Landing Advice...
Old August 4th 06, 07:19 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Default Landing Advice...
You fly the airplane until it is tied down. The nose will
weathervane into the wind unless you use the rudder to keep
it pointed straight [or the direction you want] and you will
be blown sideways by the wind unless you use aileron and
brakes to steer the airplane.
After touchdown, it is normal and proper to use full aileron
during the roll out on the runway and if you look in your
aircraft manual or a pilot training manual, you'll see a
taxi control diagram.
James H. Macklin
ATP,CFI,A&P
"Dan" wrote in message
| All,
| Occasionally, I find myself in the following situation
when landing. I
| am trying to figure out what I am doing wrong.
| I fly over the numbers at the proper airspeed, and on the
(VASI)
| glideslope. I flare by putting the cowling to the horizon
and holding
| off unitl touchdown. After touchdown, I find the plane
drifting to the
| left, while the nose is pointing to the right. Applying
further right
| rudder seems to result in a squirrley/sliding feeling (not
sure if I am
| acutally sliding though, just afraid to push it any
further). Applying
| brakes at anything more than very slight pressure results
in skidding.
| At this point, I find myself rolling down the runway,
unable to slow
| down fast enough and trying to control the drift.
| This could happen in little to no wind conditions. What
am I doing
| wrong? I'm not a beginner, but occasionally this happens
and I can't
| seem to figure it out.
| Do I need to....
| A. Crank in aggressive alieron to the right.
| B. Apply lots of back-pressure to get more weight on the
mains to allow
| breaking.
| C. Something else....?
| Dan
Old August 4th 06, 01:36 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_3_]
It doesn't happen that often, but it did last night. I am trying to
remember if it is always left, and actually I think it is. It is NOT
the same airplane. Had the problem in an Archer, Arrow, and Comanche.
- probably my technique.
Could I be unintentionally doing something with the rudder on
touchdown?
My guess is that it is your sight picture that is the problem.
You have ruled out wind. You have ruled out the equipment, since it happens
on different planes.
I think you must really have the nose pointed to the left, because that is
the direction the airplane is really going. That means what you think you
are seeing with the direction of the nose is wrong.
If while sitting in the left seat, and you are rolling straight down the
runway, if you look at the nose and observe where the spinner is, it looks
like it is off to the right. Bingo. There is your problem.
You have to look down the offset parallel line of the cowling. If the
eyeball in your head is18 inches off to the left of the center of the
airplane, you need to be looking at a spot on the cowl that is 18 inches to
the left of the crankshaft, and lining that point up with the end of the
runway. Remember to look far down the runway, of course.
Try it; I think it will help.
Jim in NC
Old August 4th 06, 02:39 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Burns[_1_]
This may indeed be the problem. Does the yaw to the left decrease in
intensity as your ground speed slows? If so it could very well be an
aileron input error.
Another thing to check is something that I ran into when transitioning to
the right seat in a C182 RG. I was inadvertently removing my left foot from
the rudder to move my leg out of the way of the flap switch on roll out.
The problem was that at the same time I was unknowingly pushing on the right
rudder. Instant veer towards the right. All it took to discover my error
was a quick ride around the pattern with another pilot, we spotted it
together almost instantly.
Fly with a CFI or another pilot in the right seat. Eliminate the aircraft
as being the problem.
And be sure that you are not transferring automobile driving muscle memory
to your flying by lifting your right foot off the "accelerator" and pushing
down on the "brake".
Old August 4th 06, 03:02 PM posted to rec.aviation.piloting,rec.aviation.student
Robet Coffey
I have had a left drift during flare where it appeared there was a
crosswind when there was none. It happened most often when I was solo. I
finally attributed it to more wing load (drag)on the left side since I
was the only passenger. I am flying a cherokee six with tip tanks and
if landing imbalanced, alieron correction is a must to correct for
drift. It always seemed to sneak up on me in very calm conditions when I
was complacent.
Dan wrote:
All,
Occasionally, I find myself in the following situation when landing. I
I fly over the numbers at the proper airspeed, and on the (VASI)
glideslope. I flare by putting the cowling to the horizon and holding
off unitl touchdown. After touchdown, I find the plane drifting to the
left, while the nose is pointing to the right. Applying further right
rudder seems to result in a squirrley/sliding feeling (not sure if I am
acutally sliding though, just afraid to push it any further). Applying
brakes at anything more than very slight pressure results in skidding.
