![]() "Denny" wrote: I'm flying with the 196 and 296 on the yokes... I can afford a 396 but haven't decided that I need inflight weather... If you flew back and forth between Mobile and Houston very much, you'd already have decided. These are typical days from mid-May to mid-September: http://tinyurl.com/zmxej (Pardon the crappy resolution allowed on the Bellsouth servers.) Before I had XM WX, it was impossible to plan summer trips with any degree of confidence, and often nerve-wracking to fly them. Now? The boomers aren't nearly as scary when I know exactly what they're up to. I ain't sayin' I'll go *every* time, but I've postponed only one flight, and landed short and waited only once in the two years I've had NEXRAD aboard. Used to happen all the time. -- Dan C172RG at BFM |
![]() "Dan Luke" wrote in message ... snip Before I had XM WX, it was impossible to plan summer trips with any degree of confidence, and often nerve-wracking to fly them. Now? The boomers aren't nearly as scary when I know exactly what they're up to. I ain't sayin' I'll go *every* time, but I've postponed only one flight, and landed short and waited only once in the two years I've had NEXRAD aboard. Used to happen all the time. -- Dan C172RG at BFM I don't have XM weather (wish I did), but the thing I've found which really helps me circumnavigate convestive stuff is altitude. Like you, I live in the South, where the haze layer often tops out at 8-10k ft. To get a good look at the CB's from afar, I climb above the haze. Since I fly an airplane which has the performance to get "up high" relatively easily, SOP for me in the summer is to climb above the haze layer, where I can see building weather from hundreds of miles away. The other plus is that 90% or more of the GA fleet is below you when you're at 10k or better, so there is less traffic in the first place and the visibility lets you see any traffic from a good distance. KB |
![]() "Kyle Boatright" wrote: I don't have XM weather (wish I did), but the thing I've found which really helps me circumnavigate convestive stuff is altitude. Like you, I live in the South, where the haze layer often tops out at 8-10k ft. To get a good look at the CB's from afar, I climb above the haze. That's ok if the CBs are isolated. Often though, they're more numerous, and hidden by towering CU that rise above the useful altitudes for my airplane. On those days, I used to fly below the bases so I could spot the darker areas and rain shafts. I spent a lot of time in sweaty, bumpy rides at 3,000 ft. Since I fly an airplane which has the performance to get "up high" relatively easily, SOP for me in the summer is to climb above the haze layer, where I can see building weather from hundreds of miles away. Must be nice. What airplane? -- Dan C172RG at BFM |
![]() "Dan Luke" wrote in message ... "Kyle Boatright" wrote: I don't have XM weather (wish I did), but the thing I've found which really helps me circumnavigate convective stuff is altitude. Like you, I live in the South, where the haze layer often tops out at 8-10k ft. To get a good look at the CB's from afar, I climb above the haze. That's ok if the CBs are isolated. Often though, they're more numerous, and hidden by towering CU that rise above the useful altitudes for my airplane. On those days, I used to fly below the bases so I could spot the darker areas and rain shafts. I spent a lot of time in sweaty, bumpy rides at 3,000 ft. Since I fly an airplane which has the performance to get "up high" relatively easily, SOP for me in the summer is to climb above the haze layer, where I can see building weather from hundreds of miles away. Must be nice. What airplane? RV-6, and the performance is wonderful. There have been numerous times where I've completed a flight through or around "VFR not recommended" weather due seeing the convective stuff from far away. The aircraft's relative speed also allows me to deviate around weather without losing all day and to get to breaks in weather before they close. On the other hand, the altitude has also kept me out of trouble when I saw stuff I didn't like and was able to put down 10 or 20 or 50 miles away instead of stumbling into it down low, sweaty, and in the haze. Of course, you have XM to help with the weather. The heat and haze are another issue... KB -- Dan C172RG at BFM |
Mike Spera wrote:
snip Final nit, it has a PROPRIETARY RECHARGEABLE BATTERY! It needs the special charger to juice up. Opinions vary, but I prefer standard double A's. I don't want to get fleeced for $200+ in a year or so when the rechargeable craps out. Yes, I know it stays charged while on external power, but I still don't like it. On the plus side, the battery will last 6+ hours with a fairly high backlight on. Something like 16 hours with the backlight off, but the unit is almost impossible to see with the light off. Mike, Good review. I share many of your observations, including your concern about the proprietary battery. However, if I may point something out -- the 396 runs for a VERY long time on that relatively tiny and lightweight battery. In order for NiMH to provide the same energy density, the entire back of the unit would need to be dedicated to battery storage, and it would weigh a ton. While I hate the thought of a proprietary battery like everyone else, I'm willing to trade that off for the higher energy density and lower weight afforded by the LiIon battery technology. If you want to talk nits, I'm more ****ed that they used a proprietary flash card. I mean, com'on! We have 2GB+ SD cards now that could hold road maps for the entire US...and what do they provide with the auto kit? 128MB(!) Hey Garmin...1998 called and wants its flash technology back! And speaking of the auto kit, I don't want to rub any more salt in that open wound of yours, but if you had bought the unit by the end of last year, you would have received the auto kit for "free". Dunno if you've seen my review of the 396, but you might find it helpful. Click through Aviation-Articles-Reviews-Garmin 396. Safe flying, -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
