Query on the Woodstock
Old July 22nd 06, 02:52 PM posted to rec.aviation.soaring
Stealth Pilot
Default Query on the Woodstock
Australia determined way back when the glider first appeared that the
aft fuselage area had insufficient torsional strength and required
strengthening. ( I suspect that they were a bunch of *******)
looking through the articles that have appeared on the woodstock I see
that it has been flown with a self launch engine that popped up behind
the pilot. surely motor operation would have bought the glider undone
if it actually had any weakness.
what do you guys who actually fly the woodstock think of the
structural integrity of the design?
Is there anything about the design that you'd alter to improve it?
Stealth Pilot
Australia
Old July 23rd 06, 02:16 PM posted to rec.aviation.soaring
Stealth Pilot
On 22 Jul 2006 18:41:45 -0700, "Doug Hoffman"
A search of the NTSB aviation accident database turned up two
structural failure incidents. Both were wing failures. One was caused
by using the glider for aerobatics. It is *not* an aerobatic glider.
The cause for the other was not determined. The pilot was flying wave
at 16,500 feet without oxygen.
I found no fuselage structure issues in the database.
Regards,
-Doug
thanks for that. it reinforces my thinking that it was an australian
spurious issue. ....not the only one.
Stealth Pilot
Old July 25th 06, 07:11 PM posted to rec.aviation.soaring
I think the Woodstock is a great design. It performs better than
expected and is well engineered. If I remember correctly, the builder
of my ship, Bob Wander, was consulted by the FAA or NTSB on both of the
in-flight break-up's that occured in the US. You could contact him at
bobwander.com for details but I'm pretty sure in both cases the
investigation showed that the glider was flown well outside limits.
I'd steer clear of the 13 meter extended wingtip version as I don't
think the rest of the airframe was originally intended for the
additional loads. The stock design has considerable margins and can
probably handle it fine but but I'd rather have the load margins Irv
Culver calculated over the couple points of L/D the extended tips might
add.
Matt Michael
http://members.aol.com/woodglider/matt.htm
Stealth Pilot
Australia
Old July 25th 06, 08:02 PM posted to rec.aviation.soaring
Frank Whiteley
I think a couple were being built with carbon rods in the spar caps
also.
http://www.marskeaircraft.com/carbonrod.html
Frank Whiteley
add.
Matt Michael
Stealth Pilot
Australia
Woodstock Plans F/S [email protected] Soaring 0 May 16th 05 10:06 PM
Jim Weir: RST-442E operation query Leo Home Built 8 April 25th 05 04:48 PM
Prop Strike Query Dick Home Built 12 November 16th 04 02:20 AM
Query for Jim Weir re RST Panel Mount Intercom [email protected] Home Built 3 November 14th 04 06:41 PM
Tool query... Tina Marie Owning 2 July 15th 04 05:20 AM
