Channel Width
Old July 30th 06, 02:52 AM posted to rec.aviation.piloting
thejim
Default Channel Width
This question relates to VOR.
I read that when VORs where increasing continuously in number in the
beginning of their "career" there was a lack of available frequencies.
So they increased the frequencies by increasing the number of chanels
and they did that by decreasing the chanel width e.x from 100kH width
to 50kH width.
Can you explain me please how this(meaning increase of channels by
reducing their width) will increase the number of available frequencies
for the increasing number of VOR stations.
Old July 30th 06, 03:04 AM posted to rec.aviation.piloting
Jose[_1_]
It means you can put channels in between existing channels. If done
right, there is no interference. It requires that existing transmitters
be modified (if they are not already "narrow" enough) so that there in
fact is no interference.
Jose
Old July 30th 06, 03:19 AM posted to rec.aviation.piloting
Jim Macklin
VOR is line of sight so the same frequency can be used over
and over as long as there stations are located far enough
apart and the "service volume" is protected. If you look at
the useable distance for a VOR signal, you will see that
very high altitudes are shorter range than lower and middle
altitudes because the interference is greater at high
altitudes.
Better quality radio receivers can reject interference,
radio band width can't be increased because all the
available frequencies have been assigned. But by making a
channel narrower, you can double the number of possible
channels each time you narrow the channel. Going from 100
KHz to 25 KHz quadrupled the number of channels. Forty
years ago, 90 comm. channels and 50 VOR was common and now,
Comm. channels are in the thousands. VOR is less suited to
adding more and more channels because of the location
issues.
If you have 108 to 117 for channels and you can only tune
whole numbers, you get ten channels. If you can tune 108.5,
you get 20 channels. If you tune 108.1 you get 100 channels
and 108.010 gets a 1,000. But if the power is high, it is
harder to reject the nearby station.
The FAA flight tests naviads and one of the issues is clear
radio reception.
James H. Macklin
ATP,CFI,A&P
"thejim" wrote in message
number in the
frequencies.
number of chanels
100kH width
| to 50kH width.
channels by
Old July 30th 06, 05:41 AM posted to rec.aviation.piloting
Peter Duniho
"Jose" wrote in message
. net...
And that the receivers also be updated to ensure that they can select within
the narrow enough frequency range (and of course, be tuned to the
intermediate frequencies as well).
Pete
Old July 30th 06, 08:11 AM posted to rec.aviation.piloting
Dave S
to 50kH width.
Older radios, with older technology, were capable of transmitting on
their tuned frequency, but the signal spilled over onto neighboring
frequencies.. this dictated fairly wide channel spacing... to prevent
interference...
Newer radios with newer innards are capable of much more precise
transmission, with much less "width" to the spillover. By mandating
everyone use the newer radios to transmit, you in effect open up more
"channels" in between the existing ones that you can use.
Right now we have (on com frequencies) 25 khz spacing between designated
frequencies.. Many of the new radios being sold are already capable of
operating at the NEXT spacing designation, somewhere on the order of 8.3
khz, which will triple the existing amount of aviation band com freqs
(from 760 to over 2000).
By simply halving the nav frequency spacing, you can double the number
of nav frequencies available. Navs are currently at 50 khz spacing, if I
remember correctly.
Dave
Old July 30th 06, 01:37 PM posted to rec.aviation.piloting
Roy Smith
"Jim Macklin" wrote:
Going from 100 KHz to 25 KHz quadrupled the number of channels. Forty
years ago, 90 comm. channels and 50 VOR was common and now, Comm.
So why are we still stuck with almost every uncontrolled field in existence
having their CTAFs crammed into just 2 or 3 freqs? How many years is it
since you could even buy a radio that didn't have 25 khz spacing?
Old July 30th 06, 01:47 PM posted to rec.aviation.piloting
Bob Noel
Isn't it "interesting" that nearly all the new AWOS frequencies require 25 kHz
spacing? Yet they can't change any CTAF frequencies.
Bob Noel
Looking for a sig the
lawyers will hate
Old July 30th 06, 02:39 PM posted to rec.aviation.piloting
Jim Macklin
government assigns the channels, we are stuck with it.
"Roy Smith" wrote in message
| "Jim Macklin"
channels. Forty
now, Comm.
field in existence
many years is it
spacing?
Old July 30th 06, 05:22 PM posted to rec.aviation.piloting
RST Engineering
You can buy legal 1, 6, 90, and 360 channel radios.
existence
Old July 30th 06, 05:43 PM posted to rec.aviation.piloting
Jim Macklin
But they now must meet the latest standards for bandwidth,
etc. Many of the old Narco, ARC and other radios cannot be
used.
"RST Engineering" wrote in message
| Jim
| "Jim Macklin"
channels. Forty
now, Comm.
field in
| existence
many years is it
spacing?
Pair of new in box, unused, EAC-1 Single Channel EGT/CHT/OAT Acroav8r Aviation Marketplace 1 May 18th 06 11:26 AM
Pair of new in box, unused, EAC-1 Single Channel [email protected] Home Built 0 May 10th 06 07:17 AM
Discovery Wings Channel ??? Bush Piloting 7 November 15th 04 04:07 PM
Discovery Wings Channel ??? Andy Asberry Home Built 0 November 13th 04 05:11 AM
History Channel show update Roger Long Piloting 0 October 11th 04 05:06 PM
