I am curious what people are using for downloading .igc files from the
LX5000 which will validate in WinScore. I have used my old laptop's serial port, SeeYou software, downloading directly onto a diskette, and it does not validate. This hasn't been a problem in past contests (even one Nationals) but according to the rules could present a problem if the rules are followed strictly. Of course now I have the challenge of using my new Dell laptop with a 'port replicator' to do the same as my old one is failing component by component. How are others out there doing this? Thanks, John GO/1PD |
John,
What do you mean by "validate" in WinScore? (Haven't used WinScore enough to know what that means.) At contests, I've used LX5000 and LX7000 log files downloaded using both ConnectMe and ConnextLX (on a PDA) with no problems. ~ted/2NO |
Thanks Doug. I did not realize the LX5000 came in two flavors -- and I
used to own one! I have a major issue with my LX7007-IGC -- its GPS engine stops updating locations while circling, causing the route to look peculiar in SeeYou, and with incorrect thermaling statistics. (Mounting the antenna up on top of the glare shield did nothing.) The response from the factory was that that's just the way the GPS receiver works. Very frustrating. ~ted/2NO |
I have 3 different GPS's (with different antennas and chip sets) on
board my glider (VolksLogger, CF-Card/PDA and an OEM GPS connected to the SN10) and none of them do this. They may occasionally skip an update or two, but not enough to mess up the thermal statistics. If this was normal, there wouldn't be a thermal statistic function in the software anyway. Assuming the LX7007 doesn't use some antiquated GPS engine, I would suspect a bad antenna or cable. wrote: Thanks Doug. I did not realize the LX5000 came in two flavors -- and I used to own one! I have a major issue with my LX7007-IGC -- its GPS engine stops updating locations while circling, causing the route to look peculiar in SeeYou, and with incorrect thermaling statistics. (Mounting the antenna up on top of the glare shield did nothing.) The response from the factory was that that's just the way the GPS receiver works. Very frustrating. ~ted/2NO |
Doug,
I'm not the only one who's had this problem. It is the GPS engine, not the antenna or cable. I still recommend the LX line of products but nearly as enthusiastically as I once did. -ted/2NO |
Remember, the DLL from the IGC website has been validated by IGC, Winscore has not. Winscore performs flight log security checks by making calls to the manufacturer supplied DLLs. The DLLs distributed with Winscore were obtained from the IGC. In this case, LX5000 logs, the "igc-lxn.dll is used for validation. The CD/Scorer is, of course, free to use external programs to perform flight log security verification. The use of the approved DLL's were included into Winscore in an effort to speed up the scoring process while still using the manufacturer supplied DLLs for verification. I am disappointed that Mr. Downing didn't take the time to contact me himself with detailed information on how to fix his problem. Guy Byars |
snip I am disappointed that Mr. Downing didn't take the time to
contact me himself with detailed information on how to fix his problem. /snip Guy, He may not have known to. -ted/2NO (the former Guy of ... oh, never mind.) |
Guy,
Thanks for the information. Originally I was looking for some hardware solutions to my LX5000/new laptop/serial port adaptor problems. Shouldn't have gravitated into a discussion of Winscore software in this forum. I didn't even think about bothering you about my hardware problems. I know from personal experience that you are always readily available to be of assistance and appreciate what you have done and are doing for sailplane racing. Indeed the scorekeeper has been in touch with you regarding this and the small difficulty is well in hand. Thanks, John Guy Byars wrote: Remember, the DLL from the IGC website has been validated by IGC, Winscore has not. Winscore performs flight log security checks by making calls to the manufacturer supplied DLLs. The DLLs distributed with Winscore were obtained from the IGC. In this case, LX5000 logs, the "igc-lxn.dll is used for validation. The CD/Scorer is, of course, free to use external programs to perform flight log security verification. The use of the approved DLL's were included into Winscore in an effort to speed up the scoring process while still using the manufacturer supplied DLLs for verification. I am disappointed that Mr. Downing didn't take the time to contact me himself with detailed information on how to fix his problem. Guy Byars |
| LX5000 DATABASE | Gordon Schubert | Soaring | 2 | May 15th 06 04:48 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| LX5000 + iPAQ | Ludovic Launer | Soaring | 7 | October 27th 04 07:18 AM |
| LX5000 FAI : any reason to keep my VL ? | Ludovic Launer | Soaring | 12 | September 21st 04 09:40 AM |
| LX5000 help | Ted Wagner | Soaring | 1 | April 29th 04 04:27 AM |