![]() However, if I may point something out -- the 396 runs for a VERY long time on that relatively tiny and lightweight battery. In order for NiMH to provide the same energy density, the entire back of the unit would need to be dedicated to battery storage, and it would weigh a ton. While I hate the thought of a proprietary battery like everyone else, I'm willing to trade that off for the higher energy density and lower weight afforded by the LiIon battery technology. Yeah, but only if you disconnect the weather receiver/antenna. With it hooked up, you get 2 hours. At that point, standard batteries in the bag start looking real good. I checked the Garmin dealers and another battery is only $40, so I'll shut up and get one. If you want to talk nits, I'm more ****ed that they used a proprietary flash card. I mean, com'on! We have 2GB+ SD cards now that could hold road maps for the entire US...and what do they provide with the auto kit? 128MB(!) Hey Garmin...1998 called and wants its flash technology back! Ain't that a load of crap? There is an outfit selling "compatible" memory cards, but they did not look much cheaper than Garmin's. And speaking of the auto kit, I don't want to rub any more salt in that open wound of yours, but if you had bought the unit by the end of last year, you would have received the auto kit for "free". They did bundle the car kit in the deal, but that was at $2499. The new retail price that I paid is $2195. So, it is just a shell game. Dunno if you've seen my review of the 396, but you might find it helpful. Click through Aviation-Articles-Reviews-Garmin 396. Safe flying, -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
![]() And speaking of the auto kit, I don't want to rub any more salt in that open wound of yours, but if you had bought the unit by the end of last year, you would have received the auto kit for "free". Not that I'm normal, but mine will probably never see the inside of a car. I bought the automotive card and software for my 295 (didn't initially realize that they were quite a bit more $$) and found I didn't like it. Small screens work for me on a yoke, but a dashboard is no man's land to this bifocal wearer. But now that my Garmin 195 is retired it is getting a new lease on life by feeding data to a retired laptop under the seat running MS Streets & trips and feeding a 7" monitor. And the whole mess isn't worth enough to be concerned about theft, unlike my 396. Even if I bought another antennae and power cord, and plumbed the 396 into the same spot where the monitor is going, I would still get tired of constantly yanking the 396 out of its mount and taking it with me when I park the car. That's the other thing that made to 295 impractical for everyday use, at least for me, I never have it when I really need it...... |
Mike Spera wrote:
Yeah, but only if you disconnect the weather receiver/antenna. With it hooked up, you get 2 hours. At that point, standard batteries in the bag start looking real good. I checked the Garmin dealers and another battery is only $40, so I'll shut up and get one. 2 hours? I get just shy of 4 hours with the XM connected and around 9 without. I wonder if your battery is from an old lot or sat around on the shelf for a while. That's the one downside to LiIon batteries...they don't last forever (charged or not) and hold less of a charge with every charge cycle. Most regularly charged LiIon batteries fail within 2 years. Can't wait to see how long this one lasts....mine is 10 months old and counting. Good that you found new batteries for $40. That makes me feel better. I though they were double that. -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
I do like the fact the the 396 charges the internal battery when plugged
into a 12V source. What I don't like that I won't necessarily know when the internal battery needs to be replaced because it will no longer hold a decent charge because it will not normally be used. Of course, from a safety standpoint, at this point I guess I have to be in IMC, lose the alternator, run the aircraft battery down, and then exhaust the 396 battery before I'm totally sol. Maybe I should just spring for another $40 battery, rotate them to keep them charged, and count my blessings! Tom Doug Vetter wrote: Mike Spera wrote: Yeah, but only if you disconnect the weather receiver/antenna. With it hooked up, you get 2 hours. At that point, standard batteries in the bag start looking real good. I checked the Garmin dealers and another battery is only $40, so I'll shut up and get one. 2 hours? I get just shy of 4 hours with the XM connected and around 9 without. I wonder if your battery is from an old lot or sat around on the shelf for a while. That's the one downside to LiIon batteries...they don't last forever (charged or not) and hold less of a charge with every charge cycle. Most regularly charged LiIon batteries fail within 2 years. Can't wait to see how long this one lasts....mine is 10 months old and counting. Good that you found new batteries for $40. That makes me feel better. I though they were double that. -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
![]() "Doug Vetter" wrote in message ... Mike Spera wrote: .... Good that you found new batteries for $40. That makes me feel better. I though they were double that. -Doug How do you charge that 'spare' battery? |
Garmin gpsmap 96 and onlinecontest? | DBn | Soaring | 3 | June 9th 06 11:46 PM |
WTB: Garmin GPSMAP 196 ccessories | bobo | Aviation Marketplace | 0 | December 7th 04 04:07 AM |
Garmin gpsmap 76s, glide ratio, airspace zone | Gilles_Sauvagnat | Soaring | 11 | April 15th 04 12:39 AM |
Garmin GPSmap 196 on 172 Yoke | Otto Braasch | Owning | 2 | February 20th 04 09:58 PM |
PLEASE HELP! GARMIN GPSMAP 196 Update and now my maps fail to show properl | PaulaJay1 | Owning | 0 | August 13th 03 06:52 PM |
