We can all agree -- THIS is a great aviation video...
Old July 7th 06, 06:49 PM posted to rec.aviation.piloting
john smith
Default We can all agree -- THIS is a great aviation video...
In article kXwrg.62937$ZW3.47903@dukeread04,
"Jim Macklin" wrote:
Note the time delay is just a few seconds as the airplane
passes overhead and the wake rocks the boat, that was not a
telephoto lens but a real close pass.
And how do you know there was not some special effects contraption out
of sight behind the rowboat to generate those waves?
Remember... it's only a movie!
Old July 7th 06, 07:27 PM posted to rec.aviation.piloting
Bob Noel
I watched the scene several times last night. Note that the camera
pans down to see the boat "rocked" but by what? The bow wave
doesn't look close to the boat and it seems hard to figure out
the distant between the plane and the boat. Doesn't a long lens
put the background out of focus? (or did I get that backwards?)
Bob Noel
Looking for a sig the
lawyers will hate
Old July 7th 06, 07:30 PM posted to rec.aviation.piloting
Gary Drescher
"Jim Macklin" wrote in message
news:l8trg.62919$ZW3.30020@dukeread04...
Don't confuse normal airport traffic near a runway with boat
traffic on a lake or harbor. On a lake, a take-off or landing
may come closer than 500 feet to a boat, but it should NEVER
be aimed at that boat.
Certainly not without the boat occupants' competent cooperation; that would
be reckless. But in this case (assuming the scene was even real), the stunt
performers in the boat *were* cooperating, and presumably had the expertise
to do so safely.
Your assertion that 91.119 prohibits the takeoff can't be correct, because
otherwise 91.119 would also forbid you to take off or land whenever doing so
would bring you within 500' of a person or vehicle. There's nothing in the
wording of 91.119 that addresses whether or not you are "aimed at" the
object you come close to.
--Gary
"Gary Drescher" wrote in message
| "Jim Macklin" wrote
in message
| news:Bmirg.62828$ZW3.25169@dukeread04...
| Note that just because you are taking off, you still
must
| comply with the regulations.
| Huh? According to the beginning of 91.119, parts a, b,
and c *do not
| apply*
| during takeoff or landing. If they did apply, then it
would be illegal
| for
| you to land on a runway whenever another plane is
holding short less than
| 500' from your flight path!
| key word, necessary... or was the take-off necessary.
| No, that's not a sensible parsing of the qualifier "Except
when necessary
| for takeoff or landing".
| A takeoff is virtually never necessary. So if 91.119 meant
what you think it
| does, then you'd be forbidden to take off from a runway if
your flight path
| would bring you within 500' of another aircraft that's on
the ground near
| the runway (on a parallel taxiway, for example). Is that
really the rule you
| follow when you fly?
| --Gary
Old July 7th 06, 07:47 PM posted to rec.aviation.piloting
Morgans[_2_]
"Bob Noel" wrote
Doesn't a long lens
Yep. Everything is in focus with the long lens.
Jim in NC
Old July 7th 06, 08:33 PM posted to rec.aviation.piloting
Jim Macklin
And it could all be CG from ILM starring real space aliens.
Your point is that you want to defend an unsafe operation
and I am suggesting that pilot's put legality and safety on
the top rung.
James H. Macklin
ATP,CFI,A&P
"john smith" wrote in message
| "Jim Macklin"
airplane
not a
contraption out
Old July 7th 06, 08:41 PM posted to rec.aviation.piloting
Jim Macklin
The FAA has been much more safety minded since they killed
Vince Morrow. Lots of risks can be accepted. But some
risks should not be taken or encouraged.
James H. Macklin
ATP,CFI,A&P
| "Jim Macklin" wrote
in message
boat
landing
NEVER
real), the stunt
had the expertise
| to do so safely.
correct, because
whenever doing so
"aimed at" the
| --Gary
message
| | "Jim Macklin"
wrote
| in message
still
| must
b,
| and c *do not
| | apply*
it
| would be illegal
| | for
necessary.
"Except
| when necessary
meant
| what you think it
runway if
| your flight path
on
| the ground near
that
| really the rule you
| | --Gary
Old July 7th 06, 09:15 PM posted to rec.aviation.piloting
Jose[_1_]
Nope. With a long lens, the depth of field is narrowed. That means
that if the foreground is in focus, the background will be =more= out of
focus than it would be had one used a short lens. There are of course
other variables (f-stop and film format) but all else equal, the long
lens narrows the depth of field and makes things seem "on top of each
other".
You can also get a sense of relative distance if you know the sizes of
the plane and boat in question, and measure the image.
Jose
  #28
Old July 7th 06, 11:02 PM posted to rec.aviation.piloting
john smith
Focus is a function of "depth of field" which is determined by the
apperature (f-stop) and shutter speed. The higher the f-stop (smaller
the apperature) the more the light rays which pass through the lense are
parallel, making the background more in focus.
  #29
Old July 8th 06, 02:33 PM posted to rec.aviation.piloting
Jose[_1_]
It was most definately a telephoto lens. I'm not convinced that the
wave that rocks the boat is the bow wave. We could figure all this out
- what kind of plane was it, what is its dimensions? (hull width, engine
spacing, wingspan). What is its typical approach speed?
It was also a close pass, but nowhere near as close as it looks. That's
how movies work. And remember, right at the end of a regular short
runway is stuff you don't want to hit too, but we take off of short
runways all the time.
It would be reckless for you and I and a few friends to go and do this.
However, Hollywood stunt people are well trained in these kinds of
things, they know, understand, and accept the risks (just like
aerobatics pilots do things that would be reckless for you or I to do
alone).
I have no problem with the flying in the shot.
Jose
  #30
Old July 8th 06, 07:39 PM posted to rec.aviation.piloting
Bob Moore
Jim Macklin wrote
I guess when you're making a movie, violation of the FAA and
USCG laws are OK?
It's pretty obvious to me that the airplane and the boat were never
in the same lake together. Just a large rear-projection screen like
Hollywood used in the past, or a good old blue/green screen effect.
Notice the number of different camera angles used to film the boat
and the men in it.
1. A wide angle shot from some distance off the port side of the boat.
2. A close-up of the man in the bow shot from the stern of the boat
or even outside the boat near the stern.
3. A close-up of the man and the engine shot from the water on the
starboard side of the boat.
How, and to where did all of those other cameras disappear to?
Nope! just a series of video clips assembled in front of a blue screen.
Bob Moore
8 days around the Great Lakes Jay Honeck Piloting 20 June 28th 06 05:19 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
