Wondering What Light Sport Can Do For You?
Old July 28th 06, 02:17 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Duniho
Default Wondering What Light Sport Can Do For You?
"Jim Macklin" wrote in message
news:yR8yg.84361$ZW3.33772@dukeread04...
I think you completely misread my posts and the intention.
Landing gear down is important on land and gear up on water
is even more important.
So you are agreeing with my point.
It seems that even a sport pilot with just a few hours could
be taught to raise and lower the gear.
You'd think a full-fledged Private certificate holder could be taught the
same. And yet, landings with the gear in the wrong position continue to
happen.
And that's my point. The Sport Pilot rules are specifically designed to try
to remove some of the more common opportunities for error that the general
pilot population runs into. It seems plausible that the FAA was trying to
address one of those common opportunities by restricting the type of landing
gear an LSA airplane is allowed to have.
I think as much as
safety, the FAA position on LSA is based on retractable
landplanes exceeding the speed limit, something no
floatplane will do.
I doubt that. The airspeed limit can be exceeded even with fixed-gear
designs, and it's simple enough to flight test any design to find whether it
exceeds the LSA speed limit or not. There should be no reason to add
addition design restrictions for that purpose.
Pete
  #32
Old July 28th 06, 02:25 AM posted to rec.aviation.owning,rec.aviation.piloting
Jim Macklin
I think that you are agreeing with me on the basic point, I
never said that landings with the gear in the wrong position
are safe. I also not that high time commercial and ATP and
even CFI land gear up on runways, the USAF landed a C130 on
the water runway at Patterson, LA many years ago. It was
night and the crew saw the runway lights and landed. The
runway they selected was water with green edge lights and
white threshold lights. Brings to mind that 3,000 foot wide
runway only 150 feet long.
I'm just not look for an argument.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Peter Duniho" wrote in
message ...
| "Jim Macklin" wrote
in message
intention.
water
could
could be taught the
| happen.
that the general
FAA was trying to
the type of landing
| I think as much as
| floatplane will do.
with fixed-gear
to find whether it
reason to add
| Pete
  #33
Old July 28th 06, 03:45 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Duniho
news:%Pdyg.84400$ZW3.14020@dukeread04...
If it makes your ego feel better to word it that way, that's fine with me.
Even though it was I who first brought up the issue of the hazard of
gear-down water landings.
  #34
Old July 28th 06, 03:55 AM posted to rec.aviation.owning,rec.aviation.piloting
Jim Macklin
Is this sweeps week?
message ...
| "Jim Macklin" wrote
in message
hazard of
  #35
Old July 28th 06, 04:45 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Duniho
news:lbfyg.84408$ZW3.66092@dukeread04...
Yes, and the ratings count double.
  #36
Old July 28th 06, 05:19 AM posted to rec.aviation.owning,rec.aviation.piloting
Jim Macklin
LOL
message ...
| "Jim Macklin" wrote
in message
  #37
Old July 28th 06, 07:39 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
cavelamb
Orval Fairbairn wrote:
In article et,
cavelamb wrote:
Morgans wrote:
"Da Monk" wrote
http://groups.yahoo.com/group/Sport_Aircraft/
Is that guy landing that thing "wheels up" on the grass or did he
retract them that early in the takeoff?
Low pass? With a seaplane, he could have landed, and done nothing more than
scratched the paint.
A neighbor at Zuehl (grass runway) landed his 210 gear up a couple years back.
The ONLY dammage (other than the curly prop) was an antenna on the belly.
Heck, the pain wasn't even scratched!
Richard
Oh, I'm SURE that the pain WAS scratched! In fact, I'm sure that the
pain was in a bleeding wallet!
I saw that after I posted it...
No dammage to the PainT...
You are right about the bleeding wallet though.
That prop still hasn't been replaced.
Sad...
Ricahrd
  #38
Old July 29th 06, 06:26 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
Highflyer
"Jose" wrote in message
. com...
If I landed a 210 on its belly, I can guarantee you my pain will be more
than scratched. But if it has a curly prop, chances are good it will need
an engine teardown.
Jose
Actually chances are not "good" it will need an engine teardown. The FAA
has issued a circular to all IA's stating
that "any prop strike, even one where the engine is not stopped but only
suffers a loss of RPM" is likely to cause unseen internal damage and will
require an inspection teardown to be returned to service. Using a dial
indicator on the prop flange to check for runout is no longer considered
sufficient inspection.
I recently saw a Lycoming where the prop flange was as close to perfect as
they get. No runout at all. However the crank was in two pieces. It had
broken between the two rows of cylinders. The break was diagonal and the
engine still ran and developed power. However, it did stop pretty quickly
when you pulled the mixture out!
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
  #39
Old August 1st 06, 03:31 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
Gilan
why wouldn't you discuss LSA in rec.aviation.piloting?
Have a good day and stay out of the trees!
See ya on Sport Aircraft group
"Larry Dighera" wrote
We discuss LSA in rec.aviation.piloting.
  #40
Old August 1st 06, 04:17 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student,rec.aviation.ultralight
Larry Dighera
On Mon, 31 Jul 2006 19:31:57 -0700, "Gilan" wrote in
y2zzg.5652$Mz3.3896@fed1read07::
As I recall, it was this sentence of yours (apparently lacking a verb)
that provoked that follow up:
"Discussions on the new (LSA) Light-Sport Aircraft and Sport Pilot
license."
As a multi-decade participant in Usenet, I also understood, that
YahooGroups, although flashier, lacked the ability to attract a
readership anywhere near as large as that of Usenet. This newsgroup
generates about 6,000 messages per month.
While GoogleGroups archives Usenet and provides a public portal, it
too, like YahooGroups, provides an alternate communications forum
separate from Usenet, thus fractionalizing the content over multiple
forums. That makes the information more difficult to search.
To be fair, I congratulate your LSA discussion group for its continued
activity since November 2002. And I wish you oodles of success in
attracting participants.
Got to fly a light sport aircraft Jay Honeck Piloting 13 May 26th 06 09:30 PM
Towing w LSA (Light Sport Aircraft) Jeffrey Banks Soaring 12 September 14th 05 01:48 AM
Sport Light Aircraft regs Bill Daniels Soaring 13 July 22nd 04 07:02 PM
Mooney to Offer Light Sport Airplane Rick Pellicciotti Home Built 4 September 24th 03 01:08 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 06:11 AM
