HVN VOR-A -- why such a high MDA?
Old October 31st 04, 12:34 AM
Roy Smith
Default HVN VOR-A -- why such a high MDA?
The VOR-A at New Haven
(http://www.myairplane.com/databases/...s/00671VG2.PDF) has an
MDA of 720, which is about 300 feet higher than the towers in the area.
The VOR-2
(http://www.myairplane.com/databases/...s/00671VG2.PDF) gets
you down to 380, and has to deal with the same towers. Why does it get
to have an MDA 340 feet lower than the VOR-A?
In fact, the VOR-A is almost perfectly lined up with runway 32; I don't
see why it couldn't have been the VOR-32 with an MDA about 300 feet
lower. Any of you TERPs-heads out there understand what's going on here?
Old October 31st 04, 01:21 AM
Steven P. McNicoll
"Roy Smith" wrote in message
The VOR-2
Apples and oranges. You're comparing the straight-in MDA of the VOR RWY 2
to the MDA of the VOR-A. The VOR-A has only a circling MDA, which is 720
feet, the same as the circling MDA of the VOR RWY 2.
Old October 31st 04, 01:03 AM
Roy Smith
In article k.net,
The VOR-2
Yeah, but the point of my question was, "Why didn't they publish
straight-in minimums for the VOR-A and call it the VOR-32?"
Old October 31st 04, 01:14 AM
Steven P. McNicoll
2
I don't know, I'm no TERPS expert, but I'd wager it's because the MAP is
beyond the runway 32 threshold.
Old October 31st 04, 04:35 AM
Andrew Sarangan
"Steven P. McNicoll" wrote in
link.net:
RWY 2
is 720 feet, the same as the circling MDA of the VOR RWY 2.
is beyond the runway 32 threshold.
But there are straight-in approaches with the MAP well past the runway
threshold. Look at VOR24@RID for example.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old October 31st 04, 12:22 PM
Ron Rosenfeld
The VOR-2
I'm not sure, but I wonder if it has something to do with the Missed
Approach path. The MA segment for the VOR-A seems to come a lot closer to
the 400+' towers than does the MA segment for the VOR-2.
--ron
Old October 31st 04, 03:31 PM
Greg Esres
In addition to the runway alignment issue, there are two other
criteria used for issuing straight in minimums: descent gradients
cannot exceed 400 ft/nm and the course must intersect the runway
center line within a certain distance of the of the runway threshold,
3000-5200 ft in this instance.
The descent gradients seem OK here, so my guess would be the point of
course intersection was out of tolerance.
Old October 31st 04, 03:43 PM
There are three requirements that must be met to establish straight-in
minimums:
1. Final approach course alignment with runway.
2. Descent gradient
3. Limits on where final approach course crosses or parallels the runway
centerline, extended.
Number 3 is impossible to assess without the source data.
Finally, flight inspection can nix the straight-in minimums if they don't
like the way the approach flies.
The VOR-2
Old October 31st 04, 09:42 PM
Roy Smith
The FAC is based on a VOR radial; by picking a radial up or down a
couple of degrees, they can make the FAC intersect the extended
centerline anywhere they want. The approach is over water and the VOR
is on the field, so neither terrain or signal quality should be an issue
for which radial they use.
Old October 31st 04, 11:29 PM
Steven P. McNicoll
"Andrew Sarangan" wrote in message
Interesting. One wonders why this isn't a VOR-A approach.
High Price of Flying Wires? PWK Home Built 34 October 8th 17 08:24 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
high impedance, low impedance? JFLEISC Home Built 5 April 11th 04 06:53 AM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
High performance homebuilt in the UK NigelPocock Home Built 0 August 18th 03 08:35 PM
