Hey all. I recently inquired about replacing my dead transponder (KT-76) with a worn out cavity. I've since bought an e-bay
special KT-79. I haven't installed it yet, but have powered it up on the bench. Things seem OK, except that the VFR button sends the unit to code "4263" rather than "1200." Aside from the obvious "It's broke" response, is there any sort of programmability to this? I've also got a KT-197 COM that has obscurely available "memories" obtainable via turn, push, twist, stand-on-your-head, twist-twist combination. Anyone know if the KT-79 has has something similar to set what "VFR" means, or am I just hosed? I do not know if the code corresponds to what's transmitted yet. Just grasping as straws here... Thanks, -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Hey all. I recently inquired about replacing my dead transponder (KT-76) with a worn out cavity. I've since bought an e-bay special KT-79. snip Anyone know if the KT-79 has has something similar to set what "VFR" means, or am I just hosed? I was wondering if you ever found a transponder after inquiring about mine, as I never heard back from you. Sorry to read of your problems. -- Peter |
![]() I've actually been on vacation for a month or so. Haven't yet caught up on the usenet since I've been back. If the VFR quick-recall is broken, I can deal with that I guess.... it's still better than a broken KT-76.... ![]() -Cory Peter R. wrote: : wrote: : Hey all. I recently inquired about replacing my dead transponder (KT-76) : with a worn out cavity. I've since bought an e-bay : special KT-79. : snip : Anyone know if the KT-79 has has something similar to set what "VFR" means, : or am I just hosed? : I was wondering if you ever found a transponder after inquiring about mine, : as I never heard back from you. : Sorry to read of your problems. : -- : Peter -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() I think it's reasonable to assume there's some way of setting the VFR code, as it varies around the world. 4263 is an internal code allocated to Albuquerque, I believe, so it's probably a company squawk for a common user like an air ambulance. I have a KT-79 maintenance manual but it has no mention of how to setting the VFR code. I'll try to round-up an install manual to set if it's in there... |
![]() Here's another idea. On the KT-73 and the KT-76C, you put the unit in standby, enter the code, hold the IDT button, and then press and release the VFR button. Since they used the same method on these two, probably worth trying it on the KT-79, too. |
Mike Granby wrote:
: Here's another idea. On the KT-73 and the KT-76C, you put the unit in : standby, enter the code, hold the IDT button, and then press and : release the VFR button. Since they used the same method on these two, : probably worth trying it on the KT-79, too. I'll try that combo on the bench tomorrow when I've got a current-limited supply available. Will report back... -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Mike Granby wrote:
: Here's another idea. On the KT-73 and the KT-76C, you put the unit in : standby, enter the code, hold the IDT button, and then press and : release the VFR button. Since they used the same method on these two, : probably worth trying it on the KT-79, too. Just to report back, that particular key combination worked! Now 'VFR' = 1200. I'll probably install it this weekend to see if the unit itself works. Transponders are particularly irritation for a gumshoe avionics guy like myself to troubleshoot since without an interrogator you have to fly it to test anything. Oh well... fingers crossed and thanks a bunch for the info. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Seeking Northrop Gamma info | Dillon | Restoration | 3 | December 12th 05 04:45 AM |
Seeking V2C info | Ted Wagner | Soaring | 0 | September 2nd 05 01:55 AM |
Operation without a transponder | flyer | Piloting | 11 | September 14th 04 08:48 AM |
seeking info on self etching primer | gromit | Restoration | 1 | July 11th 03 01:02 AM |
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan | David Megginson | Instrument Flight Rules | 0 | July 9th 03 03:04 PM |
