Scarf Joints in Plywood
Old August 12th 06, 12:26 AM posted to rec.aviation.homebuilt
Kyle Boatright
Default Scarf Joints in Plywood
One of these days, I'm gonna dust off the Hatz project, and when I do, I'll
need to make some scarf joints in 1/16" ply.
Suggestions?
KB
Old August 12th 06, 01:00 AM posted to rec.aviation.homebuilt
Bob Kuykendall
Whenever I need info about ways to make wood aircraft parts, the first
thing I think of is Sequoia:
http://www.seqair.com/skunkworks/Woo...s/Methods.html
Bob K.
Old August 12th 06, 02:00 AM posted to rec.aviation.homebuilt
JKimmel
Bob K.
Another scarfing fixtu
http://www.oneoceankayaks.com/stitch.../scarfjig2.htm
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old August 12th 06, 04:27 PM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Kyle Boatright" wrote in message
I'll need to make some scarf joints in 1/16" ply.
Suggestions?
KB
Kyle........
It's not a big deal and you do not need a fixture. A scarf for 1/6" ply is
1" wide. Make a pencil line on each area to be scarfed 1" back from the
edge. Draw a bunch of lines from that mark to the edge to give you a visual
when you are removing wood.
Using a quick-clamp, clamp the ply to the workbench in front of you so the
right edge of the ply is at or just a BCH over the right edge of the work
surface. Using a razor sharp 5" or 6" plane, taper the edge of the ply
evenly from the mark to the edge. The plies will become visible as you
remove the material and give you and excellent guide to keep it even.
It takes only a few seconds to make a perfect scarf this way and you'll
enjoy the process.
Rich S.
Old August 13th 06, 03:50 PM posted to rec.aviation.homebuilt
Lou
I used my radial arm saw (craftsman). I was able to turn and tilt to
the desired angle.
Then set up a fence to just run my plywood through. The down side is, I
haven't used my saw for sawing in over a year because I don't want to
have to set it up again. I've even considered buying another smaller,
saw just for the scarfing set up.
Old August 13th 06, 04:01 PM posted to rec.aviation.homebuilt
Dan Horton
Kyle,
You didn't mention what parts you were scarfing, but if it is just
the leading edge ply wraps you might wish to visit Darin Bishop's
excellent Model 12 site.
http://www.2wings.com/
Click FAQ, select Wings, and find the leading edge topic. No jigs
or special tools, just an sanding block. Works fine, did a set last
year.
Dan
Old August 15th 06, 04:18 AM posted to rec.aviation.homebuilt
flybabybuilder
The classic Bingelis library has info on setting up a motor and a
sanding drum, but that's probably overkill for 1/16 unless you're doing
a lot of it.
If your plane isn't razor sharp, a long sanding block with medium grit
will work fine. Just be sure to blow the dust off (do not use a tack
cloth). Rich is right - the plies will give you a good visual
indication. They should be evenly spaced.
You might plan on having some extra at the other end (if possible) in
case you mess up and have to cut a strip off the end. Practice on a
piece or two.
Suggestions?
KB
Kyle........
enjoy the process.
Rich S.
Old August 16th 06, 04:49 AM posted to rec.aviation.homebuilt
Morgans[_3_]
a lot of it.
piece or two.
The only down side here, is that sanding is considered to be a poor surface
preparation method, for glue joints. I think I recall that fact from the
Forrest products publication.
The surface should be scraped to prep for glue, at a minimum.
Jim in NC
Old August 16th 06, 11:56 AM posted to rec.aviation.homebuilt
Lou
I've always wondered about that. When gluing wood together it's always
been a good idea to rough up the area's to be glued so that the glue
goes in the roughend area and has a better grab. If the area is too
smooth it will hold less glue and more possiblity to squeeze out.
Old August 16th 06, 04:56 PM posted to rec.aviation.homebuilt
Stealth Pilot
glue beam laminators have noticed that you can get beams about 20%
stronger if the wood surface is freshly prepared just before gluing.
they are not certain why but oxidation or some other chemical process
occurring on older wood surfaces may be a culprit.
on plywoods of course the reason is different. it removes surface
contamination from the presses.
Stealth Pilot
compound curves in plywood BA-100 Home Built 58 April 13th 05 05:29 AM
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 05:26 PM
SS exhaust ball joints Stu Home Built 1 January 3rd 04 10:34 PM
Scarf Joints Flyhighdave Home Built 2 December 16th 03 05:53 AM
Substitute for Mahogany plywood Kelvin & Janice Rempel Home Built 1 September 5th 03 08:02 PM
