#11
![]() bk wrote: Congratulations on getting your ticket. How do you feel about airspeed indication now? A useful exercise is to get an instructor, put paper over the ASI, and fly the pattern a few times so that you can takeoff and land without reference to airspeed, just attitude by looking out the window and feeling the yoke. Enjoy your new privileges, Bruce I'll try that Bruce. Clearly at the end of initial PPL training, one's feel for the aircraft is somewhat better than at the start. |
![]() I'm sure you are correct, and I seriously thought about taking off, but on a second solo, with all the flying in the circuits so closely pinned to airspeeds, I'm glad I didn't. I certainly wouldn't have felt confident about knowing how far I was from stall speed on final...... As a 35 year flight instructor, I feel that you received inadequate pre-solo training. The pattern can (and perhaps should) be flown by the use of pitch and power only. Set the power and pitch correctly and the airspeed will be there. No student of mine has ever soloed without flying an entire lesson (in and out of the pattern) with the entire instrument panel completely covered except for the tachometer. RPM settings....Takeoff and climb to pattern altitude...Full Power, Downwind in a C-172, about 2100 RPM...who cares what the airspeed is? Abeam the touchdown spot, set 1500 RPM, lower the nose and keep the nose down, lower first noch flaps, who cares what the airspeed is? I'll bet that it settles out at 85kts. On base leg, second notch of flaps keeping the nose down and the airspeed WILL back right down to 75kts. Turn final, keep the nose down (still with 1500 RPM) and drop final flap and the airspeed WILL drop to 65kts. Who needs an airspeed indicator? Only an inexperienced flight instructor! They scare easily. :-) I still don't understand your "I ran out of rudder" comment, the faster you go, the more rudder control you have. BTW, here in the USofA, ultralights aren't even required to have such things as altimeters and airspeed indicators.....and mine didn't. Bob Moore CFI ATP B-707 B-727 PanAm (retired) |
![]() Bob Moore wrote: I still don't understand your "I ran out of rudder" comment, the faster you go, the more rudder control you have. Just trying to explain what it felt like. I'm not sure that cessna 150s behave too well at 70knots and full power being held down on the tarmac by a novice pilot who is still waiting for the ASI to show something. I suspect I'd do better next time. |
![]() Bob Moore wrote: As a 35 year flight instructor, I feel that you received inadequate pre-solo training. The pattern can (and perhaps should) be flown by the use of pitch and power only. Set the power and pitch correctly and the airspeed will be there. No student of mine has ever soloed without flying an entire lesson (in and out of the pattern) with the entire instrument panel completely covered except for the tachometer. RPM settings....Takeoff and climb to pattern altitude...Full Power, Downwind in a C-172, about 2100 RPM...who cares what the airspeed is? Abeam the touchdown spot, set 1500 RPM, lower the nose and keep the nose down, lower first noch flaps, who cares what the airspeed is? I'll bet that it settles out at 85kts. On base leg, second notch of flaps keeping the nose down and the airspeed WILL back right down to 75kts. Turn final, keep the nose down (still with 1500 RPM) and drop final flap and the airspeed WILL drop to 65kts. Who needs an airspeed indicator? Only an inexperienced flight instructor! They scare easily. :-) I still don't understand your "I ran out of rudder" comment, the faster you go, the more rudder control you have. I'm sure you're correct, Bob, but my understanding is that stalls in the circuit are a well-recognised cause of accidents? If so, it might not be as automatic as you suggest for a novice. |
Steph wrote
Just trying to explain what it felt like. I'm not sure that cessna 150s behave too well at 70knots and full power being held down on the tarmac by a novice pilot who is still waiting for the ASI to show something. I suspect I'd do better next time. Ah-Ha...wheelbarrowing...it does become difficult to control. Bob Moore |
Steph wrote
I'm sure you're correct, Bob, but my understanding is that stalls in the circuit are a well-recognised cause of accidents? If so, it might not be as automatic as you suggest for a novice. With 1500 RPM and the nose below the horizon, the airplane WILL NOT stall. :-) There are some qualifications to this generalized statement, learn what the runway looks like on a stabilized approach and just always put the nose in that same position every time, it WILL NOT stall. Bob Moore |
