Stupid Question
Old July 21st 06, 02:34 PM posted to rec.aviation.piloting
jmk
Default Stupid Question
Crash Lander wrote:
I'm surprised. I never knew how it all worked. That leaves the whole
'minimum number of hours required' thing a bit open to fudging doesn't it?
Crash Lander
Possibly, but as others have pointed out, it's hard for someone to
significantly falsify their log book and not get caught eventually - if
those hours are actually used as a basis for something. For example, a
pilot with a few hundred hours in a little Cessna 172 could claim
thousands of hours in MD-80's and A340's - but as soon as he applied
for a job and went into the simulator... well, you get the idea.
So it does happen (pilots used to talk about logging "P-51" time; the
P-51 Mustang being a piston fighter everyone wanted to fly, but in
reality referring to only having access to the "Parker P-51" fountain
pen to write the entry in the log book G). Rarely does it happen
such that you actually wind up with a truly unqualified pilot at the
controls of an aircraft because he fudged the hours.
NOW - as to the hours and types of aircraft a pilot may CLAIM to have
flown, when he's at the bar and trying to pick up the sweet young thing
on the stool next to him... Well, that's another matter entirely!
{:) [These tales traditionally start with the words, "There I
was..."]
Old July 21st 06, 02:40 PM posted to rec.aviation.piloting
Crash Lander
It is something that I would never ever do myself. It was just one of those
things I never knew about. I don't have my PPL yet, but will be starting
sometime later this year, and just wondered how it was recorded.
Thanks.
Crash Lander
"Morgans" wrote in message
"Jim Macklin" wrote
It is also grounds to revoke all certificates held.
To the original poster:
I think you can see, from the responses, that there are too many really
"bad
things" that can result from fudging your logbook. The possibility of
being
caught is certainly not worth the possible gain that could result from
having more hours. Very few people would have a situation where just a
few
hours would help, and fudging a lot is too obvious to get away with.
It is way too easy for someone to catch you. Also, one thing nobody
mentioned is, you write down the aircraft along with the hours in your
logbook. If it is a rental, or working hours, all you have to do is go
back
to the airplane's records, and see if you are written down as having been
the pilot on the dates you said in your logbook.
Jim in NC
Old July 21st 06, 02:42 PM posted to rec.aviation.piloting
Crash Lander
LOL! Must remember that! "There I was...!" right after I check that the wife
isn't around! LOL!
Crash Lander
"jmk" wrote in message
it?
Crash Lander
was..."]
Old July 21st 06, 03:00 PM posted to rec.aviation.piloting
Jim Macklin
The ratios of time in type and conditions often catch the
liars.
Those bar room tales often start with, " I used to fly for
the CIA, I'd tell you more about it, but then I'd have to
kill you."
One thing you'll likely never see in a pilot's logbook...
Jan3,2009 CE208B stolen at SAT round trip to Mexicalli,
2000 pounds dope, 5 hours X-C 3 hours IMC, no flight plan,
N12345xxx , unless the pilot is really stupid and wants the
turbine for an airline job.
James H. Macklin
ATP,CFI,A&P
leaves the whole
fudging doesn't it?
| Crash Lander
someone to
eventually - if
For example, a
could claim
he applied
idea.
"P-51" time; the
fly, but in
P-51" fountain
it happen
pilot at the
CLAIM to have
sweet young thing
entirely!
"There I
| was..."]
Old July 21st 06, 03:31 PM posted to rec.aviation.piloting
Morgans[_3_]
I think you can see, from the responses, that there are too many really "bad
things" that can result from fudging your logbook. The possibility of being
having more hours. Very few people would have a situation where just a few
logbook. If it is a rental, or working hours, all you have to do is go back
Jim in NC
Old July 21st 06, 03:36 PM posted to rec.aviation.piloting
Ron Natalie
Crash Lander wrote:
When pilots quote how many hours they have logged, is this a personal log
that is kept, or is every hour you fly entered into a national registry and
formally kept?
Crash Lander
The closest that comes to a national databse is that the NTSB can go
pull the medical applications and application for ratings (where you
self declare your hours).
Old July 21st 06, 05:34 PM posted to rec.aviation.piloting
Private
"Gary Drescher" wrote in message
"Crash Lander" wrote in message
and formally kept?
It's a personal log. But if the FAA has reason to be suspicious, they may
often be able to cross-check. Almost everyone does their primary training
in either rented or military planes; in either case, there's an
independent record of the planes' usage. At more advanced levels, pilots
who fly for airliners or some other commerical operators will likewise
generate an independent record of their flight hours. In between, though,
there are pilots who use their own planes for personal flying; those
flight hours would be harder to verify.
--Gary
I once spoke to an owner who said that his way of controlling maintenance
costs was, "If he didn't log the flight, then the aircraft didn't either."
Old July 21st 06, 05:50 PM posted to rec.aviation.piloting
Robert M. Gary
Its just like your taxes. The feds ask you for your times every once in
awhile (like during your medical) and you have to sign that the facts
are correct.
-Robert
Crash Lander
Old July 21st 06, 05:53 PM posted to rec.aviation.piloting
Robert M. Gary
Plus if your logs show 5000 hours in your aircraft the feds can always
ask to look at the aircraft log books. If its in a rental aircraft the
FBO will certainly have logs of it. It would probably be easy to
overstate things by 10% but it wouldn't buy you enough to risk it.
Overstating more than that would start to get easier to check.
There is the famous story (or legend) of a guy shownig up for his
multi-ATP ride with lots of multiengine time. The examiner looks
through his log book and see the N number for the multi-engine plane is
that same as the plane parked on the ramp, which just happens to be
owned by the examiner!
-Robert
Dave Doe wrote:
says...
Crash Lander
Yes. I have a flight that I never logged - and probably never will. I
have my reasons.
However logging extra hours - well - while you're doing your training,
you'll be doing so presumably with the one organisation. So this is
easily cross-checked (as well as very foolhardy IMO). Indeed it will be
the only easy way to rebuild your logbook if you lose it.
Duncan
Old July 21st 06, 06:31 PM posted to rec.aviation.piloting
Bob Martin
Robert M. Gary wrote:
Did he have an "on/off" switch on his tach? How did he manage that??
-Robert
One trick an instructor showed me... cut the master switch off. The
engine keeps running... and no time logged.
Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm Aardvark J. Bandersnatch, MP General Aviation 2 December 17th 04 11:37 PM
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___gitqexec Chris W Products 0 November 10th 04 12:39 AM
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___ gitqexec Richard Hertz Products 0 November 7th 04 11:45 PM