At this point, I find myself rolling down the runway, unable to slow
This could happen in little to no wind conditions. What am I doing
wrong? I'm not a beginner, but occasionally this happens and I can't
Do I need to....
B. Apply lots of back-pressure to get more weight on the mains to allow
breaking.
Dan
Old August 5th 06, 12:22 AM posted to rec.aviation.piloting,rec.aviation.student
BTIZ
It would not be the best advice to say.. raise the flaps to get more
braking
effect, but that is the placard in the Beech Sport/Sundowner/Sierra
series.
In my '76 Sundowner, it cost me a set of tires before I realized that
flap retraction is pretty much mandatory for any decent braking. My
plane was missing the "Raise flaps..." placard. It's super easy to
lock / drag a wheel with the flaps down.
How did it pass the annual every year if a placard was missing?
oops..
B
Old August 5th 06, 12:26 AM posted to rec.aviation.piloting,rec.aviation.student
Peter Duniho
I am flaring with my left hand (right hand on the throttle), so
probably crank the yoke to the left a bit...
For what it's worth, if you get into the habit of, when over the runway,
always correcting drift with aileron, and correcting heading with rudder,
the problem you're experiencing will go away naturally (and I think it's
likely that "P S" has correctly identified the issue). Even if you do
accidently pull the yoke a bit left while flaring, as soon as the airplane
starts to drift your natural reaction will (should) be to compensate with
some right aileron, which will negate the accidental left aileron you put in
in the first place.
Obviously there are times when heading is the appropriate correction for
drift, but by the time you are ready to touch down on the runway, you *must*
have the nose of the airplane aligned with the runway. The rudder is used
for that. Likewise, you *must* compensate for any drift, so that the
airplane is tracking straight down the runway. The aileron is used for
that.
You may recognize these control inputs as being the same for one method of
dealing with crosswinds. Of course, even in the "crab and kick-out"
method, you do at the very end, just before touching down, use the controls
in just this way. So it's perfectly reasonable to just always get in the
habit of controlling the airplane just before touchdown in this way.
In addition (not that this seems to be the issue you're dealing with), while
one should be careful to not overcontrol the airplane, and while in cruise
flight it often makes sense to let light turbulence just have its way with
the airplane (many gusts are corrected by another gust that comes along
right after...chasing the gusts with the flight controls is inefficient and
tiring ), during landing is no time to let the airplane get away from
you. If you get pushed one direction, be sure to get the plane controlled
back the other direction ASAP, all the while keeping the nose aligned with
the rudder.
Pete
Old August 5th 06, 10:47 AM posted to rec.aviation.piloting,rec.aviation.student
On Sat, 5 Aug 2006 18:24:42 +1200, Dave Doe wrote:
In article . com,
says...
All,
Do I need to....
breaking.
What you need to do is practice some crosswind landings.
Apart from gusty conditions, which needs more attention, I fly the
aircraft crabbed until about 100 to 200ft above the runway. Then I
gently straighten the aircraft with rudder and align it with the
runway at the same time stopping drift with opposite aileron. The
aircraft is now set up to land on one wheel and most times little
correction is required after that. However, as you near & touch the
runway and the aircraft slows down, you will need more aileron to
correct any drift.
This is the opposite you would do for take-off where you put in full
aileron into wind as you start the take-off roll then as you increase
speed slowly reduce aileron input.
Old August 5th 06, 02:09 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
The placard can and should be replaced. You can buy it from
Beech or have one made.
"B A R R Y" wrote in
message ...
| On Fri, 4 Aug 2006 16:22:54 -0700, "BTIZ"
flaps to get more
| braking
| series.
realized that
braking. My
super easy to
missing?
| oops..
| B
| Excellent point. The device that is in the panel where
the placard
| was has been there ~ 15 years. I've owned the plane for 2
years.
| The placard is STILL missing. G
Old August 5th 06, 03:41 PM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Can you make it yourself, or does it have to be an "official" placard
installed by an A&P?
Jose
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
Hard landing in a retractable Frode Berg Owning 7 May 19th 05 09:10 AM
Ejection -v- Forced Landing Cockpit Colin Naval Aviation 27 April 2nd 05 11:47 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 09:38 PM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
