Stuck panel screws
Old July 5th 06, 02:18 AM posted to rec.aviation.owning
Default Stuck panel screws
I was reading a previous thread from May about owner assisted annuals. I
noticed a number of comments about drilling out stuck inspection panel
screws. Back when I used to work on airplanes as an avionics tech, someone
showed me a neat trick for getting stuck screws loose. When you find a
screw that doesn't want to come loose, or that the screwdriver tip cams out
of, put a little dab of valve grinding compound on the screwdriver tip.
Valve grinding compound comes in a tube about the size of a small tube of
toothpaste at auto parts stores, and has a fairly coarse grit in it. It
gives your screwdriver tip much better traction in a screwhead that's
already been a little damaged, and does a great job of preventing the
screwdriver tip from camming out. There's also something similar available
called "Screw Grab" that I found at a hardware store locally, that has the
same grit in it but in a thinner solution. It works just as well. It comes
in a small plastic tube. I've rarely had to drill out screws since I started
using those compounds.
Scott Wilson
Old July 5th 06, 02:46 AM posted to rec.aviation.owning
Vaughn Simon
wrote in message ...
When you find a
Hmmm, that sounds a lot easier than my favorite trick. I use one of those
little cutting wheels on a Dremel tool and cut a new screwdriver slot across the
head of the screw. Works for conventional, Phillips, Torx...
Vaughn
Old July 5th 06, 03:35 AM posted to rec.aviation.owning
Valve grinding compound and, when that doesn't work, cutting a slot in the
screw head -- two good ideas. You may be able to avoid problems entirely by
using a top-quality, brand new phillips head screwdriver or bit. That will
assure that maximum torque is applied to the screw head.
For round-head or pan-head screws, there is one last, desperation move you
can try before drilling the screw out. Using a flat file or the grinding
wheel on a Dremel tool, CAREFULLY create two "flats" on the edges of the
screw head and use a vice-grip pliers to grasp them. This will allow you to
put much more torque on the head than you can with any screwdriver.
Needless to say, you should not reuse a screw that has ANY damage to the
head
-Elliott Drucker
Old July 6th 06, 12:16 AM posted to rec.aviation.owning
FlyWithTwo
Scott Wilson
Hi Scott,
An A&P friend showed me a trick on an access panel that had some stuck
fasteners. He used a 1/4" speeder wrench with a phillips head socket.
The speeder wrench looks like an old "bit and brace" drill. It allows
you to push hard on the bit and still keep it square when you turn it.
Using this tool, he started by turning the fastener tighter, just a
slight bit of a turn. This was to break the sticking threads loose,
and then it took less torque to back the screw out. Sometimes old
fasteners have a bit of rounding in the direction used to back them
out. The use of valve grinding compound to allow the bit a better
interface also sounds like good advice.
Good Luck,
Brian
Old July 6th 06, 03:25 AM posted to rec.aviation.owning
BTIZ
ahhh.. an old mechanic taught me that one 35 yrs ago.. gald to know it still
works
BT
someone
out
available
started
Scott Wilson
Old July 6th 06, 04:07 AM posted to rec.aviation.owning
Aaron Coolidge
FlyWithTwo wrote:
: Hi Scott,
: Using this tool, he started by turning the fastener tighter, just a
: slight bit of a turn. This was to break the sticking threads loose,
: and then it took less torque to back the screw out. Sometimes old
: fasteners have a bit of rounding in the direction used to back them
: out. The use of valve grinding compound to allow the bit a better
: interface also sounds like good advice.
YES! The fastener is loaded in the "loosen" direction. Turning it slightly
"tighten" breaks the (decades) old rust bond. Tapping the head with a
small hammer works, too (tap gently!).
Aaron C.
Old July 6th 06, 04:34 AM posted to rec.aviation.owning
David Lesher
With a torn-up Phillips, you can sometimes bash the head flat
again; driving the metal back into the head.
I've always wanted to try the dry ice on the head trick as well;
never have.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old July 7th 06, 12:20 AM posted to rec.aviation.owning
On 5-Jul-2006, "FlyWithTwo" wrote:
Hi Scott,
In the Air Force we called that tool a "speed handle" but I'm sure your name
is more accurate. I'm sure I've got hundreds of hours turning those, we
used them for opening and closing all of the various access panels on the
F-4Cs and F-4Es I worked on waaay back when. Fighters use LOTS of panel
fasteners! You're right, this tool does work pretty well for freeing stuck
screws. Put a little valve-grinding compund on the bit tip and you can't
miss!
I used to know a fellow that had another type of stuck screw removal tool.
I'm not sure who made it, perhaps Snap-On, but it looked kind of like a
fat stubby screwdriver with a metal handle. You'd put an Apex bit in it,
stick the bit in the stuck screw, and whack the butt of the handle with a
hammer. The impact of the hammer pushed the bit into the handle a little,
and at the same time the bit was twisted slightly counter-clockwise. That
would break loose stuck screws pretty easily and quickly. You had to be
careful not to whack it so hard as to cause other problems though!
Scott Wilson
Old July 7th 06, 12:25 AM posted to rec.aviation.owning
Mark Hansen
Hi Scott,
miss!
This is called an Impact Driver, and is available at pretty much any
tool supply store (even your neighborhood corner auto parts store).
They are great! I would never be without one.
Scott Wilson
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Airtex Interior Refurbishment - Day 53 Mike Spera Owning 1 May 26th 05 02:52 PM
Why not a hinged panel? Jay Honeck Owning 22 March 7th 05 11:15 PM
PA28-181 - Stuck Mike - King Silver Crown Roy Page Owning 2 October 29th 04 03:36 AM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 02:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
