My wife and I drove down from our home in Appleton to Oshkosh today (Sunday
the 23rd) for a few hours to watch arrivals. We saw the first Cessna 172 land and we were at AeroShell Square to see them pull it onto the display ramp. Way cool! On my scanner we heard some guy in a Cessna 180 yelling "I'm outta gas!!!!" on the Runway 18-36 freq. Amazingly, he made the runway, but must have landed too hard because he closed the runway for a 10 minutes or so until they were able to get his plane moved. We sat under the appoach to 09 for awhile, and listening to the radio while watching everyone coming was just amazing. Kudos to all you guys brave enough to fly in. Personally I'm glad I can just drive, it was frightening enough just watching. A Citation jet following a Piper Cub to 09 without much distance at all between them was easily the most amazing thing I saw today. Unreal! Scott Wilson |
Larry Dighera wrote: On Sun, 23 Jul 2006 19:12:09 GMT, wrote in :: On my scanner we heard some guy in a Cessna 180 yelling "I'm outta gas!!!!" on the Runway 18-36 freq. That C-180 pilot needs some retraining. It would be a shame for him and his passengers to become NTSB statistics. I'm sure the local FSDO Inspector had a word with him after they got his airplane out of the way. I wonder how many mishaps occur annually at Air Venture? That's easy. Just read the NTSB and FAA accident pages each day. |
That's easy. Just read the NTSB and FAA accident pages each day. There has already been a double fatal crash, today. At around 8:45 this morning, an experimental came down short of 9/27, and both of the occupants died. The Oshkosh papers had no more details, but I was able to find one source that said they were from Washington state. No other details, as to why they came down short, or what kind of plane. It is a rare year that at least 6 don't die either on the way to or on the way home from Osh. Some years there are no fatals in the immediate area, and some years there are several fatals due to airport operations. -- Jim in NC |
Had an interesting flight this year into OSH because of this crash.
Apparantly the ripple effect piled up the holds around Rush Lake, and then Green Lake. When I arrived in my 172 from Madison, everyone was to enter the hold at Green Lake (which is new this year), or to hold outside somewhere else (anywhere else). Coming up on Ripon, I spied a Mooney, got behind him and had pretty smooth sailing entering the hold over Green. The radio was alive with two different calls of bingo fuel, as well as all sorts of different unidentified calls to remind people: "come on, 90 knots", or "speed it up Ercoupe" and so forth and so on. One could also tell that Rush was packed with planes, that were slowly then allowed to re-enter the approach over Ripon and start up the tracks to Fisk. One problem that became quite apparant to those of us holding over Green Lake was that some of our not so scrupulous bretheren (or clueless) just barreled on thru from all points of the compass, past Green Lake, past Ripon, and on up the tracks. This of course gummed up the works for the controllers trying to work people out of the hold over Rush, but eventually things calmed down to the point where the Rush Lake hold was cleared, and those of us over Green were allowed to proceed. It got a little challenging trying to keep your head on a swivel, while tracking the guy ahead of you and trying to ignore the guy behind you, whose shadow I could see on the ground pretty close behind me (makes me thankful I had a 172C with no back window!), staying at 90 and 1800 and 1/2. I "only" spent about an hour in the hold, many more were there longer, on the order of 2+ hours. Those flying today probably also chuckled about the (ultralight?) pilot who admitted he didn't have the notam with him for the u/l proceedure. DOH! This is the third time I've flown in, and all in all a pretty educational experience. While holding over the lake I thought about the congestion on the radio, and I guess my thought about this Green lake holding pattern, is that it is probably not a bad idea, but having a seperate freq for some controllers moved even more forward to Ripon might help sort things out, while still keeping the Fisk frequency relatively clear to manage the pipeline from Ripon to OSH. It would also help control the flow starting at Ripon, rather than Fisk. But then again, the Fisk approach procedure has worked so well for so long.... Ryan Wubben Co-Chairman, EAA Flight Line Operations |
![]() wrote Had an interesting flight this year into OSH because of this crash. Apparantly the ripple effect piled up the holds around Rush Lake, and then Green Lake. When I arrived in my 172 from Madison, everyone was to enter the hold at Green Lake (which is new this year), or to hold outside somewhere else (anywhere else). Coming up on Ripon, I spied a Mooney, got behind him and had pretty smooth sailing entering the hold over Green. The radio was alive with two different calls of bingo fuel, I wonder if they need a new procedure to land people at one of the out-airports, to relaunch them back to OSH, when things like this happen. I also wonder if the holds were what bit the 180? driver that landed so hard on 36 , after the "I've run out of gas" call that another poster mentioned. It makes someone's advice, on this very group a couple days ago, to not try and come in toward OSH on fumes - to land somewhere out, and arrive with plenty of fuel - to be even better advise. -- Jim in NC |
On Sun, 23 Jul 2006 22:04:56 -0400, "Morgans"
wrote in :: It is a rare year that at least 6 don't die either on the way to or on the way home from Osh. That is truly tragic and pathetic. Is that the best airmen can do? Some years there are no fatals in the immediate area, and some years there are several fatals due to airport operations. I would say they were probably due to pilot incompetence rather than blame airport operations. What sort of image do such statistics about airmen conger in the minds of the lay public? What sort of program does the Experimental Aircraft Association have in place to reduce the death toll resulting from AirVenture attendance? |
Not to worry! Skylune is on the job, ready, willing and able to report all
mishaps, house slammings, stupid pilot tricks, etc. My record so far is good: I broke the news well over a year ago that the FAA was going to try to split the GA community over the user fee issue (business vs. recreational GA). (I am now predicting that there will be user fees, not on GA, AT FIRST -- Boyer is correct on this.. This will happen when the current funding formula exprires next year.) I broke the news on the death of the Aussie AOPA president (which, if you only read Boyer's stuff, you'd have never known occurred). I told you that the ADIZ will STAND, despite the thousands of identical, rhetorical argumemnts posted on the docket (AOPA retread arguments), and it looks like I will be correct on that point too. I posted news on selected crashes, including the one at the Sun and Fun earlier this year. Should there be any shenanigans at OSH, I will report the unvarnished details. |
Scooped!
You're Invited to the 4th Annual Rec.Aviation Oshkosh Party(s)! | [email protected] | Home Built | 5 | July 6th 06 10:04 PM |
You're Invited to the 4th Annual Rec.Aviation Oshkosh Party(s)! | Jay Honeck | Piloting | 0 | June 27th 06 04:58 AM |
Oshkosh Reflections | Jay Honeck | Home Built | 54 | August 16th 05 09:24 PM |
Oshkosh Reflections | Jay Honeck | Piloting | 45 | August 7th 05 02:31 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
