Radar
Old October 22nd 04, 04:37 PM
Matt Young
Default Radar
A question about something that I guess I just didn't get enough info on
during my instrument training. What exactly are you looking for when
looking at a radar image. Are you trying to avoid all returns? Is an
area of just green ok? Any other things in particular to look for?
Old October 22nd 04, 05:21 PM
Peter R.
Don't rely on color, as different vendors of radar data might color code
the returns differently. Instead, you ought to rely on the intensity
level, which is represented by the different colors on a color radar
product. Refer to the radar key to know what color each intensity
level is.
Rod Machado wrote a pretty good AOPA Pilot article about this very thing
about a year and a half ago. He discussed the relationship between
intensity level and the probability of severe to destructive turbulence.
As there is a small probability of destructive turbulence in level three
returns, with this probability significantly increasing in each of the
higher levels, Machado stated that one should avoid level three and
higher to avoid the probability of destructive turbulence.
Peter
Old October 23rd 04, 09:48 PM
Bob Gardner
I think that Capt Dave Gwinn, the airborne radar guru, has a web site. I
don't know the URL, but I'll bet you could google it up.
Bob Gardner
"Matt Young" wrote in message
ink.net...
looking at a radar image. Are you trying to avoid all returns? Is an area
Old October 25th 04, 04:19 AM
Mike Rapoport
Where did you come up with this? All airborn weather radar systems have
the same color vs. intensity scale. For example red is always 40dbz.
Mike
MU-2
"Peter R." wrote in message
level is.
Peter
Old October 25th 04, 04:29 AM
Peter R.
Mike, I interpreted his post as referring to ground-based radar
products. I guess I made a leap of assumption that since the OP was
newly instrument rated, he was referring to pre-flight, not in-flight
radar interpretation.
But perhaps he is flying behind in-flight radar system? It would be
helpful if he posted a follow-up.
Oh, and BTW, I obviously know nothing about active radar in the cockpit.
I have WSI's downlinked Nexrad in the Bonanza, but even within this
product line WSI uses slightly different colors to represent different
intensities depending on the display (MX20 versus laptop screen, etc).
Peter
Old October 25th 04, 04:58 AM
Mike Rapoport
Weather Radar is the same as vision in another part of the spectrum. It has
certain resolution and can penetrate a certain distance into obscuring
conditions. The beam reflects off all surfaces (except the stuff stealth
aircraft are made of presumably). The value of radar is that there is a
very high corralation between the reflectivity of water droplets and
turbulence. Large droplets are formed from vertical motion.and large
droplets reflect radar much better than small ones (that is why most clouds
appear transparent to radar.). More vertical motion larger drops. You have
undoubtedly experienced the difference in drop sizes from thunderstorms vs.
stratiform rain. To evaluate a target, you first have to determine that you
are not looking at a ground return which you do by knowing your altitude,
beam width and antenna tilt setting. Generally you avoid all radar targets
containing red (40dbz) returns. You avoid the whole target, not just the
red part. I usually avoid yellow too. Even green targets are fairly bumpy
and full of ice at cruise altitudes (above FL180). Green at lower altiudes
can be smooth. There are various shapes that are associated with hail and
tornados but most people avoid all thunderstorms. The irregular targets are
just avoided by a greater distance.
Basically it comes down to the fact that anything that lifts huge amounts of
water miles into the atmosphere contains a lot of vertical shear and
therefore turbulence.
There are several books on the subject, I like Archie Trammels stuff, Dave
Gwinn's book and Severe Weather Flying by Newton. There was a great deal on
AvWeb a couple of years ago where you got Trammels video course, Severe
Weather Flying and Buck's Weather Flying for around $125 along with a
discount for his live course.
Mike
MU-2
ink.net...
Mike Rapoport
Fair enough! I assumed that he was talking about airborn radar. It is
interesting how personal experience colors our interpretation of the same
statement!
Mike
MU-2
Peter
Old October 25th 04, 06:15 AM
Nick Coleman
Mike Rapoport wrote:
Fair enough!
I've always thought that was an Australian expression (personal
experience colours our etc . Made me do a double take.
Nick
Old October 25th 04, 06:37 AM
Matt Young
I was referring to ground based radar, things I can look at before
leaving. No radar in my skyhawk.
Old October 25th 04, 08:18 AM
Stan Gosnell
Matt Young wrote in news:0i0fd.6540$KJ6.2254
@newsread1.news.pas.earthlink.net:
I have to say it's hit or miss. I've flown through areas that ground radar
had painted yellow and some red, and never saw a drop of rain, not any
turbulence. I've also seen some heavy rain that hadn't been on the TV
earlier. I've seen heavy precip shown over the place where I was sitting, on
the ground, and not a drop of rain had fallen all day. Look at radar
presentations with a jaundiced eye, and take them with a lot of salt, to mix
some metaphors. Read pireps, and ask the FSS briefer what has been going on.
Regards,
Stan
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
Radar contact before squawk David Brooks Instrument Flight Rules 20 March 25th 04 01:34 AM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 12:15 AM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 06:56 PM
