$300 homebrew wing levelling system
Old July 8th 06, 01:57 AM posted to rec.aviation.homebuilt
jmk
Default $300 homebrew wing levelling system
Bill Daniels wrote:
I've been carefully watching the MEMS AHRS and IMU units for a while. The
makers claim good performance but charge high prices.
There is another way to achieve attitude sensing and that is multi-head GPS
receivers that measure carrier phase difference between the antennas. If
you combine MEMS AHRS with GPS attitude the two independent systems
complement each other such that the AHRS provides "coast-through" attitude
during GPS dropouts. It's not cheap but 0.1 degree resolution is possible.
There is no question that your idea will work, and work VERY VERY well.
NASA did some experiments and the results were WAY better than a
conventional AI. Just not quite ready for the consumer market yet -
price. But definitely has the potential to become a contender.
BTW, ref: the idea of putting multiple units in a "tell me thrice"
configuration. That would help, but except for the benefit of
redundancy, doesn't gain as much as one would think. They all tend to
suffer similar problems.
What we did do, which helped quite a bit, was characterize the units
over temperature. Although the variation between units is significant
(hence the benefits you noted), and the change with temperature is
DRASTIC, for any individual unit the change with temperature tends to
be quite repeatable. This allows you to temperature compensate the
unit with a response curve fit in software. BIG help.
Still leaves the inability to differentiate slow drift from a slight
deviation from level (or straight). But then a conventional AH
(electric or vacuum) has he same problem.
Old July 25th 06, 10:55 PM posted to rec.aviation.homebuilt
jmk wrote:
Morgans wrote:
wrote
This simple system could be put together for under $300. Any thoughts
on how it might work?
Sounds like you are on the right track. One thing I would think about
adding, is a way to automatically correct for the rate gyro's drift.
Worst case for most of those RC gyros (designed for RC helicopters,
etc.) is about 3 degrees per second. Most of our airplanes will
naturally STAY level better than that. Better gyros are available, of
course, but the price goes up... A good Crossbow 3-axis gyro is $3K or
above.
A $30 analog devices mems gyro drift is about 70 degrees/hour with
temperature calibration, straight out the box they are pretty lousy
(and I think Crossbow uses the analog devices chips but calibrates the
crap out of them). RC helicopters use the older style piezo gyro's.
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Piloting 365 March 16th 06 01:15 AM
A New Air Traffic Control System On The Horizon Larry Dighera Piloting 0 June 17th 05 03:03 PM
Air Force Helper 2000 tomcat Naval Aviation 0 June 9th 04 11:54 PM
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