![]() "Gene Seibel" wrote As for being upside down - been there, done that. Unfortunately, it was later in my flying career when I should have known better. Now, Gene, you aren't playing by the rules. You should know that you can't let *that* cat out of the bag, without telling the dark tale, on yourself! g -- Jim in NC |
OK... I'll bite... what is a Flight Indicator? Is the Flight pattern
different than the traffic pattern? Enquiring minds want to know... Jon wrote: Hi, Congratulations for your PPL license. Same with me, my wife finally allow me to take a PPL lesson on my birthday this year. Probably she was sick of me playing the Flight Simualtor every day after work. Ive been playing that game for 15 yeras. In fact when I am joining this school i was able to land the plane on my first day lesson. I believe that I am able to finish the PPL program max in 48 hours. But the program was already set up so I wont be able to be solo until flying dual about 20 hours. That means it will take about 60-70 hours until I can get my PPL. THey still have to teach me about reading the flight Indicator which I already know and it will take 2 hours minimum. Its just a procedure they said. Do I need to find a different school ? or can I customize my own program but of course has to be meet the FAA regulations. For example, the school will teach me the Flight pattern and the radio comm almost at the end of the lesson. I believe that is very important and they have to teach on the second or thirt meeting, is that true? On their program also have 1 hours just to learn slow flight, which I already familiar with the procedure just learning from Flight sim. On my first flight, I learn descent, Climb, Tuurn and Straight and Level in 0.6 Hour and plus I land the airplane. All of those learned from SIm. Do you have an input or a better learning program that I can follow and I can jsut show it to my instructure to follow your program? Thank you for your help. wrote: My flying training has taken a long time, I guess......... I started flying training in 1990, but lack of time and money meant that I stopped after about 10 hours, before going solo. Last year, my wife bought me a block of lessons for my birthday, and I found that I hadn't forgotten everything. I was so pleased I carried on iwth training, and last week I passed my flight test, and this morning I passed my written, and I now hold a Canadian PPL. The journey wasn't entirely without excitement. On my second-ever solo I was rolling down the runway in a Cessna 150 waiting for rotation speed - and it never came. By the time I realised the airspeed indicator was not going to work, I was doing well over rotation speed and ran out of rudder. The aircraft veered off the runway to the left as I pulled the power, and it would have been an embarassing run across the grass except for the runway sign........ Next I knew I was upside down, with fuel pouring down the windshield. I had the presence of mind to switch off the mags and master, and the fuel shutoff, and climbed out of the door, just as the fire trucks were arriving. Fortunately, apart from a few nasty cuts and bruises, I was relatively intact. I was even able to take part in a radio interview (about something else) an hour later. And the nice chappy from the Canadian Dept of Transport Accident branch who I had to speak to on the phone was very understanding, as was my flying school chief instructor. Examination off the written-off aircraft confirmed an orchard bee had climbed into and blocked the pitot, and I was cleared of all blame, though I'm sure if I'd had more experience, I would have avoided the crash and simply been able to abort takeoff safely. I decided that either I would get back in the air immediately, or I never would again, so I had my next lesson the next morning, and soloed again the following week. I guess that was the most dramatic episode in my pilot training, but there are so many memorable moments. The first solo, the first solo away from the circuit, the first solo cross-country, the first power on stall, the first landing at a tiny strip in the country....... Anyway, it was all worthwhile in the quest for a lifetime dream for this aging new pilot.........I'm very happy to join the club. And if there is a message for anyone still in the middle of training - perservere. You'll have some low moments (though not as low as mine, I trust) but you'll get there in the end. |
Does USA need a Club Class? | MC | Soaring | 42 | April 7th 05 08:07 PM |
Introducing... NJ's newest Soaring Club! | Jim Buckridge | Soaring | 0 | February 21st 05 11:31 PM |
Northern NJ Flying Club Accepting New Members | Andrew Gideon | General Aviation | 0 | June 12th 04 02:14 AM |
Club Management Issue | Geoffrey Barnes | Owning | 150 | March 30th 04 06:36 PM |
Where are the CFIG's? | Michael | Soaring | 10 | August 19th 03 12:23 AM |
