when is landing gear deployed?
Old July 20th 06, 03:15 AM posted to rec.aviation.piloting
Default when is landing gear deployed?
I would like to know how far before touchdown the landing gear is
typically deployed for larger commercial aircraft. Thanks.
Old July 20th 06, 03:18 AM posted to rec.aviation.piloting
Jim Macklin
At glide slope interception on an ILS or when beginning
descent on a visual, 3 to 5 miles from touchdown. Power is
set and the drag of the gear is used to initiate the descent
and glide slope capture.
James H. Macklin
ATP,CFI,A&P
gear is
Old July 20th 06, 03:22 AM posted to rec.aviation.piloting
Wow! This group is really responsive. Thanks.
I'm about to post another question about flaps.
Old July 20th 06, 03:38 AM posted to rec.aviation.piloting
Jim Macklin
The answer is, approach flaps as they are being vectored to
the approach and full flaps when the landing is assured.
Old July 20th 06, 03:47 AM posted to rec.aviation.piloting
Capt.Doug
On a standard ILS, landing gear is extended when the glideslope needle is a
half-dot above intercept. This prevents excessive pitch changes that might
occur if done at intercept. On a visual approach the gear is extended as
needed so long as we are in the landing configuration before 1000' AFE.
D.
Old July 20th 06, 05:14 AM posted to rec.aviation.piloting
Morgans[_3_]
"john smith" wrote
At KCMH/Port Columbus International, one can watch them drop their gear
just inside the Outer Marker/5 nm. This is in the vicinity of The Ohio
State University.
Yep. On one approach, they use the campus's center "green space", "The
Oval" (very visible, even from Goggle Earth) to line up on the extended
center line. I've watched many a jet fly over me, there.
Jim in NC
landing gear interface. Steve Franklin Piloting 6 September 24th 05 03:26 AM
Navy? C2/COD makes single engine, gear up landing. Dave S Piloting 20 August 20th 05 10:27 AM
Landing Gear Lights-Need Wiring Help BG Home Built 2 August 16th 03 11:21 PM
