The Ghost of Andy Granatelli Tuned My Airplane!
Old July 7th 06, 10:56 PM posted to rec.aviation.piloting
Bob Chilcoat
Default The Ghost of Andy Granatelli Tuned My Airplane!
Friday, one of my partners and I changed the oil. Afterwards, we took it up
for a spin to reward ourselves. As I rotated, I glanced down at the tach
and was rather horrified. Redline on the Archer is 2,700 RPM. We were
turning 3,300! 600 RPM over redline. Huh?! Since we still had the full
length of both prop blades, the only logical explanations are either that
someone put a different prop on in the dead of night, or that someone
sneaked up and hopped up the Lycoming. We have to be getting 240 hp to see
that much overreving on climbout. Wow. Thanks, phantom tuner. What a nice
guy...
Oh crap! The rate of climb isn't any different.
We've ordered a new tach.
Bob (Chief Pilot, White Knuckle Airways)
Old July 8th 06, 03:43 AM posted to rec.aviation.piloting
Is Andy Granatelli dead? Last I heard he was alive and living in
Montecito, CA.
David Johnson
Old July 8th 06, 05:14 AM posted to rec.aviation.piloting
Jay Honeck
Great story -- thanks, Bob.
Question: I can understand how a tach fails and shows "zero" RPM -- but
how does it fail and show *higher* RPM?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old July 8th 06, 05:53 AM posted to rec.aviation.piloting
BTIZ
have the current tach calibrated before replacement.. those cheap hold in
your hand and look at the prop works pretty good.
BT
"Jay Honeck" wrote in message
up
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old July 8th 06, 07:55 PM posted to rec.aviation.piloting
Bob Chilcoat
We did that a few weeks ago when it first started reading high. We found
that on the ground, it was consistently 10% high. However, in the air,
particularly this time, it was reading considerably higher and bouncing
around. I understand that one failure mode is for the shaft bearing to wear
and let the rotating magnet touch the aluminum drag cup. When this happens
it reads high and bounces around. Ergo, order a new tach.
"BTIZ" wrote in message
news:sTGrg.11095$6w.10302@fed1read11...
BT
Old July 8th 06, 07:59 PM posted to rec.aviation.piloting
Bob Chilcoat
I guess he's still around. Sorry, Andy. Rumors of your demise are greatly
exaggerated.
Perhaps I was thinking of Mickey Thompson or some such.
Montecito, CA.
David Johnson
Old July 8th 06, 11:25 PM posted to rec.aviation.piloting
Stache
guy...
There are two different kinds of tach pick-ups for instruments. One is
direct drive from engine to tach by a cable the other is electronic
pick-up. If the engine sounds were the same I would think you have an
indication problem. Have your local A&P use a calibrated RPM gauge and
check you RPM this is the first test.
It may be a bad cable, faulty electronic pick up or just a bad tach.
You're A&P should know in short time what the problem is. Regardless
have it fixed before the next flight.
Stache
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
