Garmin GpsMap 396 - Flight Test
Old July 7th 06, 02:13 PM posted to rec.aviation.owning
john smith
Default Garmin GpsMap 396 - Flight Test
In article .com,
"Dan" wrote:
Press and hold the OUT button while turning the GPS on.
What is the OUT button? (Is that one of the ZOOM buttons?)
  #32
Old July 7th 06, 02:34 PM posted to rec.aviation.owning
Dave Butler[_1_]
john smith wrote:
In article .com,
Yes, one is labeled "IN" and the other one is "OUT".
  #33
Old July 7th 06, 03:28 PM posted to rec.aviation.owning
Dan wrote:
I inquired to Garmin Tech support about our problems and got the
following response about clearing the almanac. Probably worth a shot.
Dan,
I spoke with Garmin today and got the same reply today. I followed the
procedure to reset the almanac and it took maybe 20 minutes to
complete. I also discussed a problem I am have having with my
lightspeed thirty 3Gs where I get a squeal through the headset when
attached to the 396 when the 396 is plugged in to the cig. lighter.
The support guy suggested I try a ground loop isolator between the 396
and the headset battery box. He mentioned RadioShack, but theirs does
not natively support the 3.5mm (1/8 inch) jack (RS requires a cable
adaptor). I did find a product at crutchfield.com ( 127SNI135 PAC
SNI-1/3.5 Minijack Ground Loop Isolator) that has female / male 3.5 mm
jacks. They web site has 5 testimonials, 2 from 396 owners, asserting
it solved all problems with using the 396's XM radio in the cockpit. I
ordered one today for about $18.00 + $6 shipping. I'll post a reply
next week with the result, but it looks promising.
-Bernie
  #34
Old July 9th 06, 01:53 AM posted to rec.aviation.owning
darthpup
GPS units need to have a "quadrifilar" design antenna or they will not
work well.
I had an older Garmin that I connected to an older stock GPS antenna
outside the Cherokee and it still would not work reliably. There is
information on this design antenna on the web. Magellan uses the quad.
http://www.qsl.net/n8imo/qha_4.html
  #36
Old July 9th 06, 04:27 PM posted to rec.aviation.owning
RST Engineering
You are either funning us, or you have absolutely no idea what a quadrifilar
antenna is. A two foot high antenna mounted on a 6 foot high mast isn't
going to mount easily on anybody's airplane, let alone a homebuilt.
Your "older Garmin ... connected to an older stock GPS antenna" probably
didn't have an amplifier in the antenna with enough gain to overcome the
loss in the coax you used.
Most GPS external antennas use a modified patch antenna with a 25-30 dB
amplifier mounted to the backside of the patch.
"darthpup" wrote in message
work well.
  #37
Old July 10th 06, 03:07 AM posted to rec.aviation.owning
john smith
Jim, have you ever seen the GPS antenna for the Goodyear Blimps?
Of course not! Do you think they want everyone to know they have a two
foot high quadrifiler antenna mounted on a six foot mast buried in the
middle of the envelope?
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
