We can all agree -- THIS is a great aviation video...
Old July 7th 06, 12:50 AM posted to rec.aviation.piloting
Gary Drescher
Default We can all agree -- THIS is a great aviation video...
"Jim Macklin" wrote in message
news:GTgrg.62820$ZW3.17380@dukeread04...
"gatt" wrote in message
news:L5drg.62804$ZW3.40846@dukeread04...
I guess when you're making a movie, violation of the FAA and
USCG laws are OK?
How is it a violation?
§ 91.13 Careless or reckless operation.
(a) Aircraft operations for the purpose of air navigation.
No person may operate an aircraft in a careless or reckless
manner so as to endanger the life or property of another.
Even assuming that the scene was filmed without special effects, a
meticulously planned and executed stunt--carefully coordinated with the
stunt performers in the boat--would not have endangered anyone. (Since there
are no clear rules as to what counts as reckless, the FAA could conceivably
try to invoke 91.13a anyway; but that's true regarding *any* flight, and in
any case they apparently haven't done so.)
(b) Aircraft operations other than for the purpose of air
navigation. No person may operate an aircraft, other than
for the purpose of air navigation, on any part of the
surface of an airport used by aircraft for air commerce
(including areas used by those aircraft for receiving or
discharging persons or cargo), in a careless or reckless
No airport surface was involved.
§ 91.115 Right-of-way rules: Water operations.
(a) General. Each person operating an aircraft on the water
shall, insofar as possible, keep clear of all vessels and
avoid impeding their navigation, and shall give way to any
vessel or other aircraft that is given the right-of-way by
any rule of this section.
The aircraft kept clear, and it had right of way according to 91.115b (the
plane was to the boat's right).
§ 91.119 Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may
operate an aircraft below the following altitudes:
The aircraft was taking off, so the altitudes in 91.119 don't apply.
Note that just because you are taking off, you still must
comply with the regulations. Read this again...
[91.119](c) Over other than congested areas. An altitude of 500 feet
above the surface, except over open water or sparsely
populated areas. In those cases, the aircraft may not be
operated closer than 500 feet to any person, vessel,
vehicle, or structure.
Huh? According to the beginning of 91.119, parts a, b, and c *do not apply*
during takeoff or landing. If they did apply, then it would be illegal for
you to land on a runway whenever another plane is holding short less than
500' from your flight path!
--Gary
Old July 7th 06, 12:52 AM posted to rec.aviation.piloting
Newps
Jim Macklin wrote:
Yes, but I didn't see a waiver.
You wouldn't, it's not like it's a billboard planted so everyone can see
it. It's a piece of paper allowing someone to deviate from certain
FAR's and under what conditions they may do so.
Do you know whether there
was a waiver?
I wouldn't have any idea but I don't go jumping off half cocked assuming
there wasn't one. I assumed there was. They are easy to get and are
given every day for a whole host of reasons.
The point I was making is that we shouldn't
be laughing at fat people being thrown from horses, kids on
skate boards crushing their jewels or pilots making an
unsafe take-off.
If it's funny I'll laugh. I don't care if you're fat, retarded, black,
whatever. If it's funny, it's funny.
Old July 7th 06, 02:00 AM posted to rec.aviation.piloting
Jim Macklin
key word, necessary... or was the take-off necessary.
"Gary Drescher" wrote in message
| "Jim Macklin" wrote
in message
| "Jim Macklin"
FAA and
| USCG laws are OK?
navigation.
reckless
another.
effects, a
could conceivably
air
than
another.
water
and
any
by
to 91.115b (the
may
don't apply.
must
of 500 feet
c *do not apply*
short less than
| --Gary
Old July 7th 06, 05:14 AM posted to rec.aviation.piloting
Jose[_1_]
Takeoffs are optional. Landings are mandatory.
Jokes aside, the key word "necessary" does not require that the takeoff
be necessary, but that once the takeoff is happening, the altitudes and
such be necessary.
Jose
Old July 7th 06, 01:01 PM posted to rec.aviation.piloting
Gary Drescher
news:Bmirg.62828$ZW3.25169@dukeread04...
apply*
for
No, that's not a sensible parsing of the qualifier "Except when necessary
for takeoff or landing".
A takeoff is virtually never necessary. So if 91.119 meant what you think it
does, then you'd be forbidden to take off from a runway if your flight path
would bring you within 500' of another aircraft that's on the ground near
the runway (on a parallel taxiway, for example). Is that really the rule you
follow when you fly?
--Gary
Old July 7th 06, 02:14 PM posted to rec.aviation.piloting
Jim Macklin
In the case in question, there was a fishing boat, with two
people and the PBY did in fact take-off directly toward the
boat. I understand that this was a staged movie and it is
possible that they did get a waiver [it is also possible
they didn't]. But the video clearly shows the boat rocking
on the bow wave, which does indicate that this was an actual
take-off toward the boat.
THAT operation is illegal, unsafe and unnecessary. In
crowed harbor, there will often be boat traffic, some being
canoes, small motor boats and most will be operated by
untrained "captains."
Don't confuse normal airport traffic near a runway with boat
traffic on a lake or harbor.On a lake, a take-off or landing
may come closer than 500 feet to a boat, but it should NEVER
be aimed at that boat.
James H. Macklin
ATP,CFI,A&P
| "Jim Macklin" wrote
in message
must
and c *do not
| apply*
would be illegal
| for
when necessary
what you think it
your flight path
the ground near
really the rule you
| --Gary
Old July 7th 06, 02:51 PM posted to rec.aviation.piloting
Jose[_1_]
If it's the same takeoff I'm thinking of, it was most definately
necessary. How else would it be filmed for the movie?
Jose
Old July 7th 06, 04:09 PM posted to rec.aviation.piloting
Jim Macklin
Filming a movie is not necessary, it is optional. There may
even be alternative ways to film the scene. Those are
things that the FAA will consider before issuing a waiver.
It is possible that the scene was filmed in Mexico or some
other country, but that might make it legal, but it is still
unsafe.
James H. Macklin
ATP,CFI,A&P
land and seaplane rated
"Jose" wrote in message
. net...
definately
| Jose
music.
Old July 7th 06, 04:52 PM posted to rec.aviation.piloting
Jose[_1_]
Flying is not necessary either.
unsafe.
I do not agree that it is unsafe, except inasmuch as breathing causes
death. That's a very long lens on the camera; this compresses
perspective. Just like aerobatics demonstrations (which are
unnecessary), the visual tricks fool the viewer into thinking things are
a lot closer than they are.
Jose
Old July 7th 06, 06:35 PM posted to rec.aviation.piloting
Jim Macklin
Note the time delay is just a few seconds as the airplane
passes overhead and the wake rocks the boat, that was not a
telephoto lens but a real close pass.
James H. Macklin
ATP,CFI,A&P
.com...
may
waiver.
some
still
| unsafe.
breathing causes
compresses
are
thinking things are
| Jose
music.
8 days around the Great Lakes Jay Honeck Piloting 20 June 28th 06 05:19 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
