Scared of mid-airs
Old July 30th 06, 12:06 PM posted to rec.aviation.piloting,rec.aviation.student
Default Scared of mid-airs
Stefan wrote:
The most dangerous near misses are those which you'll never know.
Stefan
I can see where the original poster's apprehension stems from, having
flown once, from the FO's seat. I wasn't at all inhibited in doing a
stall, steepish banks and other jiggles - in fact, I did them all
merrily. But I was petrified throughout the ride because the craft, a
JetFox, didn't have a radar and the only way of recognizing traffic in
the immediate neighborhood was by actually looking out the window. Just
felt a sense of being helplessly vulnerable in an open sky. It might go
away if I fly more, because the Capn seemed very assured
Is it correct to assume that one can always be whacked by traffic
coming from between the 4 and 8 o'clock positions, especially if the
other craft is faster and climbing?
Ramapriya
  #112
Old July 30th 06, 01:10 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Military fighter radar sees other airplanes that are in the
area (a small area) in front of the fighter. That's why the
has ground based surveillance radar and airborne
surveillance radar, such as AWACS, so somebody can tell the
fighter pilot that there is a target at his 2 or 3 o'clock
position, 20 miles.
The radar in civilian airplanes does not see other airplanes
because the radar is on a frequency band designed to see
water droplets and the antenna is too small to have a
resolution high enough to see things like airplanes or cars.
Why does it see water, because the water droplet resonates
and returns a good return to the radar, if it is liquid.
Ice in the form of hail is hard for an airborne radar to see
since the solid water doesn't have the same properties.
Bottom line is that, you can't use weather radar to detect
targets, you might be able to see an oil tanker broadside at
5 miles, but not head on. What does work is systems that
detect the transponder in the other airplane and present a
warning display.
James H. Macklin
ATP,CFI,A&P
never know.
| Stefan
from, having
in doing a
them all
the craft, a
window. Just
sky. It might go
traffic
especially if the
| Ramapriya
  #113
Old July 30th 06, 01:40 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin wrote:
What does work is systems that detect the transponder in the other airplane and present
a warning display.
James H. Macklin
ATP,CFI,A&P
That's what I went, a tad naively, expecting to find, although Bob
Moore had given me a sneak peek at what I could reasonably hope to see,
which was *not* an A320 layout
But nothing could prepare me from the vulnerability I felt when
airborne.
Ramapriya
  #114
Old July 30th 06, 02:28 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
It is a big sky. Years ago the FAA [it is said] did a study
to show how safe aviation would be if all their ATC plans
were fully funded and they could control every airplane from
taxi to shutdown in the US airspace system. They came up
with some tens of millions of flight hours between mid-air
collisions, something like a chance every hour of
0.000000015 collisions per hour. Somebody asked what kind
of improvement this was over no control at all. They had a
university do a study and the number came back...
0.000000019.
Big sky, few airplanes. The hazards at and near the busy,
big airports. To a degree, the rules that say all traffic
flies at cardinal altitudes concentrates traffic at certain
places, such as 17,500 feet or 10,000 feet because those
altitudes [in the USA] are where rules change.
You do clearing turns, shallow turns and you look for other
airplanes. Airplanes at your altitude look to be on the
horizon, airplanes above you are above the horizon and
airplanes below you are below the horizon and are harder to
see because of the ground. But you look for moving shadows
on the ground at low altitude. You run all you lights and
hope the other guy is also. You look out the windows. You
look for small dark spots that don't seem to move because
things on a collision course have zero relative motion.
But the human eye seems motion better than it does small
dark spots.
In areas of high traffic, there are often radio procedures
used to announce intentions. There are IR detectors that
can "see" the strobe lights on an airplane and they do have
systems that can detect the transponder of other aircraft.
And they are developing data-link systems that will put a
ground based radar display in the cockpit of those airplanes
and countries that can afford the cost.
James H. Macklin
ATP,CFI,A&P
ps.com...
| a warning display.
| James H. Macklin
| ATP,CFI,A&P
although Bob
hope to see,
when
| airborne.
| Ramapriya
  #115
Old July 30th 06, 02:32 PM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Default PED Scared of mid-airs
Near miss. No, I've never had one that almost missed me.
That would be a "nearly miss". A near miss is a miss. A deep lake is a
lake. A red rose is a rose. A heavy rain is a rain.
Jose
  #116
Old July 30th 06, 02:45 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
ATC has a box around each IFR airplane, no other airplane
should be in that box. The size of the box changes, but in
general [somebody will surely correct me] is 1,000 above and
below within a distance of from 5 to 20 miles. Anything
closer and it is a near-miss. When you are close enough to
see the individual rivets or make out the color of the other
pilot's eyes, it is also a near-miss.
{I know, loss of separation}
"Jose" wrote in message
deep lake is a
| Jose
music.
  #117
Old July 30th 06, 03:39 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Larry Dighera
On Sun, 30 Jul 2006 08:28:06 -0500, "Jim Macklin"
wrote in
Mt2zg.84637$ZW3.19317@dukeread04::
dark spots.
Military flights, though exempt from FAR § 91.117's 250 knot maximum
speed restriction below 10,000', do not detect Mode C transponder
beacons (no TCAS).
[rec.aviation.military added]
  #118
Old July 30th 06, 05:35 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Jim Macklin
True, but often they have an AWACS or military ground radar.
"Larry Dighera" wrote in message
| wrote in
other
to
shadows
and
You
| dark spots.
procedures
have
aircraft.
airplanes
knot maximum
transponder
| beacons (no TCAS).
  #119
Old July 30th 06, 06:01 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.military
Ed Rasimus[_1_]
On Sun, 30 Jul 2006 11:35:46 -0500, "Jim Macklin"
No kidding? They also often have their own radar and have been trained
to look at it and interpret it with greater detail than following an
up/down arrow on a TCAS. They've also been trained to provide their
own separation and to operate in areas without the
all-seeing/all-knowing motherliness of Air Traffic Control.
Nevertheless as Mr. Dighera incessantly points out, "stuff"
happens--but it ain't murder.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
  #120
Old July 30th 06, 06:30 PM posted to rec.aviation.piloting,rec.aviation.student
Orval Fairbairn
In article 5Z2zg.84642$ZW3.6823@dukeread04,
The above posting is not correct. IFR planes have a unique box *only*
against other IFR traffic -- VFR traffic is not mentioned. That is why
you *have* to keep a lookout for traffic when you are under IFR.
An IFR may report a "near miss" when a VFR does not consider it to be a
threat. The "1000 above or below within 5 to 20 miles" applie only to
Class A airspace, *not* to B, C, D, etc.; else traffic flow would
trickle to a halt.
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
