One of the tachs in our Aztec has been acting kind of flakey, usually
reading too high when above 2100 rpms, (I've checked it several times with an optical tach) so I've been contemplating our options of replacing both tachs with a single dual needle tach. This would open up some panel space allowing me to spend ludicrous AMU's on another toy. One option is to simply get a mechanical dual tach and connect both tach cables to the single tach but I don't know of a dual recording tach that has dual hour meters. Anybody? Another option is to get rid of the cables, buy tach generators, and an electric dual needle tach. But I still don't know of a company that makes a dual recording tach. So far, I have not found a company that makes a dual electronic tach. Neither E.I or Horizon seem to offer a dual tach. Also, due to panel configuration, I want a 3 1/8" dia tach not the smaller 2 1/4" tachs that EI or Horizon offer, I have no room for additional 2 1/4" gauges. Is there anybody out there with any insight into this dilemma? Thanks, Jim |
![]() "Jim Burns" wrote in message ... One of the tachs in our Aztec has been acting kind of flakey, usually reading too high when above 2100 rpms, (I've checked it several times with an optical tach) so I've been contemplating our options of replacing both tachs with a single dual needle tach. This would open up some panel space allowing me to spend ludicrous AMU's on another toy. One option is to simply get a mechanical dual tach and connect both tach cables to the single tach but I don't know of a dual recording tach that has dual hour meters. Anybody? I don't believe you need a recording tach. Most twin engine retractable aircraft only record "flight" time and have a squat switch installed that powers the Hobbs meter when the aircraft is airborne. Just don't forget to disconnect the power to it while you have it up on jacks doing MX with the battery on. Allen |
Yep. Got one of them also, but a previous owner wired it to the master
switch instead of the squat switch. Must have been used as a trainer or rental at one point. That's little item has been on our "fix it" list for a long time. I just think it's kind of nice to be able to look at the tachs and see how many hours are on each engine. Jim |
![]() "Jim Burns" wrote in message ... Yep. Got one of them also, but a previous owner wired it to the master switch instead of the squat switch. Must have been used as a trainer or rental at one point. That's little item has been on our "fix it" list for a long time. I just think it's kind of nice to be able to look at the tachs and see how many hours are on each engine. Jim If you find a dual recording tach it still will not tell you the hours on "your" engines, you will still need to do the math. I would go with the less mechanically complex tach and a Hobbs meter. Hobbs meters are cheap and you could put in a "0" time one at the next engine overhaul so the times matched. Allen |
The tach shops will run a new or rebuilt tack up to any number you want....
for about the price of a hobbs meter. ![]() recording tach. Jim If you find a dual recording tach it still will not tell you the hours on "your" engines, you will still need to do the math. I would go with the less mechanically complex tach and a Hobbs meter. Hobbs meters are cheap and you could put in a "0" time one at the next engine overhaul so the times matched. Allen |
Isn't engine TBO driven off the engine tach-time and not Hobbs meter
time? Since I don't have a hobbs meter in the Mooney does that mean my engine is not recording any wear? ;-) Jon Kraus Allen wrote: "Jim Burns" wrote in message ... Yep. Got one of them also, but a previous owner wired it to the master switch instead of the squat switch. Must have been used as a trainer or rental at one point. That's little item has been on our "fix it" list for a long time. I just think it's kind of nice to be able to look at the tachs and see how many hours are on each engine. Jim If you find a dual recording tach it still will not tell you the hours on "your" engines, you will still need to do the math. I would go with the less mechanically complex tach and a Hobbs meter. Hobbs meters are cheap and you could put in a "0" time one at the next engine overhaul so the times matched. Allen |
![]() "Jon Kraus" wrote in message . .. Isn't engine TBO driven off the engine tach-time and not Hobbs meter time? Since I don't have a hobbs meter in the Mooney does that mean my engine is not recording any wear? ;-) Jon Kraus Heh Heh, if it only worked that way. I have customers come in from Mexico for overhauls at "TBO" with probably twice the actual hours on the engines. Not very many twins have the recording tach like the Aztec. Allen |
"Jim Burns" writes:
One option is to simply get a mechanical dual tach and connect both tach cables to the single tach but I don't know of a dual recording tach that has dual hour meters. Anybody? I probably have the one we pulled from our Aztec in my junk box. So far, I have not found a company that makes a dual electronic tach. Neither E.I or Horizon seem to offer a dual tach. I was told that Horizon would have a dual tach. "soon" when we were looking in 2001. Also, due to panel configuration, I want a 3 1/8" dia tach not the smaller 2 1/4" tachs that EI or Horizon offer, I have no room for additional 2 1/4" gauges. The Horizon P-1000 is a larger tach. Another option is (always) on the horizon... http://diamondaire.com/aztec.htm Rochester engine instrumentation.We are currently working with Rochester Gauges of Texas to introduce new 2-1/4" dual-needle STC'd backlit gauges. [...] A 3-1/8" dual electric STC'd tachometer will also be available. (They've been saying that for awhile now.) Is there anybody out there with any insight into this dilemma? It's worth pursuing. I hate mechanical tachs. I've replaced those damn cables way too many times. It makes no sense to have all that crap in the plane just to provide a really lousy estimate of engine speed. In a single it's o.k. but in a twin it's ridiculous. (I recall the joy of yanking those cable housings out of my plane!) You will love an electronic tach. I especially like the mag. failure lights and the mag. drop feature. Having a tach. that always works and is accurate without constant maintenance is pretty sweet too. --kyler |
"Jim Burns" writes:
Yep. Got one of them also, but a previous owner wired it to the master switch instead of the squat switch. You have a squat switch? BTW, we changed our Hobbes meter to run off of the heater. --kyler |
![]() Jim Burns wrote: Is there anybody out there with any insight into this dilemma? Thanks, Jim Hi Jim, I have a dual needle tach in the 310 with electric tach generators on each engine - no tach hour recorder. The plane has a hobbs meter that is activated by a switch. It's not exactly a weight on wheels switch. It is a microswitch activated by a small stainless steel flap on the belly that is sensitive to airflow, similar to a stall switch. DC power goes to the Hobbs, and the ground goes through the switch. It's supposed to activate at a certain airspeed, but I know it has some bounce due to airflow from propeller wash when taxiing and running up the engines. I previously had a Cessna single with both a Hobbs and Tach hour meter. When averaged, I found that multiplying 1.15 times the Tach meter was close to the Hobbs time. I've heard of others with planes on leaseback that only had tach meters charging something like 1.1 or 1.2 times the tach time. Brian |
new twin concept from Cirrus | Kingfish | Piloting | 25 | May 11th 06 06:49 PM |
Questions on twin operation | Frode Berg | Owning | 9 | May 5th 06 08:36 PM |
aftermarket de-ice for Twin Comanche | Dico | Owning | 1 | February 5th 06 05:51 PM |
twin tail questions | Kevin Horton | Home Built | 12 | January 2nd 04 03:21 PM |
True costs of a light twin... | Captain Wubba | Owning | 20 | November 20th 03 02:32 AM |
