gliders+radar
Old July 22nd 06, 05:23 PM posted to rec.aviation.soaring
Capt. Geoffrey Thorpe
Default gliders+radar
"Martin Gregorie" wrote in message
Big John wrote:
Mike
Make one for pennies and few Oz vs 2.2# and $139.95.
I did a search for info about Luneberg Lenses - found plenty of
definitions/explanations/units for sale but nothing on DIY Luneberg, how
to make a ball with a radially varying refractive index or sources of
materials with suitable refractive index gradations.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
A corner reflector is easy and effective...
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/142806/0/0/radar%20reflector/All_2/mode+matchallpartial/0/0
If you make one out of foam core board and aluminium foil, be sure to keep
all the angles at 90 degrees. The overall shape can be whatever you want.
Geoff
Old July 22nd 06, 07:29 PM posted to rec.aviation.soaring
Eric Greenwell[_1_]
Ian wrote:
On Fri, 21 Jul 2006 04:47:04 +0000, Mike Schumann wrote:
Would the MTI also filter you out if you had a Mode C transponder?
Yes, it can do, depending on the settings of the filters. We had this
problem with the ATC at Cape Town International in South Africa.
There was a problem with Mode C Transponder equipped gliders flying in
wave, disappearing off the radar screens. The problem was found to be due
to speed filters in place on the equipment. Worse still the controllers
had call a technician if they wanted the filters adjusted. As I understand
the filters were set to filter out aircraft taxing on the ground at low
speed.
The local pilots and the controllers are now aware of the problem and the
radar has since been upgraded so this problem is under control.
But the problem is worth knowing about if you have a transponder in your
glider.
I'm not aware of this being a problem the USA. As I understand it, the
taxiing problem can be dealt with by by using proximity and altitude
filters, not speed filters. I'm told there are places where aircraft
squawking the VFR code (1200) may be filtered out, such as the Los
Angeles airspace, but these (very few) places are not where we are soaring!
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old July 22nd 06, 11:26 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Big John wrote:
Mike
org |
Geoff
Indeed. They've been discussed here in the past.
I think a Luneberg is not omnidirectional because the side with the
reflector on it will block incoming signals from that side, hence the
natty marine three-ball unit that gives 360 degree coverage. If I'm
right, you'd need to add another two balls (facing up and down) for
omnidirectional reflection.
OTOH a "spherical" corner reflector made from three equal sized disks of
of coreboard set at right angles (hence forming eight corner reflectors)
should be omnidirectional and probably lighter too.
org |
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Underwater Gliders Burt Compton Soaring 6 November 25th 03 04:43 AM
