Seeking KT-79 transponder install/operational info
Old July 25th 06, 11:52 PM posted to rec.aviation.owning
Default Seeking KT-79 transponder install/operational info
Hey all. I recently inquired about replacing my dead transponder (KT-76) with a worn out cavity. I've since bought an e-bay
special KT-79. I haven't installed it yet, but have powered it up on the bench. Things seem OK, except that the VFR button sends the
unit to code "4263" rather than "1200." Aside from the obvious "It's broke" response, is there any sort of programmability to this? I've
also got a KT-197 COM that has obscurely available "memories" obtainable via turn, push, twist, stand-on-your-head, twist-twist
combination. Anyone know if the KT-79 has has something similar to set what "VFR" means, or am I just hosed? I do not know if the code
corresponds to what's transmitted yet.
Just grasping as straws here...
Thanks,
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old July 26th 06, 12:05 AM posted to rec.aviation.owning
Peter R.
special KT-79.
snip
or am I just hosed?
I was wondering if you ever found a transponder after inquiring about mine,
as I never heard back from you.
Sorry to read of your problems.
Peter
Old July 26th 06, 12:13 AM posted to rec.aviation.owning
I've actually been on vacation for a month or so. Haven't yet caught up on the usenet since I've been back.
If the VFR quick-recall is broken, I can deal with that I guess.... it's still better than a broken KT-76....
-Cory
Peter R. wrote:
: wrote:
: Hey all. I recently inquired about replacing my dead transponder (KT-76)
: with a worn out cavity. I've since bought an e-bay
: special KT-79.
: snip
: Anyone know if the KT-79 has has something similar to set what "VFR" means,
: or am I just hosed?
: I was wondering if you ever found a transponder after inquiring about mine,
: as I never heard back from you.
: Sorry to read of your problems.
: Peter
Old July 26th 06, 01:02 AM posted to rec.aviation.owning
Mike Granby
I think it's reasonable to assume there's some way of setting the VFR
code, as it varies around the world. 4263 is an internal code allocated
to Albuquerque, I believe, so it's probably a company squawk for a
common user like an air ambulance. I have a KT-79 maintenance manual
but it has no mention of how to setting the VFR code. I'll try to
round-up an install manual to set if it's in there...
Old July 26th 06, 01:14 AM posted to rec.aviation.owning
Mike Granby
Here's another idea. On the KT-73 and the KT-76C, you put the unit in
standby, enter the code, hold the IDT button, and then press and
release the VFR button. Since they used the same method on these two,
probably worth trying it on the KT-79, too.
Old July 26th 06, 01:41 AM posted to rec.aviation.owning
Mike Granby wrote:
: Here's another idea. On the KT-73 and the KT-76C, you put the unit in
: standby, enter the code, hold the IDT button, and then press and
: release the VFR button. Since they used the same method on these two,
: probably worth trying it on the KT-79, too.
I'll try that combo on the bench tomorrow when I've got a current-limited supply available.
Will report back...
-Cory
Old July 26th 06, 01:11 PM posted to rec.aviation.owning
Just to report back, that particular key combination worked! Now 'VFR' =
1200. I'll probably install it this weekend to see if the unit itself works.
Transponders are particularly irritation for a gumshoe avionics guy like
myself to troubleshoot since without an interrogator you have to fly it to test
anything. Oh well... fingers crossed and thanks a bunch for the info.
-Cory
Seeking Northrop Gamma info Dillon Restoration 3 December 12th 05 04:45 AM
Seeking V2C info Ted Wagner Soaring 0 September 2nd 05 01:55 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
seeking info on self etching primer gromit Restoration 1 July 11th 03 01:02 AM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 03:04 PM
