Another approach question
Old November 7th 04, 03:36 AM
Andrew Sarangan
Default Another approach question
On VOR/DME-B @ 69V, there is a comment that says PT is not authorized when
arriving northbound on V208. Then on the bottom of the chart it says
"Procedure Turn NA". Why bother printing the first statement, when PT is
clearly not authorized for any transitions? Is this a left-over from a old
chart when PT might have been authorized except for the V208 transition?
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old November 7th 04, 04:06 AM
Brad Zeigler
Read it again. Not PT...the whole procedure is not authorized when arriving
northbound on V208.
"Andrew Sarangan" wrote in message
. 145...
Old November 7th 04, 05:06 AM
Andrew Sarangan
Thanks. I had misread that one.
"Brad Zeigler" wrote in
. 145...
when arriving northbound on V208. Then on the bottom of the chart it
says "Procedure Turn NA". Why bother printing the first statement,
when PT is clearly not authorized for any transitions? Is this a
left-over from a old chart when PT might have been authorized except
Old November 7th 04, 02:52 PM
Roy Smith
No, read it more carefully. It says "Procedure not authorized". I
don't have an en-route chart of the area, but presumably there are other
airways which get you to CARBON, and you've got to arrive on one of
those, or from ARBIH.
My reading of the chart also says that if you miss, you can't try again
directly out of the missed hold; you need to get clearance back to (for
example) ARBIH and start again from there.
Old November 7th 04, 03:40 PM
Andrew Sarangan
Roy Smith wrote in
other airways which get you to CARBON, and you've got to arrive on one
of those, or from ARBIH.
again directly out of the missed hold; you need to get clearance back
to (for example) ARBIH and start again from there.
Where are you seeing that? The missed hold is at CARBON, which is an IAF.
Since you are clearly not arriving from V208 (which happens to be along R-
164), why can't you start the approach from CARBON?
Old November 7th 04, 05:44 PM
Roy Smith
Well, I'm not really sure about this, but here's my thinking...
The only reason I can think of to disallow arrivals along V208 is
because there isn't enough protected airspace north of CARBON to allow
the course reversal that would be required. Seems to me the same would
be true if you're inbound to CARBON in the hold. On the other hand, if
you've got room to make the outbound turn, I guess you should have room
to just make a right turn to heading 220 or so after crossing CARBON
inbound and intercept the 195 radial outbound.
You are certainly correct that there's nothing on the plate that
explicitly says that, but that's my guess. I suppose the way it would
really work is that you call ATC from the hold and ask for clearance for
another approach. They'll either clear you for the approach directly
from the hold, or give you something that takes you to ARBIH or
somewhere else to begin the approach from.
GPS approach question Matt Whiting Instrument Flight Rules 8 November 1st 04 10:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
where to ask question about approach? J Haggerty Instrument Flight Rules 1 August 17th 04 06:30 AM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
