are at "room" temperature - 20 C for the
gel-cell and 27 C for the flooded battery. The curves for the gel-cell
battery show that its capacity at 0 C is about 90% of the 20 C capacity,
and its capacity at -20 C is about 65% of the 20 C capacity. So, at 0 C
you need a gel-cell with a nominal rating of 66.7 Ah/20hr or better, and
at -20 C you need one with a nominal rating of 92.3 Ah/20hr or better.
The flooded battery doesn't have curves like this, but looking at the two
cranking amp ratings, the rating at -18 C is 80% of the rating at 0 C.
If you ass-u-me that it follows a similar curve as the gel cells, the
SRM-24 might still cut it at 0 C (3.9 hours), but for -20 C, you
probably need to move up to the SRM-29 (6.4 hours at 27 C, derated to
4.0 hours at -20 C).
None of these batteries can be taken lightly. The gel-cells will weigh
40 to 70 pounds and the flooded ones will weigh 50 to 60 pounds. If you
have a choice, buy a battery that has a built-in handle. This becomes a
consideration if you're taking the battery home to recharge it every time.
You could put it on the solar panel, but it'd take a long time to charge
back up at 0.25 A - something like 200 hours of full sun, or three weeks
straight if you live in Phoenix.
If you do use a battery and an inverter, keep the wiring as short as
possible, but especially the DC wiring. I would cut off the cigarette
lighter plug that comes with most small inverters and wire the inverter
directly to the battery terminals. Anything that you can do to keep the
battery warm would also help; a plastic battery box that isn't sitting
right on the floor would help. For the extension cord from the inverter
to the heater, use as heavy and as short a cord as you can. It's only
about 1 A at 120 V, but since this electricity is relatively expensive,
you don't want to waste it if you can help it.
Hmm, you could use Qnty 9-10 13.8v batteries in series; 4 Ah-H
Gel-Cells are not all that pricy. Looks to be ~~$15 each for 5Ah-H.
Then a kludge to parallel them when charging off the array.
This would work too; you don't lose anything in the inverter, but as you
noted, it may be harder to control. With one big battery and an
inverter, you can use a regular 120 V AC lamp timer to turn the heater
on when you want it. With this setup, you'd probably use something like
a spring-wound timer with a switch or relay rated for DC.
For ten batteries at an average voltage of 11.5 V each, you'd need
1.09 A from each battery for four hours, or 4.35 Ah/4hr. This is at
least a 7.0 Ah/20hr nominal gel-cell at 20 C or 0 C, or a 9.0 Ah/20hr
nominal at -20 C. These batteries together will all weigh 60-65 pounds,
but at least you can carry them two or three at a time instead of all
at once. It would still take a few weeks to charge all of these
batteries off of an 0.25 A solar panel.
Either gel-cell option will probably cost around $150 for the batteries;
the flooded battery option will probably cost around $80. The inverter
should be about $30 or so. There are chemistries like NiCd and NiMH that
have higher energy density, i.e. they don't hurt as much when you drop
them on your foot, but they also have much higher dollar density as well.
There are places that sell "solar kits" for cabins and other isolated
applications. They usually have the solar cell(s), charge controller,
mounting hardware, and some cable. Some of them include an inverter;
you get to buy your own batteries for most of them. Googling on "cabin
solar kit" or looking at the ads in "Home Power" magazine are good ways
to find systems like these.
Another possible source of power might be a wind generator, but this
probably wouldn't be too practical unless it's really, really windy
close to the ground; towers are expensive and you probably don't want to
stick it too high up in the air at the airport. Maybe you could put it
down low, by a busy taxiway, and convert prop wash into free juice...
If what you're really after is heat, the best answer is often to burn
the hydrocarbons fairly close to where you want the heat. That probably
wouldn't work very well in this situation, though. I had some other
creative ideas, like a weight on a rope that turned an alternator pulley,
but that turned out to require way too much weight.
Standard disclaimers apply; I don't get money or other considerations
from any of the companies mentioned.
Matt Roberds
[1] http://www.tripplite.com/products/pr...productID=2553
[2] http://www.solar-electric.com/solar_...r_electric.htm
[3] http://www.power-sonic.com/techman.pdf
[4] http://www.interstatebatteries.com/w...uct_marine.asp
Old July 1st 06, 03:04 PM posted to rec.aviation.owning
nrp
Check at Wally World to find batteries with the most AH per dollar.
Garden tractor batteries (about 20 AH) go on sale at like $15 each. As
an alternate, you may even be able to collect used batteries from a car
repair shop. Connect them in series and run the heater from DC to
avoid the losses of an inverter.
