Removing Ethanol from Gas?
Old August 9th 06, 04:13 PM posted to rec.aviation.piloting
Jay Honeck
Default Removing Ethanol from Gas?
The adding of ethanol to gasoline has made the auto-gas STC unusable
for many aircraft owners, nationwide. So far, we're okay (in Iowa,
which is pretty funny) and are able to purchase untainted mogas -- but
the long-range situation seems untenable. We, as a nation, are
inexorably being forced toward the addition of alcohol into ALL
gasoline, so it seems...
On the Cherokee 235 user's group, there is a guy who's been
successfully using ethanol-gas in his aircraft. It's ruined his
fiberglass tip tanks, but he apparently expected this to happen.
Otherwise, the engine is running fine, or so he reports. (Personally,
I think he's crazy, ruining tip tanks that run close to $4K *apiece*,
but that's just me...)
His experience has led to a more interesting (to me) discussion about
the possibility of REMOVING ethanol from gasoline. Several ideas have
been postulated (evaporation; heating; adding water), but none of them
sound particularly safe or easy.
Any chemists out there? Anyone know a way to remove the ethanol from
mogas, so that we may safely use it in our aircraft?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 9th 06, 04:25 PM posted to rec.aviation.piloting
Gig 601XL Builder
"Jay Honeck" wrote in message
This was discussed a while back. While I'm not a chemist I would think that
what came out of the removal process would have a completely unknown octane
rating that would probably be lower than what went in.
I also think "successfully using ethanol-gas" and "ruined his fiberglass tip
tanks" really shouldn't be used in the same paragraph.
Old August 9th 06, 04:27 PM posted to rec.aviation.piloting
Jay Honeck
Really? Dang, I thought I had kept up here. I remember reading about
TESTING for ethanol, but never removing it... Sorry about that.
Few planes have fiberglass tip tanks -- so I think his experience is a
fairly valid test for many aircraft owners. It seems to be "running"
just fine in his low-compression Lycoming O-540, which is exactly what
you might expect from an old 1940's-era tractor engine.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 9th 06, 05:25 PM posted to rec.aviation.piloting
Jim Macklin
ECON 101
AvGas is available at X price
MoGas is available at 3/4X price
Cost to re-refine MoGas Y (why is a good choice of letter)
Cost to repair damaged engine (each) $20,000.
Cost to repair damaged fuel tanks, plumbing, pumps and
seals, unknown.
Cost of FAA violation of regulations, certificate
suspension, a lot
Cost of uninsured aircraft when your insurance is cancelled,
priceless.
James H. Macklin
ATP,CFI,A&P
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
STC unusable
okay (in Iowa,
nation, are
into ALL
been
ruined his
happen.
(Personally,
$4K *apiece*,
discussion about
Several ideas have
but none of them
ethanol from
would think that
his fiberglass tip
Old August 9th 06, 06:12 PM posted to rec.aviation.piloting
Al[_1_]
"Jim Macklin" wrote in message
news:q0oCg.14$SZ3.7@dukeread04...
ECON 101
seals, unknown.
suspension, a lot
priceless.
James H. Macklin
ATP,CFI,A&P
There is also the issue of performance. As I understand it, alcohol
doesn't produce as much horsepower per volume as does avgas. If I use a
mogas that has alcohol in it, I don't have the "Get up and GO" that I used
to have. On that hot day at high altitude, over an obstacle, which takeoff
performance chart do I use?
Al G
Old August 9th 06, 06:39 PM posted to rec.aviation.piloting
James Robinson
Longer term, he is also risking corrosion damage to main tanks and pumps,
since ethanol, being hygroscopic, tends to join with any water, including
that from humidity in the air, and settle to the bottom of tanks. This
is a particular problem where humidity is high, and the fuel is left in
the tank for any period of time before being used.
The water content can also add to the risk of vapor lock or ice crystals
forming in the fuel where those things are already a problem, such as
where winter grade fuel is not used until the heat of the summer.
Without directly answering the question, also keep in mind that ethanol
is an octane booster. If it is removed from E10 fuel, as an example,
there is a loss of 2 or 3 points of octane. (This is also a problem
where the ethanol has combined with water and dropped out of the gasoline
mix.)
An engine like a Rotax turbo approved for use of Mogas requires a minimum
of 91 or 92 octane, and that is the rating for premium fuel. Thus, if
the ethanol is removed, even from premium fuel, the octane wouldn't be
high enough to use in the engine. The only possibility would be to start
with Sunoco Ultra, which is a 94 octane fuel, which I understand is 93
octane without the ethanol. Perhaps Sunoco will offer it as mogas
One way of removing ethanol would be to mix water with the fuel, and let
it sit for a while. The ethanol would combine with water, then you could
drain both off, (along with any other soluble compounds in the fuel).
Old August 9th 06, 06:47 PM posted to rec.aviation.piloting
Jim Macklin
It's is like the guy who spent $25,000 on tools to build
furniture for his house, to save 25% on the furniture.
During WWII the Army published flight manuals for fighters
(and bombers) for different grades of fuel, 80/87, 91-96,
100/130 and 115/145 being refined. But some battlefields
did not have supplies of all grades. So you might have a 54
In Hg. MAP with 115/145 and only 40 inches with 100/130.
But what octane do you get from home refined mogas?
James H. Macklin
ATP,CFI,A&P
"Al" wrote in message
| "Jim Macklin" wrote
in message
| ECON 101
letter)
| seals, unknown.
| suspension, a lot
cancelled,
| priceless.
| James H. Macklin
| ATP,CFI,A&P
it, alcohol
avgas. If I use a
GO" that I used
| Al G
Old August 9th 06, 07:00 PM posted to rec.aviation.piloting
john smith
Today's Wall Street Journal has an chart of pickup trucks and cars and
gas milage with gasoline and E85.
Gas E85 Gas E85 Annual E85 Costs+
City City Hwy HWy Cost /Savings-
Chevy Silverado 1500 AWD 15 11 19 14 $2813 -$10
Chevy Impala 21 16 31 23 $1877 +$40
Chevy Tahoe 1500 AWD 14 11 18 14 $2813 +$223
Ford Crown Victoria 17 12 25 18 $2250 +$353
Ford F150 FFV AWD 14 10 18 13 $3002 +$311
based on 45% highway/55% city, 15,000 mpy
Old August 9th 06, 07:02 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Wed, 9 Aug 2006 10:12:00 -0700, "Al"
The one that says, "stay on the ground and have a beer"?
Old August 9th 06, 07:27 PM posted to rec.aviation.piloting
M[_1_]
I don't think there's nearly enough ethanol manufacturing capacity to
do a nation wide mix of E10. That's a huge amount of ethanol to be
made from corn or other plants, plus the cost and the energy in
distillation.
Ethanol & capacitance fuel-level sensors Adam Aulick Home Built 4 May 20th 06 03:28 PM
The effects of Ethanol on... ventus2 Home Built 35 May 8th 06 05:45 AM
MoGas users: Ethanol replacing MTBE John Piloting 167 May 5th 06 08:31 PM
Ethanol Mandate for Iowa? Jay Honeck Piloting 155 October 4th 05 03:17 PM
Ethanol Powered Airplane Certified In Brazil Victor Owning 4 March 30th 05 09:10 PM
