Previously I had posted that I didn't clearly notice any effect from
the installation of a Knots 2U Wing Root Fairing kit on my cherokee 140. As part of my BFR I did some slow flight and stalls today. One difference with the wing root fairings is that it was waaaay easier to fly with the stall light on. Never before have I been able to keep the stall light on steady for any significant time, never mind thru the entire task. Bottomline: it seems that the most noticable effect of the fairings is lower stall speed. -- Bob Noel Looking for a sig the lawyers will hate |
lower stall speed. And it simply makes any Cherokee look better. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
It DOES!
Have new pix for the Gallery Jay! Dave On 1 Jul 2006 19:55:39 -0700, "Jay Honeck" wrote: Bottomline: it seems that the most noticable effect of the fairings is lower stall speed. And it simply makes any Cherokee look better. |
On Sat, 01 Jul 2006 21:39:15 -0400, Bob Noel
wrote: Previously I had posted that I didn't clearly notice any effect from the installation of a Knots 2U Wing Root Fairing kit on my cherokee 140. As part of my BFR I did some slow flight and stalls today. One difference with the wing root fairings is that it was waaaay easier to fly with the stall light on. Never before have I been able to keep the stall light on steady for any significant time, never mind thru the entire task. Bottomline: it seems that the most noticable effect of the fairings is lower stall speed. The Cherokee is the only plane I've every flown that could be flown through turns using the ailerons while stalled. The Cherokees are very good and well behaved in slow flight right up to and including the stall. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
through turns using the ailerons while stalled. The Cherokees are very good and well behaved in slow flight right up to and including the stall. Straight wing or taper wing? |
On Sat, 08 Jul 2006 03:03:17 GMT, john smith wrote:
The Cherokee is the only plane I've every flown that could be flown through turns using the ailerons while stalled. The Cherokees are very good and well behaved in slow flight right up to and including the stall. Straight wing or taper wing? Both, although I have much more time with the "Hershey Bar", or constant cord wing which is the much more docile of the two. Higher sink rate too:-)) In my experience the tapered wing Cherokee is less forgiving, but still one of the most docile out there when compared to other 4 place planes. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger |
| ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 09:40 PM |
| Canard planes swept wing outer VG's? | Paul Lee | Home Built | 8 | January 4th 04 09:10 PM |
| wing root strakes (not canard A/C) | Wallace Berry | Home Built | 0 | October 2nd 03 09:47 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
