#11
Jim Macklin wrote:
government assigns the channels, we are stuck with it. An airport may request a different frequency assignment, it is not that big of a deal... just fill out some forms. Of course FAA must be in the loop as well. The bigger possible PIA for the airport is that it must then modify any equipment involved in pilot controlled runway/VASI/PAPI/approach lighting. |
"Jose" wrote in message
. net... Can you explain me please how this(meaning increase of channels by reducing their width) will increase the number of available frequencies for the increasing number of VOR stations. It means you can put channels in between existing channels. If done right, there is no interference. It requires that existing transmitters be modified (if they are not already "narrow" enough) so that there in fact is no interference. Actually the biggest limiting factor is the receivers. I'm not sure what was done during the VOR changeover, but I can say that when the FAA went from 50Khz to 25Khz spacing for voice channels, the only change to the ground equipment was to change the bandpass of the receivers. Older receivers were less sensative and had to have a wider bandpass. As receiver technology progressed, the bandpass could be made more narrow. |
RST Engineering wrote:
You can buy legal 1, 6, 90, and 360 channel radios. Agreed.. But who sells new ones nowadays that are ok to transmit with? (that are only 1, 6, 90 and 360 channels, respectively) |
Didn't see the "new" word in the OP. I s'pose I could round up enough parts
to make a 541 (single channel) and 542 (6 channel) and if I dug deep enough into the obsolete parts bin I might even be able to do a 571 (360 channel). The type certificate approval never runs out, just like a pilot certificate. Jim "Dave S" wrote in message ink.net... RST Engineering wrote: You can buy legal 1, 6, 90, and 360 channel radios. Agreed.. But who sells new ones nowadays that are ok to transmit with? (that are only 1, 6, 90 and 360 channels, respectively) |
Pair of new in box, unused, EAC-1 Single Channel EGT/CHT/OAT | Acroav8r | Aviation Marketplace | 1 | May 18th 06 11:26 AM |
Pair of new in box, unused, EAC-1 Single Channel | [email protected] | Home Built | 0 | May 10th 06 07:17 AM |
Discovery Wings Channel ??? | Bush | Piloting | 7 | November 15th 04 04:07 PM |
Discovery Wings Channel ??? | Andy Asberry | Home Built | 0 | November 13th 04 05:11 AM |
History Channel show update | Roger Long | Piloting | 0 | October 11th 04 05:06 PM |
