GPS Reception Problems with 396
Old August 4th 06, 11:18 PM posted to rec.aviation.piloting
.Blueskies.
Default GPS Reception Problems with 396
"Jay Honeck" wrote in message ps.com...
: Is anyone else having major GPS satellite reception problems with their
: 396?
: I know it's not quite the same unit, but the 496 seems to be made from
: about 99.5% of 396 parts, so...
: Nope. With 5 hours on the unit, and three major cross-country flights,
: it's been rock solid from start up to shut down. (BTW: In the
: automotive mode, a nice lady will announce, in her most sultry voice:
: "Satellite reception lost..." There's no such thing in the aviation
: mode, for some reason... :-)
: Jay Honeck
: Iowa City, IA
: Pathfinder N56993
: www.AlexisParkInn.com
: "Your Aviation Destination"
Probably because, if you loose satellite reception in aviation mode, it yells in a terrified voice "Satellite reception
lost, flight call, take evasive action immediately!"
Old August 4th 06, 11:19 PM posted to rec.aviation.piloting
.Blueskies.
"Jack Cunniff" wrote in message ...
: "Dan" writes:
: 396? I've made two trips since getting the 396 and have noticed the
: following...
: After takeoff or on arrival within 5 miles of airports here in the
: Phoenix Metro area I have _always_ experienced a loss of GPS signal.
: This could happen even on a smooth, straight in approach (it's not that
: I'm turning away from the satellites, etc.)
: According to this page (Jay Honeck had recently shared the URL elsewhere)
: http://www.scn.org/~bk269/gps.html , certain nav/com frequencies can
: prevent your handheld GPS from receiving signal.
: It's likely, since it's in the same area, that you're tuning one of the
: frequencies listed on that page.
: I've always found that changing frequencies solved the problem; put up
: your satellite status page, then get permission from ATC to go off
: frequency. Turn OFF the radios (if you're in VFR and not using the NAV),
: and you'll quickly know whether you've got a nav/com interference problem.
: I first found this problem when I bought my Arrow (Narco panel), and had
: this problem within the first day or two. I have had interference affect
: my GPS Pilot III, 196, and 396.
: -Jack
Did you try any other GPS brands beside Garmin?
Old August 5th 06, 01:07 AM posted to rec.aviation.piloting
Bob Noel
In article
john smith wrote:
Does the 396 have RAIM?
Portable devices do not have RAIM.
Really? Then what's the point of a 12 channel GPS receiver?
Bob Noel
Looking for a sig the
lawyers will hate
Old August 5th 06, 02:40 AM posted to rec.aviation.piloting
Jon Woellhaf
With regard to com/nav receivers causing a GPS to lose satellites, Dan
asked,
... Is it simply the act of tuning the frequency, or the act
of actually _receiving_ something on the frequency?
Just tuning the frequency.
Old August 5th 06, 02:42 AM posted to rec.aviation.piloting
john smith
Standard GPS chipsets. RAIM requires separate processing.
Old August 5th 06, 02:49 AM posted to rec.aviation.piloting
Dan[_1_]
This isn't my problem then.... Must be something in the unit.
--Dan
asked,
Old August 5th 06, 04:01 AM posted to rec.aviation.piloting
Newps
Bob Noel wrote:
In article
Go find yourself a consumer GPS message board and see what thyey talk
about. There are GPS manufacturers that say their GPS is a 30 channel
parallel receiver. These people on these boards are gushing at how
great these new GPS's are. The manufacturers are laughing all the way
to the bank at $250 a pop. Now remember these are GPS's only, they
require a PDA or other computer to actually display the information.
They have no mapping software, you provide all that. It doesn't faze
these people when you tell them there are 24 GPS sats and most of the
time you will have 8-9 sats in view.
Mooney Engine Problems in Flight Paul Smedshammer Piloting 45 December 18th 04 09:40 AM
ILS reception question gatt Piloting 6 June 11th 04 02:19 AM
Chaplains urge couples to attend retreat to solve problems, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 31st 04 03:46 AM
F22 Problems Paul F Austin Military Aviation 9 February 5th 04 02:27 AM