You don't even need a full 120 V if the heat demand isn't that high.
Maybe better blankets and say 60 V for 12 hrs would do the job?
Another approach is to use a Dragon heater which requires propane and a
small amoount of 12 V power.
Old July 1st 06, 04:05 PM posted to rec.aviation.owning
The $15/mo is cheap compared to all these battery
solutons--which require implementations using your time
at $0.05/ hour.
I'd guess your heater draws 125 watts when cold, too.
For the next level, figure out a way to turn it on remotely!
Bill Hale who does it with X-10 but is looking for a cell
phone solution!
I'd be surprised if
hangar. I need it for my 125 watt preheater if I'm taking an early-morning
flight in the winter, and will use it for a .25A trickle charger if I've let
The problem is that my T-hangar doesn't have power. One of the other hangar
renters had electrical service pulled to his hangar, and sublets 15A
breakers for $15/month = $180/year, which is a bit much for me, considering
my needs are for a dollar or so of electricity a year.
Any suggestions other than either buying a small generator or paying the
$15/month?
I'm asking because the "power guy" complained last week when I ran a
dropcord to a neighboring hangar for an hour last week to run the trickle
charger...
KB
Old July 1st 06, 08:29 PM posted to rec.aviation.owning
Kyle Boatright
" wrote in message
at $0.05/ hour.
Could be. The point is that I need a little bit 'o power once every once in
a while. As everyone has mentioned, batteries and an inverter are a
solution, but are capital intensive.
The real deal would be to pay the "power guy" a the airport a one time fee
of, say, $50 for my occasional use via drop cord. I inquired about that
once, but he was a pretty big a-hole about it.
There is a way to do it remotely (a pager works), but I have two timers in
series so IF I know I'll be flying on a particular day, I can turn set the
heater to come on once (and for whatever duration I need) during a 14 day
period. Since I work 15 minutes from the airfield, it isn't a huge problem.
phone solution!
KB
Old July 2nd 06, 12:18 AM posted to rec.aviation.owning
David Lesher
"nrp" writes:
repair shop.
All batteries are not created equal. 'Starting' batteries are
ill-suited to deep-cycle service. You can use "marine/RV/cycle"
batteries if available. Note "Gel-Cells" [tm] come in both "float"
and "cycle" versions; you'll want the 2nd.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old July 2nd 06, 03:03 PM posted to rec.aviation.owning
.Blueskies.
" wrote in message
phone solution!
X-10.com has some sort of remote call in box gizmo thingie to do this....
Old July 2nd 06, 06:07 PM posted to rec.aviation.owning
Kyler Laird
You'd attend while using the drop cord, right? And you drive a car to
the airport? 'seems like it'd be a whole lot easier (and less expensive)
to buy a cheapo inverter (because waveforms and noise won't matter to
your heating element) to use from your car.
If you really only need 125W something like this should do the trick.
http://www.target.com/gp/detail.html...sin=B000157TNA
Even a 400W unit costs less than two years at $50.
http://www.target.com/gp/detail.html...sin=B000157TNK
I suspect that once you have one of these you'll find a lot of other
uses for it.
If using your car for power is problematic and you're considering a
generator then consider getting a tug with an electrical system (lawn
tractor) instead. Plug an inverter into that and you'd have a handy
dual-use device. Heck, if you rig it with a nice 12/24V battery
charger, inverter, lights and an air pump you could probably rent it
to others on the field.
--kyler
Old July 2nd 06, 06:35 PM posted to rec.aviation.owning
Ron Rosenfeld
On Thu, 29 Jun 2006 20:56:29 -0400, "Kyle Boatright"
$15/month?
charger...
KB
Kyle,
Where are you located and do you have an unobstructed southern exposure for
solar panels? Could you south facing solar panels on the roof of your
hangar?
In Georgia, to set up a reliable solar system that would meet the
requirements you outlined above will probably cost about $500. Maintenance
would be to check the battery water at appropriate intervals (a few times a
year).
It might be less expensive to run a line from your neighbor's hangar, and
pay him a few bucks a month.
Old July 2nd 06, 08:38 PM posted to rec.aviation.owning
Kyle Boatright
"Kyler Laird" wrote in message
Again, the problem is that a pre-heater and/or a trickle charger need hours
to do their thing. Trying to run either from a car ain't gonna cut it.
snip
--kyler
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Please help -- It's down to the wire Jay Honeck Owning 24 July 14th 04 06:05 PM
