gliders+radar
Old July 21st 06, 02:43 AM posted to rec.aviation.soaring
Bob Salvo
Default gliders+radar
Reflectivity is not the problem. We conducted experiments with Boston
control many years ago. They got good radar returns from our glass ships.
The problem is the slow speed we generally fly. Usually the center's radar
uses MTI (moving target indicator), which gets rid of ground clutter returns
and returns from flying birds. When Boston control deactivated the MTI
function, they could easily see us. Adding a lens to increase our
reflectivity would not help. But if we had doppler generator built into the
lens (maybe a spinning wheel propelled by air; we have lots of that
available), the lens would be removed from the clutter notch. Maybe
"Mike C 17" wrote in message
http://www.sailorssolutions.com/inde...ails&Item=RR01
Big John wrote:
Johan
Look up Luneberg Lens via Google.
We hung them on T-33 target aircraft in exercies to give a radar
return the size of a B-47.
You could make one out of foam and Rennels (sp) Wrap and put inside
your plastic bird and get a much larger radar return for just a few
ounces for the lens.
These are passive devices and no power is required.
Big John
On 19 Jul 2006 18:25:38 -0700, wrote:
Modern gliders are small and made of materials that show up poorly on
radar.
Are we basically flying stealth aircraft?
Johan Larson
Old July 21st 06, 06:47 AM posted to rec.aviation.soaring
Mike Schumann
Would the MTI also filter you out if you had a Mode C transponder?
Mike Schumann
"Bob Salvo" wrote in message
radar
returns
Big John wrote:
Johan
Big John
radar.
Johan Larson
Old July 21st 06, 01:13 PM posted to rec.aviation.soaring
Mike, AIUI there are two quite different radar types. The originals,
now know as Primary Radar, send out a signal and deduce your range and
direction (azimuth) from a reflection. That sort does not know whether
you have a transponder or not, reflections could be improved by large
enough Luneberg lenses (of dubious benefit for the size we could get
into a glider fuselage), and is subject to MTI if they switch it on.
Also, on a visit to Stansted UK (London's "third" airport) some years
ago, their ATC explained to me that not only did it fail to see slow
moving targets when MTI was on - which it almost always was, to reduce
screen clutter; it was also blind to anything with a radial speed
towards or away from the radar head at certain harmonics of the wave
length - in practice at 37.5 knots, 75 knots, and multiples. So even
with MTI off, thermalling gliders that were good reflectors would be
invisible half the time, and cruising towards or away from them would
also reduce or eradicate their trace of us.
Transponders use SSR (Secondary Surveillance Radar) which sends out an
APB to all transponders within range - "Oi, anyone out there?" to which
they all respond. No transponder, no response, SSR cannot see you.
With Mode S (for Selective), the Controller can then tweak it to say
next time around "Oi, only those transponders I have Selected - where
are you now?". Gliders etc. not so selected will then not be seen by
ATC. This has three effects (at least):
They have less cluttered screens, seeing only those that they want to
for control purposes;
Each Mode S transponder has a unique code identifying it to the
aircraft it is in, so they never run out of codes (unlike Modes A and
C, where Europe already has problems, because the existing 7xxx - type
codes are too few for ATC's purposes);
And transponders NOT selected by ATC would not be made to transmit a
signal zillions of times per second like a Mode A or C is, only say
once per second, so they still show up to TCAS units in the area but
save a lot of power compared with Mode A or C. This seems to be why,
in Europe at least, the authorities are looking at Mode S, rather than
A or C, as a mandatory standard. They know gliders would never have
enough power for Mode A or C with the expected growth in utilisation of
airspace and hence growing number of interrogations making transponders
squawk.
TCAS etc. in airliners etc., however, will still see all transponders
within their range, so will still give collision avoidance in respect
of gliders.
Hope that helps. Any experts care to correct this if necessary?
Chris N.
Old July 21st 06, 06:06 PM posted to rec.aviation.soaring
Big John
Mike
Make one for pennies and few Oz vs 2.2# and $139.95.
Big John
On 20 Jul 2006 14:36:09 -0700, "Mike C 17"
Big John wrote:
Johan
Big John
radar.
Johan Larson
Old July 21st 06, 06:13 PM posted to rec.aviation.soaring
Big John
Bob
I played with rotating Lens some years ago in a project to develope a
high speed radar return that could be detected by Police Radar
Detectors without the results I wanted. I wanted to 'pin the needle'
on detector at max so true speed wouldn't show. (I'm a dirty old man
Your idea for gliders might work? Not expensive to try/test.
Big John
On Thu, 20 Jul 2006 20:43:39 -0400, "Bob Salvo"
roups.com...
Big John wrote:
Johan
Big John
radar.
Johan Larson
Old July 21st 06, 06:20 PM posted to rec.aviation.soaring
Big John
Cris
FYI. The Lens used on our target aircraft in Air Force were only about
one foot in diameter. Not very big.
Return simuated aircraft size of B-47.
Big John
squawk.
of gliders.
Chris N.
Old July 22nd 06, 01:27 AM posted to rec.aviation.soaring
BTIZ
no... because you are sending a coded reply to a specific interrogation.
BT
"Mike Schumann" wrote in message
ink.net...
Mike Schumann
ships.
radar
returns
Big John wrote:
Johan
Big John
on
radar.
Johan Larson
Old July 22nd 06, 01:28 AM posted to rec.aviation.soaring
BTIZ
Yes... depends on the clutter... talk to a military pilot about "direct
terrain masking"
After reading the various posts here, the question arises-Will a radar
image be lost in clutter if it is the size of a B-47, due to the speed
of the aircraft?
Mike
Old July 22nd 06, 02:53 AM posted to rec.aviation.soaring
Bob Salvo
Only if the clutter is moving at the same speed.
of the aircraft?
Mike
Old July 22nd 06, 12:59 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Big John wrote:
Mike
I did a search for info about Luneberg Lenses - found plenty of
definitions/explanations/units for sale but nothing on DIY Luneberg,
how to make a ball with a radially varying refractive index or sources
of materials with suitable refractive index gradations.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 07:23 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Underwater Gliders Burt Compton Soaring 6 November 25th 03 05:43 AM
