barrel roll in 172
Old July 23rd 06, 07:10 PM posted to rec.aviation.piloting
Larry Dighera
Default barrel roll in 172
On Sun, 23 Jul 2006 14:00:37 GMT, Matt Whiting
wrote in ::
Larry Dighera wrote:
On Sun, 23 Jul 2006 01:54:35 GMT, Matt Whiting
wrote in ::
Flight load factor
Flaps up = +4.4 G's and -1.76 G's
So, in inverted flight a C-172 has only a 76% of a G margin to carry
additional G force. That isn't much.
Thanks.
No, 176% of a G.
No. A _margin_ of only a 76% of a G to carry G forces in addition to
the one G natural force.
When you are pulling negative G, there is no one natural G force.
While you are in the vicinity of the Earth, your aircraft is being
acted upon by the Earth's one G gravitational force.
If you are flying straight and level while inverted, the airframe is
experiencing -1G, not 0 G.
That provides the remaining 0.76 (76%) of a G of the C-172's negative
load factor specification of -1.76 to carry the load of any
acceleration that may subsequently occur.
It takes -1 G of acceleration to counter gravity and get you to 0 G.
Agreed.
You can then add -1.76 G of additional acceleration and still be within load
limits.
That analysis presumes the aircraft is not inverted.
The negative G load factor is referenced to 0 G, not 1 G
straight and level.
Are not both the positive and negative load factors referenced to 0 G?
You don't set your G-meter to 0 when you are on the taxiway; you set
it to read 1 G, right?
We were discussing the negative load that might be encountered during
the inverted recovery from a barrel roll, so the earth's gravity would
add to any accelerative force while the aircraft is inverted, right?
  #112
Old July 23rd 06, 08:13 PM posted to rec.aviation.piloting
Morgans[_3_]
"john smith" wrote in message
Matt Whiting wrote:
When you are pulling negative G, there is no one natural G force. It
takes -1 G of acceleration to counter gravity and get you to 0 G. You
limits. The negative G load factor is referenced to 0 G, not 1 G
straight and level.
Is negative G an up force or a down force?
I'll disagree, here.
Straight level flight, right side up is 1 G
Free-fall, so you are not touching the seat or seatbelt is O G
Straight level flight upside down, is -1G
If the plane is upside down, and pushes up elevator, until a100KG weight
weighs 176KG, that is a -1.76 G factor. Not much extra for upside down
flight, is it.
Jim in NC
  #113
Old July 23rd 06, 09:18 PM posted to rec.aviation.piloting
RomeoMike
If the barrel roll is performed correctly it is a +G maneuver
throughout, even while inverted.
  #114
Old July 24th 06, 12:10 AM posted to rec.aviation.piloting
Larry Dighera
On Sun, 23 Jul 2006 14:18:23 -0600, RomeoMike
wrote in
While that may be true, it isn't pertinent to this branch of this
message thread:
Newsgroups: rec.aviation.piloting
Subject: barrel roll in 172
Message-ID: 2SQvg.78944$ZW3.35114@dukeread04
Date: Thu, 20 Jul 2006 14:31:05 -0500
The issue is recovery from a botched barrel roll, such as in
inverted stall followed by a high speed dive and too strong
a pull on recovery.
  #115
Old July 25th 06, 05:36 AM posted to rec.aviation.piloting
Jay Beckman
"Jim Macklin" wrote in message
news:_aMvg.78918$ZW3.55764@dukeread04...
Didn't Lorena Bobbitt say that?
Not sure if we've ever seen the entire quote as her post was "snipped."
Jay B
  #116
Old July 25th 06, 11:09 PM posted to rec.aviation.piloting
Matt Whiting
straight and level.
It is an acceleration opposite the normal acceleration due to gravity,
so it would be downward with respect to the airframe.
Matt
  #117
Old July 25th 06, 11:12 PM posted to rec.aviation.piloting
Matt Whiting
wrote in ::
wrote in ::
Flight load factor
Thanks.
No, 176% of a G.
If you had said 76% of a negative 1 G, I'd have agreed with you. :-)
Just saying of a G, implies positive 1 G by most conventions.
Matt
  #118
Old July 25th 06, 11:21 PM posted to rec.aviation.piloting
Peter R.
What about the case of a fighter jet climbing on afterburners at a steep
nose-high attitude quickly rolling forward through the horizon to a steep
nose-low attitude? Wouldn't the negative G force be considered an upward
force with respect to the airframe?
Peter
  #119
Old July 26th 06, 12:17 AM posted to rec.aviation.piloting
Larry Dighera
On Tue, 25 Jul 2006 18:21:54 -0400, "Peter R."
wrote in ::
Of course.
  #120
Old August 1st 06, 02:24 AM posted to rec.aviation.piloting
john smith
More accurately, doesn't it depend on your frame of reference?
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
