Then your horn is not set properly. Also 50x60=3000 so if
you are coming down at 3000 fpm at 50 ft agl, your landings are something to see. The Arrow system could be defeated in two ways. As I recall the first gear up was done by a pilot who made a high power very flat high speed approach to a runway and flared and pulled the power off just a foot above the surface. The plane touched down before the gear had a chance to begin to extend. Others happened when CFIs practicing/teaching stalls used a small wooden block to wedge the over-ride lever UP so they could do slow flight and stalls without the gear falling down and without having to hold the lever up by hand. They would forget the block. -- James H. Macklin ATP,CFI,A&P "Peter R." wrote in message ... | Peter Duniho wrote: | | As for the warning horn, most retractable gear airplanes are equipped with | gear warning horns, and pilots frequently manage to ignore them | snip | | With regards to my Bonanza, this horn is practically useless as it will | only sound when manifold pressure drops below 12 inches, well below the | green arc on the MP gauge (implying that for the majority of the approach | the horn would be silent). | | It is not until power is pulled almost all the way back, which in my case | typically is less than 50 feet above the runway or about a second before | touchdown. | | | -- | Peter |
Jim Macklin wrote:
Then your horn is not set properly. OK, when should it sound? 17 inches MP? Also 50x60=3000 so if you are coming down at 3000 fpm at 50 ft agl, your landings are something to see. sigh You, too? -- Peter |
Yes, about 15-17 inches, low enough that you can slow down
and cool the engine without the horn sounding on every landing. Depending on the model of your Bonanza, you can use approach flaps and gear at 152 kts [if my old memory works] but some models have much lower speeds. You will need to plan your descents so that the airplane can slow down to Vlo and Vfe without needing to shock cool the engine and without hearing the horn. A normal approach would involve a descent to TPA 2-3 miles from the airport, then slowing to Vfe, gear down as required to begin the descent at 700 fpm/85-100 kts depending on traffic. If your Bonanza has three green lights, check them 5 seconds after you put the gear lever down. If yours is an old model, with just one green light, understand that the gear down microswitch is on the gear housing under the center spar cover and it is looking at the position of the gear housing. Since the Bonanza and Baron use steel push/pull rods to operate the gear, if one gear leg is up or one is down, the other two have to be in the same position unless the steel rods are bent or the housing has broken. Have a mechanic show you the system while it is on the jacks during the 100 hr or annual. On a flight, take a ruler up and set the throttle at the power you'd use, 15-17 inches and measure the position of the throttle and then your mechanic can set the warning horn microswitch in the correct place. -- James H. Macklin ATP,CFI,A&P "Peter R." wrote in message ... | Jim Macklin wrote: | | Then your horn is not set properly. | | OK, when should it sound? 17 inches MP? | | Also 50x60=3000 so if | you are coming down at 3000 fpm at 50 ft agl, your landings | are something to see. | | sigh You, too? | | -- | Peter |
![]() Kingfish wrote: Robert M. Gary wrote: They say we'll all do it at some point in our life. I sure hope not. If so, the insurance companies wouldn't write policies for complex acft anymore as they'd be replacing engines, props, and belly skins continually. I know distractions will happen, but I had it pounded into my head that if you do the same thing the same way every time you'll (usually) get the same result. That is, no sickening grinding noise during your (brief) rollout. The problem is that you'll never be able to do the same thing at the same time everytime. ATC may ask you to switch to a straight in, traffic may start to take off the opposite direction on the runway, etc. I sure hope I'll never land gear up, but I'm going to continue to live with the idea that its just out there waiting to happen to me on every flight. -Robert |
![]() "BTIZ" wrote in message news:tADvg.12811$6w.4234@fed1read11... I thought that auto extend feature had been disabled by a SB on most Arrows.. maybe only the older ones.. The '73 that I fly still has the auto-extend feature. If he was practicing commercial maneuvers he might have disabled it with the override switch and then forgotten to turn it off. GUMPS. I hope I never forget it. -c |
"Peter R." wrote: It is not until power is pulled almost all the way back, which in my case typically is less than 50 feet above the runway or about a second before touchdown. Wow! That must be something to watch! 50 feet per second vertical rate of descent on landing! I didn't know Bonanza gear was that stout! |
john smith wrote:
Wow! That must be something to watch! 50 feet per second vertical rate of descent on landing! I didn't know Bonanza gear was that stout! snip Some of you are so anal it makes me want to return to the bathroom for a second wipe job to see what I am missing. -- Peter |
![]() Robert M. Gary wrote: The problem is that you'll never be able to do the same thing at the same time everytime. ATC may ask you to switch to a straight in, traffic may start to take off the opposite direction on the runway, etc. I sure hope I'll never land gear up, but I'm going to continue to live with the idea that its just out there waiting to happen to me on every flight. Agreed. To clarify my statement about doing the same thing every time, I should have been more specific. A quick GUMP check will always keep you out of trouble regardless of where in the pattern you do it. It's OK to have a healthy fear of a gear-up landing, just don't accept it as inevitable as that old saying refers to (two kinds of pilots...) Distractions do happen, and that's where training should take over. The same guy at my old airport that bellied in his Baron almost did it a second time a year later. He got distracted by LL turbulence and was over the threshold when an eagle-eyed controller sent him around. |
![]() "Robert M. Gary" wrote The problem is that you'll never be able to do the same thing at the same time everytime. ATC may ask you to switch to a straight in, traffic may start to take off the opposite direction on the runway, etc. I sure hope I'll never land gear up, but I'm going to continue to live with the idea that its just out there waiting to happen to me on every flight. Yes, but there is time to check for the last time, before you reduce power to settle in, that you do have something to settle in "on to." Don't most people build into their approach and landing procedure, at least 3 opportunities to check gear down? Failure to do one because of being busy, maybe, but 3 times? I'm with kingfish. Not everyone will land gear up. -- Jim in NC |
In my S35 the gear horn start at about 13-14 inches. Bottom of the
green is 15 inches. I reduce to 15 inches about 5 miles out. My gear speed is 165 but I like to be around 145 or less to save wear and tear. After putting some time on my Bo this last 11 months I am convinced that many gear ups happen because pilots don't slow down enough in the pattern. I have a hard time getting below 100 without putting the gear down. I know Bonanza pilots who are deathly afraid to ever get below 100 unless their wheels are inches from the ground. Peter R. wrote: Peter Duniho wrote: As for the warning horn, most retractable gear airplanes are equipped with gear warning horns, and pilots frequently manage to ignore them snip With regards to my Bonanza, this horn is practically useless as it will only sound when manifold pressure drops below 12 inches, well below the green arc on the MP gauge (implying that for the majority of the approach the horn would be silent). It is not until power is pulled almost all the way back, which in my case typically is less than 50 feet above the runway or about a second before touchdown. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
landing gear interface. | Steve Franklin | Piloting | 6 | September 24th 05 03:26 AM |
Navy? C2/COD makes single engine, gear up landing. | Dave S | Piloting | 20 | August 20th 05 10:27 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
