Windmilling Prop & Vacuum Pump
Old October 14th 04, 02:18 PM
Dave Butler
Bill Hale wrote:
The gyros will typically run for ~ 5 min, but they lose the erection
function caused by the vacuum loss.
You must have way better bearings than I do... or maybe you're measuring the
time to when they stop spinning. They become useless for attitude control way
before they stop spinning.
Not sure what the 'erection function' is. I'm afraid to ask.
Old October 14th 04, 02:30 PM
Bob Moore
Research pendulous vanes.
Bob Moore
Old October 14th 04, 02:56 PM
Dave Butler
Thanks, Bob, I know what pendulous vanes are, but I was having trouble relating
pendulous vanes to the context of lost vacuum due to engine stoppage. The poster
Old October 14th 04, 04:19 PM
Ron Natalie
Sort of gyroscopic viagra?
Old October 14th 04, 08:08 PM
Roger
On Wed, 13 Oct 2004 04:39:47 GMT, Matt Young
Ok, a curious question just popped in my mind. Say that one was flying
IFR in a piston single, maybe a 172 or 182. While enroute, either in
actual or above a cloud layer, the engine fails. Will the windmilling
prop keep the vacuum pump going enough to make the AI and DG usuable
during descent through the clouds, or will the gyros keep spinning fast
enough long enough to make the vacuum pump irrelevant?
Your 're going to get answers all over the spectrum, but my take would
be it might happen, but don't count on it to save your bacon. IOW,
I'd not count on them working, or staying accurate which is
_far_worse_ than not working when you are in the clouds.
There are many variables such as the actual engine, prop, and vacuum
pump combination as well as best glide speed.
Its been my experience (which may not be typical) that a wet pump will
do better with the low RPM than the dry pump. This is assuming you
still have RPM which with a catastrophic failure you probably won't.
In my particular airplane which has a wet pump and a constant speed
prop, once the instruments are spun up even vacuum at idle (which is
well below the minimum) will keep the AI and DG working. The AI stays
accurate. The DG will start precessing but slowly although it does
hold well with a prolonged idle on the ground. Actually it's close to
being in tolerance. With full vacuum I don't have to reset it during
a 3 to 4 hour flight.
So, I'd expect to see the vacuum instruments "on mine" hold for some
time, but even knowing them as well as I do, I'd still depend on
partial panel and consider any use out of the vacuum instruments a
bonus.
www.rogerhalstead.com
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 05:42 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
