no instrument flight
Old July 10th 06, 03:07 AM posted to rec.aviation.soaring
bumper
Default Clams
Mostly because it conjures up a nicer mental image than being, "Happier than
a pig in a waller".
Or I ain't had this much fun since the hogs ate my little brother.
bumper ZZ (reverse all after @)
"Dare to be different . . . circle in sink."
"Martin Gregorie" wrote in message
Bullwinkle wrote:
They then make marks with grease pencil at the crucial airspeeds, and
report
being happy as clams with it.
There's something I've always wondered: why are clams happy in America?
And is this happy clam a shellfish or a cult member?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #32
Old July 10th 06, 04:59 AM posted to rec.aviation.soaring
Mike the Strike
Default OT: Happy Clams
The expression is totally American and originated in about the 1830's
in New England. The original is often quoted as "Happy as clams at
high tide" or similar. That's when it's difficult to dig them up and
eat them!
I also experimented with extra canopy strings (I had to buy about 4,000
feet of red yarn to replace a lost string, so have plenty spare). They
were for ever getting trapped in the canopy and even when free weren't
that useful. Anyone need 3,900 feet of red yarn?
Mike
  #33
Old July 10th 06, 01:31 PM posted to rec.aviation.soaring
Don Johnstone
Default no instrument flight - angle of attack
Sorry Bill not knocking your suggestion which is technically
sound but, ASI,Altimeter, 2 varios, turn and slip,
AH, compass, FLARM, transponder, radio, ELT, GPS, Palm
Top, Anti collision strobe, AoA meter, logger, data
link and batteries to power the above. I need a bigger
glider or perhaps dispense with the pilot :-)
At 21:42 09 July 2006, Bill Daniels wrote:
'Marc Ramsey' wrote in message
.com...
I suspect that surface ports on the top and bottom
of the nose will also
only work at zero slip/skid angle. Marc
Why would that be?
If both top and bottom ports are on the center line
they should be equally
influenced by slip/skid induced crossflow. You'd just
be measuring the
pressure difference between the ports not the absolute
pressure.
BTW, the guys at Black Forrest with pitch strings report
they give advanced
warning of lift so zooms can start a few seconds sooner.
An electronic AOA
indicator should do the same. Seems an AOA indicator
is both a safety
device and a performance boon.
Bill Daniels
  #34
Old July 11th 06, 01:49 AM posted to rec.aviation.soaring
Ralph Jones
Default OT: Clams
On Mon, 10 Jul 2006 00:40:42 +0100, Martin Gregorie
Bullwinkle wrote:
They then make marks with grease pencil at the crucial airspeeds, and report
We have a whelk shortage.
rj
  #36
Old July 18th 06, 04:18 PM posted to rec.aviation.soaring
Eric Greenwell[_1_]
Marc Ramsey wrote:
Eric Greenwell wrote:
I don't think it's a good thing for student pilots, but how about the
licensed pilot flying cross-country? Would outlandings be safer if
pilots used the AGL information? I already do so to some extent, when
I use the "make waypoint here" feature over a good outlanding field,
then use that waypoint as my "target" for the glide computer.
I've been working with digital terrain elevation data since the mid-80s.
There are noticeable errors in some of the publicly available source
data. Fitting data for a usable area into the memory available in a PDA
requires a reduction in resolution. One also needs to consider the
possibility of significant GPS altitude errors. This data is fine for
drawing maps and getting a general idea of the height of the terrain,
but, in my opinion, depending on it for flying a pattern into an
unfamiliar field would be a mistake...
Marc is quite correct, and I should have mentioned I usually add 500
feet to my reserve to mitigate the problems he mentions; also, I
normally use it over relatively level terrain where the 2D resolution
wouldn't be important, and it's been accurate enough. I don't exactly
use it to fly a pattern, but just to get me back to the field high
enough to set up a pattern in the usual fashion - "that looks about right".
Now I'm curious about the accuracy of the terrain data used in my pda,
which runs SeeYou Mobile. I know SeeYou itself uses "relatively
accurrate" data now after the change (last year?) to data downloaded
from the Internet as needed, and SeeYou's terrain data is used to
produce the terrain data for the pda.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
question about instrument proficiency check Sylvain Instrument Flight Rules 14 October 20th 05 09:11 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
