http://www.whiteindustries.com/
White Industries lists engines with flange runout. What does flange runout tell about the engine? It seems some prop strike engines have a larger flange runout reading than others, and the larger the flange runout, the lower the price. Why? Thanks. |
Flange runout means absolutely nothing. Especially on Lycomings.
Because of the meatllurgy involved they don't bend, they break. wrote: http://www.whiteindustries.com/ White Industries lists engines with flange runout. What does flange runout tell about the engine? It seems some prop strike engines have a larger flange runout reading than others, and the larger the flange runout, the lower the price. Why? Thanks. |
![]() White Industries lists engines with flange runout. What does flange runout tell about the engine? It seems some prop strike engines have a larger flange runout reading than others, and the larger the flange runout, the lower the price. Why? The higher the runout number, the more damage there is to either the crank or the case. It depends on the exact engine series as to how bad a number you can tolorate before the repair costs are closing in on replacement costs. For me, it's not worth dealing with an engine that has had a prop strike unless one of two things are known: 1: The prop strike was with a wooden prop or 2: The case has already been through a complete inspection and the shop is able to guarantee that the case has no damage, visable or hidden, and that the case will meet or beat the table of limitations the manufacturer has for that engine. Craig C. |
If your going to rebuild anyway, take a look at these.
http://www.airboattrader.com/PartsForSale.htm Lou |
Great site, I especially like the 8 cylinder Contential:
http://www.airboattrader.com/PartsF1420.jpg "Lou" wrote in message ups.com... If your going to rebuild anyway, take a look at these. http://www.airboattrader.com/PartsForSale.htm Lou |
Simple, More runout means that the crankshaft is bent more. Bent
more means it is more likely to be cracked and the prop fly off some day. On 6 Aug 2006 16:53:15 -0700, " wrote: http://www.whiteindustries.com/ White Industries lists engines with flange runout. What does flange runout tell about the engine? It seems some prop strike engines have a larger flange runout reading than others, and the larger the flange runout, the lower the price. Why? Thanks. |
http://www.whiteindustries.com/ White Industries lists engines with flange runout. What does flange runout tell about the engine? It seems some prop strike engines have a larger flange runout reading than others, and the larger the flange runout, the lower the price. Why? Thanks. The run out will tell you how badly the flange is bent. Thats it. In order to tell how much damaged there was you need to know several things: What was the power setting when the engine had it's strike?, What kind of prop?, What did it hit? Was it a sudden stop or a slow down? Then you need to tear it down. Throw away the crank. have the case throughly inspected, have all of the other moving parts throughly inspected. Personally I would only buy one as a core exchange if the manufacturer will take it. Michelle |
1: The prop strike was with a wooden prop or...
Some composite props, like IVO, break easy on impact. I had a prop strike with IVO and had the crank magnafluxed. No flange runout or cracks were found. I have a Franklin 6A350 engine (are they more solid?).. It's the aluminum rigid props that are crank killers. ---------------------------------------------------------------- SQ2000 canard http://www.abri.com/sq2000 |
Then you need to tear it down.????
If its a lycoming you need to tear it down regardless..... AD NOTE joe Michelle P wrote: wrote: http://www.whiteindustries.com/ White Industries lists engines with flange runout. What does flange runout tell about the engine? It seems some prop strike engines have a larger flange runout reading than others, and the larger the flange runout, the lower the price. Why? Thanks. The run out will tell you how badly the flange is bent. Thats it. In order to tell how much damaged there was you need to know several things: What was the power setting when the engine had it's strike?, What kind of prop?, What did it hit? Was it a sudden stop or a slow down? Then you need to tear it down. Throw away the crank. have the case throughly inspected, have all of the other moving parts throughly inspected. Personally I would only buy one as a core exchange if the manufacturer will take it. Michelle |
joe wrote:
Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
Prop Feathers and Engine Shuts down after landing???????? | AIR ADVENTURE82 | Piloting | 3 | August 21st 03 05:42 AM |
